Author Topic: Installing pepperflash - flashplayer 24 - for Chromium 64bit (and now 32bit)  (Read 6217 times)
Offline rod_stone
  • Peppermint version(s): 7
My Chromium won't play it. Firefox, Chrome do.
So it wont even play it from this forum ?
can you go to
chrome:plugins
and take a screenshot of the flash section
then host it on say IMGUR
http://imgur.com
and post a link.
Also, make sure there's only ONE flash section.
Offline rod_stone
Adobe Flash Player - Версия: 24.0.0.221
Shockwave Flash 24.0 r0
Описание:   Shockwave Flash 24.0 r0
Версия:   24.0.0.221
Расположение:   /usr/lib/adobe-flashplugin/libpepflashplayer.so
Тип:   PPAPI (вне процесса)
    Отключить
Типы MIME:
Тип MIME   Описание   Расширения файлов
application/x-shockwave-flash   Shockwave Flash
.swf
application/futuresplash   FutureSplash Player
.spl
Отключить   Запускать всегда
Offline rod_stone
sorry this was a copied text from the plugin section. Imgur requires a sign up. How about a google drive link? Another problem is it is russified, since I'm Russian and all software is russified.
Okay, you're still using the wrong pepperflash
what's the output from:
dpkg -l | grep flash
ls -a /etc/chromium-browser/customizations
and the contents of
pluma /etc/chromium-browser/default
Offline rod_stone
renat@renat-Lenovo-G50-45 ~ $ dpkg -l | grep flash
ii  adobe-flash-properties-gtk                  1:20170214.1-0ubuntu0.16.04.1              amd64        GTK+ control panel for Adobe Flash Player plugin
ii  adobe-flashplugin                           1:20170214.1-0ubuntu0.16.04.1              amd64        Adobe Flash Player plugin
ii  browser-plugin-freshplayer-pepperflash      0.3.4-3ubuntu0.1                           amd64        PPAPI-host NPAPI-plugin adapter for pepperflash
ii  bunsen-pepperflash                          8.0-1+peppermint1                          amd64        Pepper Flash Player - browser plugin
# Default settings for chromium-browser. This file is sourced by /bin/sh from
# /usr/bin/chromium-browser
# Options to pass to chromium-browser
CHROMIUM_FLAGS=""
« Last Edit: March 16, 2017, 10:37:52 am by AndyInMokum, Reason: Encapsulating output with [code]. »
Offline rod_stone
how do I install the right pepperflash?
It shouldn't. Click the green drop-down that says New post and then Upload images.
Offline rod_stone
Offline rod_stone
So is there a way for me to install the right version of pepperflash?
Run:
sudo apt-get remove --purge adobe-flashplugin adobe-flash-properties-gtk
sudo apt-get install --reinstall browser-plugin-freshplayer-pepperflash bunsen-pepperflash
then close ALL web browser instances
reopen Chromium
then post a screenshot of
chrome:plugins
again
Offline rod_stone
Offline rod_stone
Flash updated to 25.0.0.127, still it won't play that darn video. Or this http://www.currenttime.tv/a/manhoffarchive-stalin/28359843.html
Firefox plays it just fine.  If I remove and reinstall chromium, would that help the problem?
« Last Edit: March 17, 2017, 01:23:27 am by rod_stone »
Hi rod_stone, here's tip you may find useful.  When you post an image from imgur.  You can have it display directly in the forum, rather than linking it to another page.  To do this, first open imgur and select the image you want to use.  In the right hand column, there are a select of links for different usages.  Select the: BBCode (message boards & forums) link and select: Copy.  As an example, the relevant link is highlighted in green in the image below.
Click on Image to Enlarge
Paste the link you've just copied to the forum.  You can encapsulate link with the Centered function if you want.  Check how it'll look by using the: Preview button that's next to the: Post button.  I hope you find this useful  ;).
Okay, it's not a problem with the flashplayer itself because Chrome and Firefox will now be using the same one.
So try this .. in Chromium go to
chrome:settings
Scroll to the bottom and click "show advanced settings"
Now add/remove the tick from "use hardware acceleration when available"
Then restart Chromium.
Does that make any difference ?
If not, do you have any plugins installed in Chromium ?
