Author Topic: new wifi usb drivers are... Realtek RTL8812AU chipset [SOLVED x9]  (Read 22440 times)
Re: new wifi usb drivers are... Realtek RTL8812AU chipset
« Reply #30 on: February 02, 2017, 05:52:44 pm »
okay run:
sudo apt-get remove --purge rtl8812au-dkms
sudo apt-get update && sudo apt-get upgrade && sudo apt-get dist-upgrade
then REBOOT.
Once rebooted, run:
modinfo 8812au
and as long as you get
modinfo: ERROR: Module 8812au not found.
run:
sudo rm -rv ~/RTL8812AU
then follow the instructions here again
https://forum.peppermintos.com/index.php/topic,5018.msg50284.html#msg50284
« Last Edit: February 02, 2017, 05:54:23 pm by PCNetSpec »
    • My MeWe profile
« Reply #31 on: February 02, 2017, 06:21:36 pm »
It didn't spring to life until after after I moved USB dongle to a different slot. I leave it be for now, perhaps next go round, I'll be repeating with the "possibly newer version" at the bottom of the last set of instructions...
spence@antec ~ $ modinfo 8812aumodinfo: ERROR: Module 8812au not found.
spence@antec ~ $ sudo rm -rv ~/RTL8812AU
[sudo] password for spence:
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_dm.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_types_linux.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/byteorder/little_endian.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/byteorder/swab.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/byteorder/generic.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/byteorder/big_endian.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/byteorder/swabb.h'
removed directory '/home/spence/RTL8812AU/rtl8812au/include/byteorder'
removed '/home/spence/RTL8812AU/rtl8812au/include/sdio_ops_ce.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_eeprom.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8812PwrSeq.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8192CPhyReg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/mp_custom_oid.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_version.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_mp_phy_regdef.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8723PwrSeq.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_com_reg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_dm.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_pg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8723BPhyReg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_ht.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8188EPwrSeq.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/wifi.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8192DPhyCfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/osdep_service.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/usb_ops_linux.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_ioctl_query.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_conf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_sreset.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/custom_gpio.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_ioctl_set.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/ethernet.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8192EPhyReg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8192EPhyCfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_pg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_sreset.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8723BPwrSeq.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/usb_vendor_req.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8192CPhyCfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/ieee80211.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_sreset.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/nic_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_android.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/pci_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_bt-coexist.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/gspi_ops_linux.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_dm.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/osdep_service_xp.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/osdep_service_linux.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/sdio_ops.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8192EPwrSeq.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_types_gspi.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_com_phycfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_com_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/circ_buf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/osdep_service_bsd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_mp.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_dm.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_debug.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_efuse.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_qos.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/wlan_bssdef.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/pci_osintf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/usb_ops.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_intf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_event.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/pci_ops.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_bt_mp.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_data.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_sreset.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_mlme_ext.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/ioctl_cfg80211.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_bt-coexist.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_security.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_tdls.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8723BPhyCfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/cmd_osdep.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/sdio_ops_xp.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_sreset.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/sdio_osintf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_sreset.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_types_pci.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8821a_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_dm.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_pwrctrl.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/sdio_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/recv_osdep.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_event.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_byteorder.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_ioctl.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/osdep_service_ce.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_wapi.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_types.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_com.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/mlme_osdep.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8723APhyReg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8723APhyCfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8812PhyReg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8188e_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_phy_reg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/sta_info.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_recv.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_vht.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192c_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/gspi_osintf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_dm.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/ieee80211_ext.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8821APwrSeq.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/osdep_intf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/usb_osintf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/usb_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/hal_phy.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8812PhyCfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_types_xp.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8188EPhyReg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_led.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/basic_types.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_ap.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8192DPhyReg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/autoconf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_dm.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_io.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_iol.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/gspi_hal.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723b_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_mlme.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/if_ether.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_sreset.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/xmit_osdep.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/h2clbk.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8723a_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/Hal8188EPhyCfg.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_mp_ioctl.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_p2p.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/ip.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_ioctl_rtl.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_types_ce.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_xmit.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192d_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/HalPwrSeqCmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/HalVerDef.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_rf.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8192e_cmd.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtl8812a_spec.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/linux/wireless.h'
removed directory '/home/spence/RTL8812AU/rtl8812au/include/linux'
removed '/home/spence/RTL8812AU/rtl8812au/include/sdio_ops_linux.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/drv_types_sdio.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/gspi_ops.h'
removed '/home/spence/RTL8812AU/rtl8812au/include/rtw_br_ext.h'
removed directory '/home/spence/RTL8812AU/rtl8812au/include'
removed '/home/spence/RTL8812AU/rtl8812au/Kconfig'
removed '/home/spence/RTL8812AU/rtl8812au/runwpa'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_wlan_util.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_recv.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_io.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_eeprom.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_wapi.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_iol.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_security.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_br_ext.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_ap.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_debug.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_tdls.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_pwrctrl.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_ioctl_rtl.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_sreset.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_mp.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_ioctl_set.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_cmd.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_mlme_ext.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_ieee80211.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_bt_mp.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_mlme.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_rf.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_vht.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_sta_mgt.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/efuse/rtw_efuse.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/core/efuse'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_ioctl_query.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_wapi_sms4.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_mp_ioctl.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_p2p.c'
removed '/home/spence/RTL8812AU/rtl8812au/core/rtw_xmit.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/core'
removed '/home/spence/RTL8812AU/rtl8812au/wlan0dhcp'
removed '/home/spence/RTL8812AU/rtl8812au/dkms.conf'
removed '/home/spence/RTL8812AU/rtl8812au/Makefile'
removed '/home/spence/RTL8812AU/rtl8812au/clean'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/osdep_service.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/ioctl_cfg80211.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/mlme_linux.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/os_intfs.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/ioctl_linux.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/xmit_linux.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/custom_gpio_linux.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/rtw_android.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/usb_intf.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/recv_linux.c'
removed '/home/spence/RTL8812AU/rtl8812au/os_dep/linux/usb_ops_linux.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/os_dep/linux'
removed directory '/home/spence/RTL8812AU/rtl8812au/os_dep'
removed '/home/spence/RTL8812AU/rtl8812au/ifcfg-wlan0'
removed '/home/spence/RTL8812AU/rtl8812au/install.sh'
removed '/home/spence/RTL8812AU/rtl8812au/hal/hal_intf.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/hal_com.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/led/hal_usb_led.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/hal/led'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_types.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_HWConfig.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/HalPhyRf.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_precomp.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_interface.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_debug.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_HWConfig.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_reg.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_MAC.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_MAC.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalPhyRf_8812A.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_BB.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_FW.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_MAC.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_BB.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_RF.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_FW.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_MAC.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_FW.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/odm_RegConfig8812A.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/odm_RegConfig8812A.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_RF.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_RF.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_BB.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalPhyRf_8812A.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_RF.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_TestChip_BB.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a/HalHWImg8812A_FW.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8812a'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_RegDefine11N.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_RegDefine11AC.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/HalPhyRf.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_MAC.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/odm_RegConfig8821A.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_BB.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalPhyRf_8821A.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_BB.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_TestChip_RF.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_MAC.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_FW.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_TestChip_RF.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_TestChip_BB.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_RF.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_TestChip_BB.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/odm_RegConfig8821A.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_TestChip_MAC.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_FW.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_RF.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalPhyRf_8821A.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a/HalHWImg8821A_TestChip_MAC.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/rtl8821a'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_debug.h'
removed '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC/odm_interface.h'
removed directory '/home/spence/RTL8812AU/rtl8812au/hal/OUTSRC'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/usb/rtl8812au_recv.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/usb/usb_halinit.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/usb/rtl8812au_xmit.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/usb/rtl8812au_led.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/usb/usb_ops_linux.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/usb'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_hal_init.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/Hal8812PwrSeq.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_dm.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/Hal8821APwrSeq.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_rf6052.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_cmd.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_sreset.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_rxdesc.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_phycfg.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_xmit.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a/rtl8812a_mp.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/hal/rtl8812a'
removed '/home/spence/RTL8812AU/rtl8812au/hal/hal_phy.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/HalPwrSeqCmd.c'
removed '/home/spence/RTL8812AU/rtl8812au/hal/hal_com_phycfg.c'
removed directory '/home/spence/RTL8812AU/rtl8812au/hal'
removed '/home/spence/RTL8812AU/rtl8812au/.git/description'
removed '/home/spence/RTL8812AU/rtl8812au/.git/index'
removed '/home/spence/RTL8812AU/rtl8812au/.git/objects/pack/pack-1f00e36a794f010eb9d362cba5aa7d7f3f4ede65.idx'
removed '/home/spence/RTL8812AU/rtl8812au/.git/objects/pack/pack-1f00e36a794f010eb9d362cba5aa7d7f3f4ede65.pack'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/objects/pack'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/objects/info'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/objects'
removed '/home/spence/RTL8812AU/rtl8812au/.git/info/exclude'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/info'
removed '/home/spence/RTL8812AU/rtl8812au/.git/logs/HEAD'
removed '/home/spence/RTL8812AU/rtl8812au/.git/logs/refs/heads/master'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/logs/refs/heads'
removed '/home/spence/RTL8812AU/rtl8812au/.git/logs/refs/remotes/origin/HEAD'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/logs/refs/remotes/origin'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/logs/refs/remotes'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/logs/refs'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/logs'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/branches'
removed '/home/spence/RTL8812AU/rtl8812au/.git/HEAD'
removed '/home/spence/RTL8812AU/rtl8812au/.git/packed-refs'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/refs/tags'
removed '/home/spence/RTL8812AU/rtl8812au/.git/refs/heads/master'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/refs/heads'
removed '/home/spence/RTL8812AU/rtl8812au/.git/refs/remotes/origin/HEAD'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/refs/remotes/origin'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/refs/remotes'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/refs'
removed '/home/spence/RTL8812AU/rtl8812au/.git/config'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/commit-msg.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/pre-push.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/applypatch-msg.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/post-update.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/pre-commit.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/prepare-commit-msg.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/pre-rebase.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/pre-applypatch.sample'
removed '/home/spence/RTL8812AU/rtl8812au/.git/hooks/update.sample'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git/hooks'
removed directory '/home/spence/RTL8812AU/rtl8812au/.git'
removed '/home/spence/RTL8812AU/rtl8812au/README.md'
removed directory '/home/spence/RTL8812AU/rtl8812au'
removed directory '/home/spence/RTL8812AU'
spence@antec ~ $ sudo apt-get remove --purge rtl8812au-dkms
Reading package lists... Done
Building dependency tree
Package 'rtl8812au-dkms' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
spence@antec ~ $ sudo dkms remove -m 8812au -v 4.2.2 --all
Error! There are no instances of module: 8812au
4.2.2 located in the DKMS tree.
spence@antec ~ $ sudo apt-get install build-essential dkms git
build-essential is already the newest version (12.1ubuntu2).
git is already the newest version (1:2.7.4-0ubuntu1).
dkms is already the newest version (2.2.0.3-2ubuntu11.3).
spence@antec ~ $ mkdir ~/RTL8812AU
spence@antec ~ $ cd ~/RTL8812AU
spence@antec ~/RTL8812AU $ git clone https://github.com/gnab/rtl8812au.git
Cloning into 'rtl8812au'...
remote: Counting objects: 515, done.
remote: Total 515 (delta 0), reused 0 (delta 0), pack-reused 514
Receiving objects: 100% (515/515), 1.62 MiB | 1.72 MiB/s, done.
Resolving deltas: 100% (202/202), done.
Checking connectivity... done.
spence@antec ~/RTL8812AU $ sudo cp -R rtl8812au /usr/src/8812au-4.2.2
spence@antec ~/RTL8812AU $ sudo dkms add -m 8812au -v 4.2.2
Creating symlink /var/lib/dkms/8812au/4.2.2/source ->
DKMS: add completed.
spence@antec ~/RTL8812AU $ sudo dkms build -m 8812au -v 4.2.2
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area....
'make' all..........
DKMS: build completed.
spence@antec ~/RTL8812AU $ sudo dkms install -m 8812au -v 4.2.2
8812au:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/4.4.0-62-generic/kernel/drivers/net/wireless/
depmod....
DKMS: install completed.
spence@antec ~/RTL8812AU $ sudo modpobe -r 8812au
sudo: modpobe: command not found
spence@antec ~/RTL8812AU $ sudo modprobe -r 8812au
spence@antec ~/RTL8812AU $ sudo modprobe 8812au
spence@antec ~/RTL8812AU $ lsmod | grep 8812
8812au                991232  0
spence@antec ~/RTL8812AU $ sudo dkms status
8812au, 4.2.2, 4.4.0-62-generic, x86_64: installed
spence@antec ~/RTL8812AU $ sudo lshw -C network
  *-network
       product: Ethernet Connection (2) I219-V
       vendor: Intel Corporation
       physical id: 1f.6
       bus info: pci@0000:00:1f.6
       logical name: enp0s31f6
       version: 00
       serial: 70:85:c2:29:10:c2
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.2-4 ip=192.168.1.23 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:132 memory:df100000-df11ffff
  *-network DISABLED
       physical id: 1
       bus info: usb@1:11
       logical name: enp0s20f0u11
       serial: 16:88:11:c3:6d:b9
       configuration: broadcast=yes driver=rtl8812au multicast=yes wireless=unassociated
spence@antec ~/RTL8812AU $ modinfo 8812au | grep -i version
version:        v4.2.2_7502.20130517
srcversion:     86A0F0E9D0592F171DD97D4
vermagic:       4.4.0-62-generic SMP mod_unload modversions
parm:           rtw_chip_version:int
Wifi didn't survive reboot, but revived upon moving to a different slot
« Last Edit: February 02, 2017, 07:18:01 pm by spence »
 '18 Asus VivoBook
« Reply #32 on: February 02, 2017, 06:49:57 pm »
So is it working now ?
It looks like the "newer version" is the same one from the repos, which didn't work earlier but may have just been the USB slot.
« Last Edit: February 02, 2017, 06:51:42 pm by PCNetSpec »
    • My MeWe profile
« Reply #33 on: February 02, 2017, 07:19:57 pm »
its working... but not gonna mark it solved just yet...  :-\
Might I also assume I'll need to go thru these motions with each upgrade of the kernel?
« Last Edit: February 02, 2017, 07:26:53 pm by spence »
 '18 Asus VivoBook
« Reply #34 on: February 02, 2017, 07:45:28 pm »
Theoretically NO, that's supposed to be the whole point of dkms (they get recompiled automatically against a new kernel) .. dunno what went wrong the last time though.
If they stop working after the next kernel upgrade, see if just running:
fixes things.
« Last Edit: February 02, 2017, 07:54:05 pm by PCNetSpec »
    • My MeWe profile
« Reply #35 on: February 02, 2017, 08:41:57 pm »
Well vinDSL just invited us all to update our kernels to 4.9.7 ... but think I'mma gonna wait... sorta drained today  ;)
 '18 Asus VivoBook
« Reply #36 on: February 02, 2017, 08:49:59 pm »
Stick with the default kernel unless you have a specific reason to change .. if you manually install 4.9 you'll have to manually stay on top of security patches.
    • My MeWe profile
« Reply #37 on: February 04, 2017, 02:43:02 pm »
Happpy to report relatively working wifi over the last few days. Each time I boot or reboot though, I have to pull out then re-insert the USB dongle. Seem to recollect reading something about the power down command along the way messing with Realtek chipsets...
Also noted that I now have two folders related to the RTL8812AU in my home folders now... which I perhaps need help clearing out after recollecting where they're supposed to be located?...
 '18 Asus VivoBook
« Reply #38 on: February 04, 2017, 04:16:16 pm »
You can delete those directories if you like
    • My MeWe profile
Re: new wifi usb drivers are... Realtek RTL8812AU chipset [reSOLVED]
« Reply #39 on: February 06, 2017, 11:59:08 pm »
Those directories are deleted/removed. Gonna mark this as reSOLVED, as I'm letting myself become accustomed to letting the desktop stay turned on and allowing the powe management settings to put it into hibernation/suspend. The wifi dongle remains connected to the wifi network when returning from that state w/o having to be pulled out and plugged back in. I'll start a new thread if I begin having more issues with it later.
 '18 Asus VivoBook
Offline Gunnvald
« Reply #41 on: June 01, 2017, 01:29:48 pm »
Thanks for the additional info Gunnvald, and welcome to the madhouse forum :)
    • My MeWe profile
« Reply #42 on: July 04, 2017, 01:32:30 am »
:o Well, I am quite frankly, stunned :o updated my Antec Aria desktop rebuild to Peppermint 8 two days ago with an ethernet connection. Wasn't expecting the wifi usb dongle to work without some fanagling. Turned it on this evening and noticed the blue light indicated it was working. Voila! I'm typing over the wifi network once again, without having to pester PCNetSpec... #KOW  8)
 '18 Asus VivoBook
    • My MeWe profile
« Reply #43 on: August 02, 2017, 04:57:21 pm »
Seems a storm knocked out our power while we were away and the wireless WiFi usb dongle may have suffered...
Any particular reason you're not just installing it via the repos:
sudo apt-get install rtl8812au-dkms
Decided to go back t this thread to see if I could get it fired up once again... but first intruction turned up an error:
spence@antec ~ $ sudo apt-get install rtl8812au-dkms
The following package was automatically installed and is no longer required:
  thermald
Use 'sudo apt autoremove' to remove it.
  rtl8812au-dkms
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,024 kB of archives.
After this operation, 7,778 kB of additional disk space will be used.
Get:1 http://mx.archive.ubuntu.com/ubuntu xenial/universe amd64 rtl8812au-dkms all 4.3.8.12175.20140902+dfsg-0ubuntu2 [1,024 kB]
Fetched 1,024 kB in 1s (779 kB/s)
Selecting previously unselected package rtl8812au-dkms.
(Reading database ... 273057 files and directories currently installed.)
Preparing to unpack .../rtl8812au-dkms_4.3.8.12175.20140902+dfsg-0ubuntu2_all.deb ...
Unpacking rtl8812au-dkms (4.3.8.12175.20140902+dfsg-0ubuntu2) ...
Setting up rtl8812au-dkms (4.3.8.12175.20140902+dfsg-0ubuntu2) ...
Loading new rtl8812au-4.3.8.12175.20140902+dfsg DKMS files...
First Installation: checking all kernels...
Building only for 4.10.0-28-generic
Building initial module for 4.10.0-28-generic
Error! Bad return status for module build on kernel: 4.10.0-28-generic (x86_64)
Consult /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/make.log for more information.
Now to study reast of previous instructions  ::)
 '18 Asus VivoBook
    • My MeWe profile
« Reply #44 on: August 02, 2017, 05:09:47 pm »
As I plow thru the prvious set of intructions I realize I'm making one mistake...  but the terminal output provides a sigh of relief as it says:
spence@antec ~/RTL8812AU $ sudo dkms install -m 8812au -v 4.3.8
8812au:
Good news! Module version v4.2.2_7502.20130517 for 8812au.ko
exactly matches what is already found in kernel 4.10.0-28-generic.
DKMS will not replace this module.
You may override by specifying --force.
depmod....
Meanwhile, here's the rest of what I had done... and will now redo in a bit with proper kernel info...  ::)
spence@antec ~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser
Bus 001 Device 003: ID 0bda:0811 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 07cc:0501 Carry Computer Eng., Co., Ltd Mass Storage
  thermald
The following packages will be REMOVED:
  rtl8812au-dkms*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 7,778 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 273410 files and directories currently installed.)
Removing rtl8812au-dkms (4.3.8.12175.20140902+dfsg-0ubuntu2) ...
Deleting module version: 4.3.8.12175.20140902+dfsg
completely from the DKMS tree.
Done.
spence@antec ~ $ sudo dkms remove -m 8812au -v 4.3.8 --all
4.3.8 located in the DKMS tree.
git is already the newest version (1:2.7.4-0ubuntu1.1).
  thermald
spence@antec ~ $ sudo apt autoremove
  thermald
After this operation, 586 kB disk space will be freed.
(Reading database ... 273056 files and directories currently installed.)
Removing thermald (1.5-2ubuntu4) ...
Processing triggers for dbus (1.10.6-1ubuntu3.3) ...
Processing triggers for man-db (2.7.5-1) ...
remote: Counting objects: 551, done.
remote: Total 551 (delta 0), reused 0 (delta 0), pack-reused 551
Receiving objects: 100% (551/551), 1.67 MiB | 0 bytes/s, done.
Resolving deltas: 100% (215/215), done.
spence@antec ~/RTL8812AU $ sudo cp -R rtl8812au /usr/src/8812au-4.3.8
spence@antec ~/RTL8812AU $ sudo dkms add -m 8812au -v 4.3.8
Creating symlink /var/lib/dkms/8812au/4.3.8/source ->
spence@antec ~/RTL8812AU $ sudo dkms build -m 8812au -v 4.3.8
Building module:
8812au:
depmod....
spence@antec ~/RTL8812AU $ sudo modpobe 8812au
Even as i scratch my concussioned head about modprobe?
ahhh, see mispelling
« Last Edit: August 02, 2017, 05:11:19 pm by spence »
 '18 Asus VivoBook
