Author Topic: 5 over 4 [wonderful]  (Read 2456 times)
Offline ronj1950
  • Peppermint version(s): Peppermint 5/32 bit
« on: June 24, 2014, 05:09:21 am »
Hello All you Peppermintors!
Peppermint 5 installed flawlessly over 4 on my Acer Aspire 1 [d257-1417].  Kept the dual boot with Windows 7 starter, however use Peppermint as primary OS.
Customizing it all now .. nice work to our developers.
And I did order the Stick to help support Peppermint, and an official backup for me as well.
Ron
« Last Edit: June 24, 2014, 05:27:57 am by ronj1950 »
rej
Re: 5 over 4
« Reply #1 on: June 24, 2014, 05:20:03 am »
Happy to hear it all went without a hitch .. and thanks for supporting Peppermint :)
Offline ronj1950
Re: 5 over 4 [wonderful]
« Reply #2 on: June 24, 2014, 05:27:18 am »
You bet.
rej
Offline starchase
  • New Forum User, Old Old Forum User
Re: 5 over 4 [wonderful], How is That Done?
« Reply #3 on: July 13, 2014, 08:19:28 am »
If you don't mind me asking how the OP installed P5 over P4, I have P4 on my wife's netbook.  While it is running fine it finds no updates to install.  I'm sure it will continue running for a long while now, but . . . .   I don't really want to put a  whole lot of work into removing the current installation with personalized settings and documents in order to install P5, but if P5 can be installed on top of P4 without a problem, then that is cool.  But if that is really risky, then that is another story.
Many Thanks.
John
Asus Eee PC 1025C, Intel Atom N2600 Dual Core 1.6GHz, 1GB DDR3, 320 GB HDD, Peppermint 9
Offline ronj1950
« Reply #4 on: July 13, 2014, 05:20:22 pm »
Hello John,
P5 will be a fresh install .. no more P4, so all your customized settings will need to be re-established with 5, documents saved in internal file system will be lost.  Since I use the cloud, no downloads nor files I needed to worry about.
Ironically I like 5 so much, with the 5 years support, I eventually elected to do an complete install on this netbook, over Windows 7 Starter, no more MS nor dual boot.  Part of the appeal is customizing it for my use, so a second re-install did not bother me.
All your settings and documents [not on cloud, such as Google Drive] will be lost, documents can be backed up and re-installed as you most likely know.
Ron
« Last Edit: July 13, 2014, 05:23:55 pm by ronj1950 »
rej
