Author Topic: Ethernet Problems  (Read 5686 times)
Offline Bigoeuf
Ethernet Problems
« on: February 08, 2017, 07:54:29 am »
The other day I bought a Cat5 lead & over the last day or so I have been trying to connect my laptop to the internet via the router. This is the first time I have tried this. I have connected via my phone both by tethered USB & mobile Wi-Fi hotspot & also via Wi-Fi to the broadband router - all with Network Manager - no real problems - Ethernet & Wi-Fi cards configured out the box when I installed Pepp 7  :)
Connected the laptop to the router with the Cat5 cable & set up & configured a new NM profile for eth0 interface - very basic settings:
 Connection Name: Router, Device:eth0(xx:xx:xx:xx:xx:xx),IPv4: Automatic (DHCP), IPv6:Ignore
Cant remember if I rebooted or not but was connected . Also the Default Profile was also there, pretty much the same settings as for the "Router" profile above & I was also able to connect with that one too. I'm not sure but here why the start of my problems lie because I thought, not unreasonably, I don't need 2 identical profiles - so I deleted the "Wired Ethernet 1" (Default) one, when I next booted the laptop - no eth0 connection.  ???
As far as can see if is down & I don't know to get it up:
 -I've read up & tried a few thing to try to get it working, reinstate a "Wired Ethernet 1"(Default) profile in NM & also change my "Router" profile name to "Wired Ethernet 1", manual configuration of IPs in NM & on the router (re-booting both after)
Done:
mick@mick-Inspiron-1501 ~ $ nmcli connection up "Wired Ethernet 1"
Error: Connection activation failed: No suitable device found for this connection.
Also done:
sudo modprobe b44
and then rebooted
And:
sudo cp /var/lib/NetworkManager/NetworkManager.state /var/lib/NetworkManager/NetworkManager.state.bak
sudo systemctl stop NetworkManager.service
rm /var/lib/NetworkManager/NetworkManager.state
sudo systemctl start NetworkManager.service
So I am where I should of come in the first place - just thought I may be able to work it out for myself - anyone help me out?
Cheers  :)
« Last Edit: February 09, 2017, 03:22:32 pm by Bigouef »
Re: Ethernet Problems
« Reply #1 on: February 08, 2017, 08:25:13 am »
Hi Bigouef,
It's strange you say this, I had problem connecting to the Ethernet this morning.  My solution was to turn off my modem and my computer, wait a minute, and then turn my modem and computer back on again.  Bigouef, have you tried turning your modem off and then turning it back on again?
perknh
« Reply #2 on: February 08, 2017, 09:40:18 am »
I'm kind of surprised your system doesn't appear to be using "predictable network interface names" and is still using "eth0" and "wlan0" .. have do done something to force this ?
Anyway, what's the output from:
ls -a /etc/NetworkManager/system-connectionsand
ifconfigand
lspci -vnn | grep -i net
Offline Bigoeuf
« Reply #3 on: February 08, 2017, 11:53:25 am »
Evening Perknh
Thanks for your response - No I haven't done that - I have only rebooted both will do it after I have responded to Mark  ;)
And evening to you to  Mark - Cheers for piping up  :)
Not that I am aware of - what would I have done to do this? Is it a problem? both interfaces appear to clearly & accurately identified?
Here's the info you asked for:
mick@mick-Inspiron-1501 ~ $ ls -a /etc/NetworkManager/system-connections
.  ..  517835  Moto G Tethered  PAJOIARO  Wired Ethernet 1
mick@mick-Inspiron-1501 ~ $ ifconfig
eth0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:21
          RX packets:907 errors:0 dropped:0 overruns:0 frame:0
          TX packets:907 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:78562 (78.5 KB)  TX bytes:78562 (78.5 KB)
wlan0     Link encap:Ethernet  HWaddr yy:yy:yy:yy:yy:yy
          RX packets:18362 errors:0 dropped:0 overruns:0 frame:0
          TX packets:17353 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:17211010 (17.2 MB)  TX bytes:2130136 (2.1 MB)
mick@mick-Inspiron-1501 ~ $ lspci -vnn | grep -i net
05:00.0 Network controller [0280]: Broadcom Corporation BCM4311 802.11b/g WLAN [14e4:4311] (rev 01)
08:00.0 Ethernet controller [0200]: Broadcom Corporation BCM4401-B0 100Base-TX [14e4:170c] (rev 02)
The Ethernet card is recognised in Network Manager:
http://imgur.com/a/byEs5
And I don't know if this is of any use but this is my /etc/network/interfaces file:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
In my trawling through forums I have seen eth0 listed here too  :-\
« Reply #4 on: February 08, 2017, 12:12:03 pm »
Okay I take it YOU modified the reply here:-
          Interrupt:21
If you run:
sudo pluma "/etc/NetworkManager/system-connections/Wired Ethernet 1"does it contain a line
mac-address=xx:xx:xx:xx:xx:xx
with the same address as the one reported by ifconfig ?
Quick question - Roughly how long is this ethernet cable ?
« Last Edit: February 08, 2017, 12:14:55 pm by PCNetSpec »
Offline Bigoeuf
« Reply #5 on: February 08, 2017, 12:54:20 pm »
Indeed I did Mark - I didn't think you were supposed to publicise your Mac addresses?
Yes the mac address  is the same - only difference is the letters are capitalised in the file:
[connection]
id=Wired Ethernet 1
uuid=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
type=ethernet
interface-name=eth0
permissions=
secondaries=
[ethernet]
duplex=full
mac-address-blacklist=
[ipv4]
dns-search=
method=auto
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
ip6-privacy=0
method=auto
Cable is 10m
Offline Bigoeuf
« Reply #6 on: February 08, 2017, 12:59:40 pm »
Hello Perknh
Just to let you know I tried what you said - infact I left the laptop & the router switched off for about 10/15 mins but no joy I'm afraid  :-\
« Reply #7 on: February 08, 2017, 01:15:26 pm »
Hello Perknh
That's too bad, Bigouef.  That would have been such a simple solution.  It's just a coincidence that we both lost connectivity around the same time.  PCNetSpec, I'm sure, will figure this mystery out. ;)
I thought it might have had something to do with a wayward update of some sort.
perknh
« Last Edit: February 08, 2017, 01:18:23 pm by perknh »
« Reply #8 on: February 08, 2017, 01:45:00 pm »
Are you sure this isn't just the cable ?
Have you tried a different ethernet socket on the router ?
Can you install ethtool:
sudo apt-get install ethtoolThen post the output from:
sudo ethtool eth0
If you haven't got an active internet connection to install ethtool, download one of these 2 files on a PC that *has* got a connection:-
32bit Peppermint 7
http://cz.archive.ubuntu.com/ubuntu/pool/main/e/ethtool/ethtool_4.5-1_i386.deb
64bit Peppermint 7
http://cz.archive.ubuntu.com/ubuntu/pool/main/e/ethtool/ethtool_4.5-1_amd64.deb
Transfer it to the Peppermint 7 PC, and double-click it to install.
« Last Edit: February 08, 2017, 02:21:02 pm by PCNetSpec »
« Reply #9 on: February 08, 2017, 02:02:47 pm »
I've been following the thread, PCNetSpec.  I was curious, so I ran the last command, but it didn't work for me.  I got this message instead:
perknh@peppermint ~ $ sudo ethtool eth0
[sudo] password for perknh:
sudo: ethtool: command not found
« Reply #10 on: February 08, 2017, 02:14:23 pm »
Cheers perknh, I'll add this to the post above.
Offline Bigoeuf
« Reply #11 on: February 08, 2017, 02:37:22 pm »
Well all can say about the cable is it has worked (as I said in my OP). Its brand new and I have handled it with care (no bends, kinks or pulling of connectors) & unfortunately it is the only one I have.I have tried all 4 Ethernet sockets & even turned the cable round & done the same again.  :-\
Here's what you asked for Mark:
mick@mick-Inspiron-1501 ~ $ sudo ethtool eth0
Settings for eth0:
Supported ports: [ MII ]
Supported link modes:   10baseT/Half 10baseT/Full
                        100baseT/Half 100baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes:  10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Speed: 10Mb/s
Duplex: Half
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: g
Wake-on: d
Current message level: 0x000000ff (255)
       drv probe link timer ifdown ifup rx_err tx_err
Link detected: no
« Reply #12 on: February 08, 2017, 02:50:27 pm »
well everything looks okay to me but it's not detecting a link
It would be handy if you could get another ethernet cable to test with.
Offline mac
« Reply #13 on: February 08, 2017, 02:55:26 pm »
If that doesn't work try logging into your router and checking your security settings....make sure your device is being allowed by the router.
cheers
Reg. Linux User #432835
« Reply #14 on: February 08, 2017, 03:03:16 pm »
What's the output from:
sudo mii-tool -v eth0then run
sudo mii-tool -R eth0and post the output from:
sudo mii-tool -v eth0again
For diagnostic purposes (to rule in/out hardware) it might be worth booting a LiveCD/LiveUSB and seeing if the ethernet cable/port works ?
« Last Edit: February 08, 2017, 03:11:20 pm by PCNetSpec »
