Author Topic: Installing pepperflash - flashplayer 24 - for Chromium 32bit  (Read 1277 times)
« on: January 03, 2017, 07:50:57 am »
NO LONGER NECESSARY .. instead install adobe-flashplugin which contains both pepperflash and flashplayer .. see here:
https://forum.peppermintos.com/index.php/topic,4802.msg53995.html#msg53995
for instructions
[END EDIT]
The following instructions are for 32bit Peppermint ONLY .. this pepperflash version will NOT work in 64bit Chromium.
If you're running 64bit Peppermint, use the instructions at the following link instead:-
https://forum.peppermintos.com/index.php/topic,4893.0.html
sudo apt-get remove --purge pepperflashplugin-nonfreethen
sudo mkdir -p /usr/lib/adobe-pepflashpluginthen
cd /usr/lib/adobe-pepflashpluginthen
sudo wget --no-check-certificate https://fpdownload.macromedia.com/pub/labs/flashruntimes/flashplayer/linux32/flash_player_ppapi_linux.i386.tar.gzthen
sudo tar xvf flash_player_ppapi_linux.i386.tar.gzthen
sudo pluma /etc/chromium-browser/customizations/01-adobe-pepflashpluginand when a BLANK file opens, make it read:-
flashso="/usr/lib/adobe-pepflashplugin/libpepflashplayer.so"
flashjson="/usr/lib/adobe-pepflashplugin/manifest.json"
CHROMIUM_FLAGS="$CHROMIUM_FLAGS --ppapi-flash-path=$flashso --ppapi-flash-version=$(grep version $flashjson | sed 's|.*"version": ||;s|"||g;s|,||')"
SAVE that file, and exit pluma.
Now close ALL running instances of Chromium .. reopen Chromium, and go to:-
chrome://plugins
it should show you're running:-
Adobe Flash Player - Version: 24.0.0.xxx
Shockwave Flash 24.0 r0
    Description:       Shockwave Flash 24.0 r0
    Version:             24.0.0.xxx
    Location:            /usr/lib/adobe-pepflashplugin/libpepflashplayer.so
To UNDO
Open a terminal and run:
sudo rm -v /etc/chromium-browser/customizations/01-adobe-pepflashpluginthen
sudo rm -rv /usr/lib/adobe-pepflashpluginthen restart Chromium
« Last Edit: April 09, 2017, 08:08:43 am by PCNetSpec »
