Author Topic: Linux Kernel 4.9.7 Brings Updates to the Intel i915 and InfiniBand Drivers, More  (Read 3796 times)
Yeah they make a lot more sense now :-\
All hail Linux 4.9.8 (4-FEB-2017)     8)
╭─vindsl@Boogaloo-6 ~
╰─➤  inxi -Fxz
System:    Host: Boogaloo-6 Kernel: 4.9.8-040908-generic i686 (32 bit gcc: 6.2.0) Desktop: N/A
           Distro: Peppermint Seven
Machine:   Mobo: N/A model: Canterwood Bios: Phoenix v: 6.00 PG date: 04/09/2004
CPU:       Single core Intel Pentium 4 (-HT-) cache: 2048 KB flags: (pae sse sse2) bmips: 6815
           clock speeds: max: 3407 MHz 1: 3407 MHz 2: 3407 MHz
Graphics:  Card: NVIDIA G73 [GeForce 7600 GT] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa) Resolution: 1280x1024@60.02hz
           GLX Renderer: Gallium 0.4 on NV4B GLX Version: 2.1 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card Intel 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller
           driver: snd_intel8x0 ports: d800 dc00 bus-ID: 00:1f.5
           Sound: Advanced Linux Sound Architecture v: k4.9.8-040908-generic
Network:   Card: Lite-On LNE100TX driver: tulip v: 1.1.15 port: a400 bus-ID: 02:0c.0
           IF: enp2s12 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives:    HDD Total Size: 1000.2GB (6.0% used) ID-1: /dev/sda model: SAMSUNG_HD103SJ size: 1000.2GB
Partition: ID-1: / size: 9.8G used: 4.2G (46%) fs: ext4 dev: /dev/sda11
           ID-2: /home size: 99G used: 51G (54%) fs: ext4 dev: /dev/sda12
           ID-3: swap-1 size: 2.15GB used: 0.00GB (0%) fs: swap dev: /dev/sda13
Sensors:   System Temperatures: cpu: 38.0C mobo: N/A gpu: 44.0
Info:      Processes: 166 Uptime: 6 min Memory: 305.3/2013.4MB Init: systemd runlevel: 5 Gcc sys: N/A
           Client: Shell (zsh 5.1.1) inxi: 2.2.35
Never could get the 32-bit rc(s) working right on Peppermint.  Decided to hold off for awhile, and 4.9.8 is working fine on my ancient iron (circa 2004) !
Worked a treat ...
╰─➤  echo && echo "~ VinDSL Unity Debug Script 13.07.08 (vindsl.com) ~" && echo -n "Current Date/Time: " && TZ='UTC' date && echo -n "Distro Release: " && lsb_release -sd && echo -n "Kernel Release: " || cat /etc/*release && uname -s -r && echo -n "Gnome Release: " && gnome-shell --version && echo -n "Unity Release: " && unity --version && echo && /usr/lib/nux/unity_support_test -p -f && echo || echo && dpkg -s mesa-utils && echo || echo && echo "Package: mesa-common-dev" && dpkg -s mesa-common-dev | sed 's/^/  /' | grep Version && echo || echo && echo "Package: xserver-xorg-core" && apt-cache policy xserver-xorg-core | grep Installed && echo || echo && echo "Package: xserver-common" && apt-cache policy xserver-common | grep Installed && echo || echo && echo "Package: xserver-xephyr" && apt-cache policy xserver-xephyr | grep Installed && echo || echo && echo "Tree Map of PCI Devices:" && lspci -tv && echo || echo && echo "Display Properties:" && echo -n " lcd monitor:    Dell UltraSharp 1907FP (analog input)" && echo && xdpyinfo | grep -E '(resolution|dimensions)' && echo
Current Date/Time: Sat Feb  4 17:37:13 UTC 2017
Distro Release: Peppermint 7 Seven
Kernel Release: Linux 4.9.8-040908-generic
Gnome Release: zsh: command not found: gnome-shell
Package: mesa-utils
Status: install ok installed
Priority: optional
Section: x11
Installed-Size: 99
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: i386
Source: mesa-demos
Version: 8.3.0-1
Depends: libc6 (>= 2.4), libgl1-mesa-glx | libgl1, libx11-6
Description: Miscellaneous Mesa GL utilities
 This package provides several basic GL utilities built by Mesa, including
 glxinfo and glxgears.
Original-Maintainer: Debian X Strike Force <debian-x@lists.debian.org>
Homepage: http://mesa3d.org/
  Version: 11.2.0-1ubuntu2.2
  Installed: 2:1.18.4-0ubuntu0.2
  Installed: (none)
-[0000:00]-+-00.0  Intel Corporation 82875P/E7210 Memory Controller Hub
           +-01.0-[01]----00.0  NVIDIA Corporation G73 [GeForce 7600 GT]
           +-06.0  Intel Corporation 82875P/E7210 Processor to I/O Memory Interface
           +-1d.0  Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1
           +-1d.1  Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2
           +-1d.2  Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3
           +-1d.3  Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4
           +-1d.7  Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller
           +-1e.0-[02]----0c.0  Lite-On Communications Inc LNE100TX
           +-1f.0  Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge
           +-1f.2  Intel Corporation 82801EB (ICH5) SATA Controller
           +-1f.3  Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller
           \-1f.5  Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller
Display Properties:
  dimensions:    1280x1024 pixels (338x270 millimeters)
  resolution:    96x96 dots per inch
╰─➤  uptime
 10:37:40 up  2:30,  1 user,  load average: 0.30, 0.75, 1.03
Okay, I'm done testing my 32-bit Peppermint install, for the day.
Back to me Dells ...   8)
And, they just keep coming ...   :)
4.9.9 installed (*manually) and running fine on 32-bit Peppermint 7.  Gonna go install it on my 64-bit machines now.   8)
You do realise you can now upgrade the entire graphics stack too via the HWE (used to be known as the LTS Enablement Stack) ?
https://wiki.ubuntu.com/Kernel/LTSEnablementStack
It's not "quite" ready for the main repo release, so you'll need to enable the "proposed" repo.
it updates the kernel to the 16.10 (4.8 series), and the graphics stack too.
Just thinking it should bring the graphics stack more in line with the 4.9 kernel you're using now .. a LOT of people have said 16.10 is better for gaming than 16.04, so maybe this will improve that, but I'm not enough of a gamer to be able to judge.
« Last Edit: February 11, 2017, 12:26:38 pm by PCNetSpec »
Yeah, might do that.  I generally don't worry about graphic stacks.  Thx for the reminder.
The 'trick' with proposed is to use it like salt n' pepper.  Enable it, sprinkle it on, and disable it again.
The 'problem' with proposed, these days, is there are a lot of incomplete packages in there, so you don't want to leave proposed enabled and forget about it.  It'll bite you in the azz sooner or later.   ;)
