Author Topic: Installing pepperflash - flashplayer 24 - for Chromium 64bit (and now 32bit)  (Read 7635 times)
NO LONGER NECESSARY .. instead install adobe-flashplugin which contains both pepperflash and flashplayer .. see here:
https://forum.peppermintos.com/index.php/topic,4802.msg53995.html#msg53995
for instructions
[END EDIT]
sudo apt-get remove --purge pepperflashplugin-nonfreethen
sudo mkdir -p /usr/lib/adobe-pepflashpluginthen
cd /usr/lib/adobe-pepflashpluginthen
sudo wget --no-check-certificate https://fpdownload.macromedia.com/pub/labs/flashruntimes/flashplayer/linux64/flash_player_ppapi_linux.x86_64.tar.gzthen
sudo tar xvf flash_player_ppapi_linux.x86_64.tar.gzthen
sudo pluma /etc/chromium-browser/customizations/01-adobe-pepflashpluginand make it read:-
flashso="/usr/lib/adobe-pepflashplugin/libpepflashplayer.so"
flashjson="/usr/lib/adobe-pepflashplugin/manifest.json"
CHROMIUM_FLAGS="$CHROMIUM_FLAGS --ppapi-flash-path=$flashso --ppapi-flash-version=$(grep version $flashjson | sed 's|.*"version": ||;s|"||g;s|,||')"
SAVE that file, and exit pluma.
Now close ALL running instances of Chromium .. reopen Chromium, and go to:-
chrome://plugins
it should show you're running:-
Adobe Flash Player - Version: 24.0.0.xxx
Shockwave Flash 24.0 r0
    Description:       Shockwave Flash 24.0 r0
    Version:             24.0.0.xxx
    Location:            /usr/lib/adobe-pepflashplugin/libpepflashplayer.so
To UNDO
Open a terminal and run:
sudo rm -v /etc/chromium-browser/customizations/01-adobe-pepflashpluginthen
sudo rm -rv /usr/lib/adobe-pepflashpluginthen restart Chromium
« Last Edit: April 09, 2017, 08:08:16 am by PCNetSpec »
Offline rod_stone
  • Peppermint version(s): 7
Re: Installing pepperflash - flashplayer 24 - for Chromium 64bit
« Reply #1 on: March 14, 2017, 06:30:17 am »
Will this procedure mess up the flash plugin for Chrome if you want to use both Chromium and Chrome?
NO it won't interfere with Chrome's pepperflash, but the procedure above is now outdated.
The instruction below should now also work for 32bit Chromium too.
The best way to get pepperflash for Chromium now would be to run these commands in sequence
sudo apt-get remove --purge pepperflashplugin-nonfree  flashplugin-installerthen
sudo add-apt-repository ppa:peppermintos/p7-pepperflashthen
sudo apt-get updatethen
sudo apt-get install browser-plugin-freshplayer-pepperflash bunsen-pepperflash Now close ALL Chromium browser instances and reopen one.
Now go here:
http://www.adobe.com/products/flash/about/
or here:
https://helpx.adobe.com/flash-player.html
and check it says:-
You have version 24,0,0,221 installed
You MAY have to go here in Chromium:
chrome://plugins/
and make sure there's a tick in the "Always allowed to run" box:-
« Last Edit: March 14, 2017, 07:13:19 am by PCNetSpec »
Offline rod_stone
Thank you very much! It works! BTW, the reason I have installed Chromium is because Chrome of late is functioning a little funny with Facebook : when clicking  on a new post window, it will crowd up the space for the new message by different add-on buttons - photos, emoticons, etc. I notice Firefox does not have this glitch, but I am so accustomed to Chrome, so decided to try out Chromium...
« Last Edit: March 14, 2017, 10:42:20 am by rod_stone »
You're most welcome :)
Offline rod_stone
still I have noticed Chromium won't play some videos on vimeo and some other flash vids, while Firefox has no problem.  What can be done about that?
can you give us some examples ?
Offline rod_stone
What do you mean? do I supply a screenshot of a looping video?
Offline rod_stone
also, I'm not receiving email notifications of the posts, comments that I'm following. How come? How should I fix it?
How about a link to a video you can't play?
Offline rod_stone
Either click the "NOTIFY" button at the top of individual topics you want to receive notifications for.
or
Go to your Forum Profile, select "Notifications" on the left, and tick the box entitled "Turn notification on when you post or reply to a topic"
Offline rod_stone
OK, done that. Thanks!
That vimeo video is working for me in Chromium :-\ .. is it working for anyone else ?
(audio is naff on it, right up until the crowd applauds at the end .. but that's obviously not a Chromium problem)
« Last Edit: March 16, 2017, 06:25:32 am by PCNetSpec »
I tried it in Firefox first, where I had to enable javascript a couple of times before it played.
In Chromium it just works for me.
