Author Topic: Linux Kernel 4.9.7 Brings Updates to the Intel i915 and InfiniBand Drivers, More  (Read 3435 times)
Offline VinDSL
It's time to upgrade the Linux kernel packages of our GNU/Linux distributions once more, as renowned Linux kernel maintainer Greg Kroah-Hartman today, February 2, 2017, announced the release of Linux kernel 4.9.7.[...]
While still not marked as "longterm" on the kernel.org website, the Linux 4.9 kernel series recently become LTS (Long Term Support), which means that it will be supported with security patches for a couple of years. It also means that OS vendors need to adopt the Linux 4.9 kernel series for their distros as soon as possible. Arch Linux and Solus are already powered by Linux kernel 4.9, so make sure you update your PCs right now.[...]
If you're using a GNU/Linux distribution powered by a kernel from the Linux 4.9 series, we recommend updating to today's Linux kernel 4.9.7 release as soon as possible. It already landed for Solus users and it's coming very soon to Arch Linux and openSUSE Tumbleweed, as well as other distro
SOURCE:  https://goo.gl/g8C5DM
Offline VinDSL
Come on in, the water's fine !   8)
╭─vindsl@Boogaloo-5 ~
╰─➤  inxi -Fzx
System:    Host: Boogaloo-5 Kernel: 4.9.7-040907-generic x86_64 (64 bit gcc: 6.2.0) Desktop: N/A
           Distro: Peppermint Seven
Machine:   System: Dell product: OptiPlex 7010 v: 01
           Mobo: Dell model: 0GXM1W v: A02 Bios: Dell v: A23 date: 08/09/2016
CPU:       Quad core Intel Core i5-3470 (-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 25541
           clock speeds: max: 3600 MHz 1: 2891 MHz 2: 2695 MHz 3: 2901 MHz 4: 2623 MHz
Graphics:  Card: NVIDIA GK208 [GeForce GT 710B] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 driver: nvidia
           Resolution: 1280x1024@60.02hz, 1280x1024@60.02hz, 2560x1080@60.00hz
           GLX Renderer: GeForce GT 710/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 375.26 Direct Rendering: Yes
Audio:     Card-1 Intel 7 Series/C210 Series Family High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 NVIDIA GK208 HDMI/DP Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
           Sound: Advanced Linux Sound Architecture v: k4.9.7-040907-generic
Network:   Card: Intel 82579LM Gigabit Network Connection driver: e1000e v: 3.2.6-k port: f040 bus-ID: 00:19.0
           IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 250.1GB (12.9% used) ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB
Partition: ID-1: / size: 20G used: 8.3G (45%) fs: ext4 dev: /dev/sda5
           ID-2: /home size: 30G used: 21G (75%) fs: ext4 dev: /dev/sda6
           ID-3: swap-1 size: 0.54GB used: 0.00GB (0%) fs: swap dev: /dev/sda10
           ID-4: swap-2 size: 0.54GB used: 0.00GB (0%) fs: swap dev: /dev/sda7
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 0.0:54C
Info:      Processes: 223 Uptime: 4 min Memory: 1271.2/16000.8MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
           Client: Shell (zsh 5.1.1) inxi: 2.2.35
Offline VinDSL
3 second boot -- flies like the wind. *
* Results may vary ...    ;)
Save me looking though all that .. is that with the network card that was causing slow boots before, or did you fix that ?
As this is in a public facing forum and as a moderator VinDSL's post could be misconstrued by new users as "advice" to change kernel, I'd just like to add that Team Peppermints advice is to stick with the default kernel unless you have a specific reason to change .. if you manually install a non default kernel you'll also need to manually stay on top of security patches yourself (they will no longer be automatic).
« Last Edit: February 02, 2017, 08:58:35 pm by PCNetSpec »
Offline VinDSL
Apples n' oranges.  The (above) is my desktop machine.  I haven't installed 4.9.7 in my laptop (with the 'slow' boot times)  yet.
Matter of fact, the new Intel 7260 wifi card just arrived, an hour or two ago.  I pulled the Broadcom card, replaced it with the Intel 7260, and decided to look for Linux drivers.  However ...
As fate would have it, I booted into '10', to make sure the new card worked.  Good thing:  it worked (including the bluetooth feature).  Bad thing:  There was a cumulative update sitting there, whatever that means, and it tied up my lappy for 45 minutes, downloading and installing the updates.  Gotta love winders   ::)
So, I'll see if the new wifi card takes care of the 'slow' boot, and soon as I get the drivers sorted.
« Last Edit: February 03, 2017, 06:02:01 am by VinDSL, Reason: Added Link »
Offline VinDSL
True !
I might also add, don't install winders 10 either (mentioned above) if you're concerned about WiFi security  ...    ;D
« Last Edit: February 03, 2017, 06:06:06 am by VinDSL, Reason: Addendum »
Offline VinDSL
Well, that was interesting !
I downloaded the firmware blob from Intel, went to install it, and the drivers were already sitting in ~/lib/firmware, but the card wasn't working  :-\
So, I checked it in CLI ...
vindsl@Chi-You ~ $ dmesg | grep iwl
[    2.904220] iwlwifi 0000:02:00.0: enabling device (0100 -> 0102)
[    2.919418] iwlwifi 0000:02:00.0: loaded firmware version 17.352738.0 op_mode iwlmvm
[    2.958759] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144
[    2.958847] iwlwifi 0000:02:00.0: L1 Enabled - LTR Disabled
[    2.959165] iwlwifi 0000:02:00.0: L1 Enabled - LTR Disabled
[    3.197690] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    3.212725] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[   20.248010] iwlwifi 0000:02:00.0: RF_KILL bit toggled to disable radio.
[   88.829272] iwlwifi 0000:02:00.0: RF_KILL bit toggled to enable radio.
[  186.037228] iwlwifi 0000:02:00.0: RF_KILL bit toggled to disable radio.
[  189.750618] iwlwifi 0000:02:00.0: RF_KILL bit toggled to enable radio.
vindsl@Chi-You ~ $
Yup, working !
So, I checked wicked (WiCD).
For some reason, wicked thought the WiFi interface addy was wlp2s0b1
I removed the 'b1' and BAM !  It immediately started working.
Aren't computers fun ?   :)
Offline VinDSL
Hrm...
Something doesn't seem right.  Maybe the script I'm using to generate the plot is somehow misrepresenting the values.
If you look at the column header -- the firmware and loader times are negative seconds.  The actual boot time starts at '0', right ?
If that's the case, then I'm really getting a 4 second boot on the lappy.
It *feels* like 4 seconds -- no way it's taking 10 seconds to boot this thing ...   :P
Oh, well, I'll figure it out.  I'll test the new card on the routers at work in the morning, to see if the range improved.
Yeah I had to boot Win10 the other day expecting it to take about 2 - 3 minutes .. on rebooting "Windows is preparing your updates, do not turn off your PC" (or sommat similar) .. one and a half %&^$ing hours just to shut down >:(
Whilst staring at that damn screen for ages it dawned on me they've removed the "please" .. I'd have sworn Win7 used to say "PLEASE don't turn off your PC" (or sommat similar).
« Last Edit: February 03, 2017, 06:47:01 am by PCNetSpec »
http://www.howtogeek.com/268982/how-to-shut-down-a-windows-pc-without-installing-updates/
For the next time you have to suffer the indignity and you have better things to do  ;D
Handy to know as long as it doesn't stuff things up .. but that doesn't really change my opinion of their update system ;)
It didn't for me when I have used it in the past.
Offline VinDSL
To be fair, fsck is a pain, too !
My all-time favorite fsck tale: https://goo.gl/GLFwRK
Memorable quote:  "Overall, FSCK on a 1.7 TB machine appears to take about 96+/- hours to run when you've really abused it."
About on par with chkdsk /r then ;)
If you're going to do a multiple read/copy/compare/relocate on every single individual sector of a 2TB spinner it's gonna take AGES no matter what the file system or tool doing it.
at least fsck/e2fsck gives you more control.
And who said I was being fair anyway >:D
more ANGRY at the time .. and I've never had Linux decide to run fsck just to reboot >:(
« Last Edit: February 03, 2017, 07:58:46 pm by PCNetSpec »
Offline VinDSL
Ran some tests at work today, with my infamous Intel AC 7260 card.
First impression was it worked fine on '10', but I wasn't so sure about Linux.
Later in the day, it seemed to be working ok on Linux, so I did some forensics when I got back to the abode.
I had a feeling I was missing a few pieces of the puzzle, so I D/L & installed the Intel Graphics Update Tool.  Doesn't make since that a graphic update tool would improve my wifi card, but it contained a lot of ancillary drivers that I would have needed to download and install individually anyway -- sort of like the Microsoft 'shotgun' approach, you know ?  Toss everything in, including the kitchen sink ...
Anyway, this thing is hauling azz now, wifi, video, all things Intel.  Feels every bit as fast as my desktop machine.
Wifi upload & download speeds match the CAT5 connection speeds on my desktop machine, too, so it must be working.
I'll keep tweaking things, and give it another test at work next week.
Back OT, I installed Linux 4.9.7 on this laptop, a few hours ago.  Running without a hitch, so far.
Oh, BTW, I found out where wicked picked up the 'b1' in wlp2s0b1
vindsl@Chi-You ~ $ lspci -nnk
02:00.0 Network controller [0280]: Intel Corporation Wireless 7260 [8086:08b1] (rev bb)
   Subsystem: Intel Corporation Dual Band Wireless-AC 7260 [8086:4070]
   Kernel driver in use: iwlwifi
   Kernel modules: iwlwifi
Remember this article ? : https://major.io/2015/08/21/understanding-systemds-predictable-network-device-names/   LoL !   :D
