Author Topic: new wifi usb drivers are... Realtek RTL8812AU chipset (RESOLVED x 14)  (Read 26607 times)
oh well... looks like I managed to order something with Realtek drivers once again. The documentation reveals the included .tar only supports linux kernels thru 3.1. Is there a way to find an updated driver? I've been all over the web since this arrived.... I think my bald spot has doubled in size and my gray hair mass has tripled...
I did locate the following... https://github.com/gnab/rtl8812au which gives me hope...
as well as this... http://askubuntu.com/questions/491263/installing-rtl8812au-linux-v4-2-0-6952-20130315-tar-gz hmmmm rebooting now... keeping fingers crossed...
« Last Edit: April 28, 2020, 05:34:44 pm by spence »
Re: new wifi usb drivers are... Realtek RTL8812AU chipset
« Reply #1 on: February 01, 2017, 12:32:08 pm »
Okay, now that all the Christmas holidaze stuff is packed away, I have time to focus on getting these drivers properly installed...
After finding this: http://askubuntu.com/questions/491263/installing-rtl8812au-linux-v4-2-0-6952-20130315-tar-gz
 I went thru the following steps,
sudo apt install rtl8812au-dkms
rfkill list
sudo lshw -C network
iwlist scan
iwconfig
sudo apt-get install build-essential git
git clone https://github.com/gnab/rtl8812au.git
cd rtl8812au
make
sudo make install
sudo modprobe 8812au
sh
yet still have no "installed drivers" it seems... My apologies in advance for being a befuddled old man...
« Reply #2 on: February 01, 2017, 01:31:14 pm »
Any particular reason you're not just installing it via the repos:
sudo apt-get install rtl8812au-dkms?
« Reply #3 on: February 01, 2017, 01:37:04 pm »
It was the first thing I tried, top of that list from my bash history, didn't work/take or something...
spence@antec ~ $ sudo apt install rtl8812au-dkms
[sudo] password for spence:
Reading package lists... Done
Building dependency tree
rtl8812au-dkms is already the newest version (4.3.8.12175.20140902+dfsg-0ubuntu2).
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
spence@antec ~ $ rfkill list
spence@antec ~ $ sudo lshw -C network
  *-network
       product: Ethernet Connection (2) I219-V
       vendor: Intel Corporation
       physical id: 1f.6
       bus info: pci@0000:00:1f.6
       logical name: enp0s31f6
       version: 00
       serial: 70:85:c2:29:10:c2
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.2-4 ip=192.168.1.23 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:132 memory:df100000-df11ffff
spence@antec ~ $ iwlist scan
enp0s31f6  Interface doesn't support scanning.
spence@antec ~ $ iwconfig
enp0s31f6  no wireless extensions.
« Last Edit: February 01, 2017, 01:41:10 pm by spence »
« Reply #4 on: February 01, 2017, 02:27:50 pm »
Is this new wireless adapter USB ?
« Reply #5 on: February 01, 2017, 02:34:15 pm »
Si SeƱor it is a wireless USB...
« Reply #6 on: February 01, 2017, 02:37:08 pm »
What's the output from:
lsusb?
« Reply #7 on: February 01, 2017, 02:39:46 pm »
lsusb ?
spence@antec ~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser
Bus 001 Device 003: ID 0bda:0811 Realtek Semiconductor Corp.
Bus 001 Device 005: ID 07cc:0501 Carry Computer Eng., Co., Ltd Mass Storage
« Reply #8 on: February 01, 2017, 03:02:15 pm »
Okay (with a wired connection) run these commands in sequence:
sudo apt-get remove --purge rtl8812au-dkmsthen just in case
sudo dkms remove -m 8812au -v 4.2.2 --allthen
sudo apt-get install build-essential dkms gitthen
mkdir ~/RTL8812AUthen
cd ~/RTL8812AUthen
git clone https://github.com/gnab/rtl8812au.gitthen
sudo cp -R rtl8812au /usr/src/8812au-4.2.2then
sudo dkms add -m 8812au -v 4.2.2then
sudo dkms build -m 8812au -v 4.2.2then
sudo dkms install -m 8812au -v 4.2.2then
sudo modprobe -r 8812authen
sudo modprobe 8812auIf wireless didn't spring to life, post the output from:
lsmod | grep 8812and
sudo dkms statusand
sudo lshw -C networkand
modinfo 8812au | grep -i version
On the off-chance they don't work, I think there's a more recent version here:
https://github.com/Grawp/rtl8812au_rtl8821au
and this link is here just for my possible future reference:
http://dustymabe.com/2016/01/24/802-11ac-on-linux-with-netgear-a6100-rtl8811au-usb-adapter/
and again JUST FOR REFERENCE, this command
sudo dkms remove -m 8812au -v 4.2.2 --allwill uninstall the 8812au-4.2.2 dkms driver you installed above .. but do not do this yet.
« Last Edit: August 02, 2017, 04:01:55 pm by PCNetSpec »
« Reply #9 on: February 01, 2017, 03:11:38 pm »
ran smoothly until:
spence@antec ~/RTL8812AU $ git clone https://github.com/gnab/rtl8812au.git
Cloning into 'rtl8812au'...
remote: Counting objects: 515, done.
remote: Total 515 (delta 0), reused 0 (delta 0), pack-reused 514
Receiving objects: 100% (515/515), 1.62 MiB | 1.40 MiB/s, done.
Resolving deltas: 100% (202/202), done.
Checking connectivity... done.
spence@antec ~/RTL8812AU $ sudo cp -R rtl8812au /usr/src/8812au-4.2.2
spence@antec ~/RTL8812AU $ sudo dkms add -m 8812au -v 4.2.2
Creating symlink /var/lib/dkms/8812au/4.2.2/source ->
DKMS: add completed.
spence@antec ~/RTL8812AU $ sudo dkms build -m 8812au -v 4.2.2
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area....
'make' all.........
DKMS: build completed.
spence@antec ~/RTL8812AU $ sudo dkms install -m 8812au -v 4.2.2
8812au:
Running module version sanity check.
Good news! Module version v4.2.2_7502.20130517 for 8812au.ko
exactly matches what is already found in kernel 4.4.0-59-generic.
DKMS will not replace this module.
You may override by specifying --force.
depmod....
DKMS: install completed.
spence@antec ~/RTL8812AU $ sudo modpobe -r 8812au
sudo: modpobe: command not found
spence@antec ~/RTL8812AU $ sudo modpobe 8812au
here's what you asked for:
spence@antec ~/RTL8812AU $ lsmod | grep 8812
spence@antec ~/RTL8812AU $ sudo dkms status
8812au, 4.2.2, 4.4.0-59-generic, x86_64: installed (WARNING! Diff between built and installed module!)
spence@antec ~/RTL8812AU $ sudo lshw -C network.
spence@antec ~/RTL8812AU $ modinfo 8812au | grep -i version
version:        v4.2.2_7502.20130517
srcversion:     86A0F0E9D0592F171DD97D4
vermagic:       4.4.0-59-generic SMP mod_unload modversions
parm:           rtw_chip_version:int
« Reply #10 on: February 01, 2017, 03:25:26 pm »
Sorry typos .. missed out an "r" in one command, and added an "." in another :-[ .. try
sudo dkms statusand
Also fixed in original instructions now.
« Last Edit: February 01, 2017, 03:31:14 pm by PCNetSpec »
« Reply #11 on: February 01, 2017, 03:39:16 pm »
my coffee deprived brain didn't catch the missspellinghk dahlinghk
spence@antec ~ $ sudo modprobe -r 8812au
spence@antec ~ $ sudo modprobe 8812au
spence@antec ~ $ lsmod | grep 8812
8812au                991232  0
spence@antec ~ $ sudo dkms status
  *-network
       physical id: 1f.6
       version: 00
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
  *-network
       physical id: 1
       bus info: usb@1:4
       logical name: enp0s20f0u4
       serial: 16:88:11:c3:6d:b9
       configuration: broadcast=yes driver=rtl8812au ip=192.168.1.8 multicast=yes wireless=IEEE 802.11bgn
spence@antec ~ $ modinfo 8812au | grep -i version
Wifi sprang to life after modprobes, but there's a warning in there, should we worry?
« Reply #12 on: February 01, 2017, 04:11:02 pm »
No, that warning shouldn't be a problem (although I'm not getting it).
Though I'm pretty sure you should have a later kernel than "59" .. I'm on "62" .. so you might want to run a FULL system update and reboot.
then post the output from:
sudo dkms statusagain.
« Last Edit: February 01, 2017, 04:15:32 pm by PCNetSpec »
« Reply #13 on: February 01, 2017, 04:27:56 pm »
spence@antec ~ $ sudo apt update
Hit:1 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Get:2 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [102 kB]
Get:3 http://security.ubuntu.com/ubuntu xenial-security InRelease [102 kB]
Hit:4 http://ppa.launchpad.net/peppermintos/p7-respin/ubuntu xenial InRelease
Hit:5 http://ppa.launchpad.net/peppermintos/p7-release/ubuntu xenial InRelease
Get:6 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [102 kB]
Hit:7 http://ppa.launchpad.net/saiarcot895/chromium-beta/ubuntu xenial InRelease
Fetched 306 kB in 0s (347 kB/s)
All packages are up to date.
spence@antec ~ $ sudo apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
spence@antec ~ $ sudo apt dist-upgrade
spence@antec ~ $ uname -a
Linux antec 4.4.0-59-generic #80-Ubuntu SMP Fri Jan 6 17:47:47 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Otherwise, all done...
« Last Edit: February 01, 2017, 05:13:30 pm by spence »
Re: new wifi usb drivers are... Realtek RTL8812AU chipset [SOLVED]
« Reply #14 on: February 02, 2017, 12:54:04 am »
Hi spence and PCNetSpec,
I too have only kernel 4.4.0-59 and find no mention of kernel 4.4.0-62 ... :-\ Not sure where PCNetSpec dug that one up ...
