Author Topic: Downgrading Chromium/Chrome to non-Aura versions (Peppermint 5)  (Read 9654 times)
As mentioned in the Peppermint 5 Release Notes:-
Quote from: Release Notes
The browsers Chromium and Chrome have recently moved to a new graphics engine called "Aura" that can cause some visual anomalies on the desktop when used in combination with certain hardware. Installing an earlier version of either Chromium or Chrome corrects this.
ONLY follow these instructions if you're getting weird graphics glitches in either of the Chromium or Chrome web browsers
Before we get to downgrading, there is an easier option that works for most people .. but you'll loose desktop effects such as drop shadows, transparency, and compositing .. but if you're OK with that, go to:-
menu > Preferences > Peppermint Control Center > Desktop Effects (tab)
and remove the tick from "Enable Desktop Effects" .. now restart Chromium/Chrome
If that didn't work, or you'd like to keep desktop effects, you'll need to downgrade Chromium and/or Chrome to non-Aura versions .. so re-enable desktop effects and read on...
In the following post I'll explain how to downgrade Chrome first as it's easier than the pre-installed Chromium .. then in the next posting I'll explain how to downgrade Chromium (further down the page).
« Last Edit: June 23, 2014, 07:23:09 pm by PCNetSpec »
Re: Downgrading Chromium/Chrome to non-Aura versions (Peppermint 5)
« Reply #1 on: June 23, 2014, 07:08:49 pm »
To downgrade the Chrome web browser -
Open a terminal (Ctrl+Alt+T) and run this command to remove any previously installed version of Chrome:
sudo apt-get remove --purge google-chrome*
(don't worry if that command fails, it just means you haven't already installed a previous version)
Now download ONE of these 2 files depending on whether you're running 32bit or 64bit Peppermint 5
32bit:
http://mirror.pcbeta.com/google/chrome/deb/pool/main/g/google-chrome-stable/google-chrome-stable_34.0.1847.137-1_i386.deb
64bit:
http://mirror.pcbeta.com/google/chrome/deb/pool/main/g/google-chrome-stable/google-chrome-stable_34.0.1847.137-1_amd64.deb
Once you have downloaded the file, double-click it to install, then click the "Install" button.
You'll then find Chrome in the menus at:-
menu > Internet > Google Chrome
Fire it up, and go to
chrome://version/
and make sure it says you're running version 34.0.1847.137
If it does .. run this command to stop the software updater from updating it in the future:
sudo echo "google-chrome-stable hold" | sudo dpkg --set-selections
To UNDO:-
Take the package off hold with:
sudo echo "google-chrome-stable install" | sudo dpkg --set-selections
now uninstall Chrome with:
sudo apt-get remove google-chrome*
then download Chrome from the official website:
http://www.google.com/chrome/browser/
and install it in the normal way
« Last Edit: June 27, 2014, 06:18:38 am by PCNetSpec »
« Reply #2 on: June 23, 2014, 07:09:28 pm »
To downgrade the installed Chromium web browser -
OK, I've created a PPA with the earlier non-aura version of Chromium (31) to ease installation as much as possible.
To install it you'll need to add the PPA, update the package cache,  install the older version, and rename your original chromium profile directory (as the old version cannot load the new profile).
Open a terminal (Ctrl+Alt+T) and run these commands in sequence:
sudo add-apt-repository ppa:mark-pcnetspec/chromium-31
sudo apt-get update
sudo apt-get install chromium-browser=31.0.1650.57-0ubuntu1 chromium-browser-l10n=31.0.1650.57-0ubuntu1 chromium-codecs-ffmpeg-extra=31.0.1650.57-0ubuntu1
Now MAKE SURE Chromium is CLOSED, and run:
mv -v ~/.config/chromium ~/.config/chromium-original
to rename the profile directory.
Finally make sure the pepperflash plugin is updated:
sudo update-pepperflashplugin-nonfree --install
Now fire up Chromium, and go to
chrome://version/
and make sure it says you're running version  31.0.1650.57
To UNDO:-
To go back to the default (with chromium closed) run:
sudo apt-get install ppa-purge
sudo apt-get update
sudo ppa-purge ppa:mark-pcnetspec/chromium-31
mv -v ~/.config/chromium ~/.config/chromium-31
mv -v ~/.config/chromium-original ~/.config/chromium
now fire up Chromium and check it's the latest version.
« Last Edit: December 28, 2014, 08:37:59 am by PCNetSpec »
