Author Topic: ot: USA: Cox Email Servers? DFEOJM?  (Read 2872 times)
« on: December 07, 2016, 01:28:14 pm »
After migrating all of my usual email contacts to use @cox.net email for me instead of @live.com... I'm having trouble downloading any e'mail (pop3 nor imap arrive) from Cox... anybody else west of the Mississippi also having trouble of late. Cox used to have separate settings for folks east or west of the Mississippi... so ...
Re: ot: USA: Cox Email Servers? DFEOJM?
« Reply #1 on: December 07, 2016, 02:56:02 pm »
I'm west of the Mississippi .. a l-o-n-g l--o--n--g way west though.
In fact unless you're swimming in the Mississippi.....
« Reply #2 on: December 07, 2016, 05:54:26 pm »
there doesn't appear to be an emoji for smacking down nor pummeling...
« Reply #3 on: December 07, 2016, 05:57:38 pm »
Can anyone check out the servers at imap.cox.net?
« Reply #4 on: December 08, 2016, 01:55:52 pm »
Well it's responding to a ping
ping -c 5 imap.cox.net
PING imap.cox.net (146.20.147.247) 56(84) bytes of data.
64 bytes from 146.20.147.247: icmp_seq=2 ttl=46 time=117 ms
64 bytes from 146.20.147.247: icmp_seq=3 ttl=46 time=96.0 ms
64 bytes from 146.20.147.247: icmp_seq=4 ttl=46 time=94.1 ms
64 bytes from 146.20.147.247: icmp_seq=5 ttl=46 time=92.7 ms
--- imap.cox.net ping statistics ---
5 packets transmitted, 4 received, 20% packet loss, time 4011ms
rtt min/avg/max/mdev = 92.740/100.122/117.574/10.145 ms
but repeated runs shows the return times are unstable (varying wildly), and about 50% of the time there is packet loss (as seen above).
Dunno if that means much from the UK though.
« Reply #5 on: December 08, 2016, 04:00:44 pm »
forgot about that... ::)
spence@Dell-DM061 ~ $ ping -c 5 imap.cox.net
64 bytes from 146.20.147.247: icmp_seq=1 ttl=57 time=79.1 ms
64 bytes from 146.20.147.247: icmp_seq=2 ttl=57 time=83.3 ms
64 bytes from 146.20.147.247: icmp_seq=3 ttl=57 time=71.8 ms
64 bytes from 146.20.147.247: icmp_seq=4 ttl=57 time=75.8 ms
64 bytes from 146.20.147.247: icmp_seq=5 ttl=57 time=73.3 ms
5 packets transmitted, 5 received, 0% packet loss, time 4003ms
rtt min/avg/max/mdev = 71.862/76.724/83.378/4.147 ms
64 bytes from 146.20.147.247: icmp_seq=1 ttl=57 time=82.2 ms
64 bytes from 146.20.147.247: icmp_seq=2 ttl=57 time=72.1 ms
64 bytes from 146.20.147.247: icmp_seq=3 ttl=57 time=76.6 ms
64 bytes from 146.20.147.247: icmp_seq=5 ttl=57 time=72.8 ms
5 packets transmitted, 4 received, 20% packet loss, time 4003ms
rtt min/avg/max/mdev = 72.194/75.994/82.243/3.984 ms
spence@Dell-DM061 ~ $ ping -c 5 pop.cox.net
PING pop.cox.net (146.20.147.245) 56(84) bytes of data.
64 bytes from 146.20.147.245: icmp_seq=1 ttl=57 time=72.5 ms
64 bytes from 146.20.147.245: icmp_seq=2 ttl=57 time=72.3 ms
64 bytes from 146.20.147.245: icmp_seq=3 ttl=57 time=73.9 ms
64 bytes from 146.20.147.245: icmp_seq=4 ttl=57 time=74.9 ms
64 bytes from 146.20.147.245: icmp_seq=5 ttl=57 time=73.6 ms
--- pop.cox.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4004ms
rtt min/avg/max/mdev = 72.365/73.516/74.966/1.001 ms
« Reply #6 on: December 08, 2016, 04:06:19 pm »
Meanwhile downforeveryoneorjustme.com/imap.cox.net says:
It's not just you! http://imap.cox.net looks down from here.
« Reply #7 on: December 08, 2016, 04:26:44 pm »
Hello spence,
We need VinDSL to see this thread.  Yeah, it's down for me too, but, then again, I'm east of the Mississippi also --but further west than PCNetSpec!  ;D
But, seriously, let's hope VinDSL sees this thread.  ;)
PS
I've dealt with Cox before --in San Diego.  I have mixed feeling about the company, but the company seemed to me to be overextended.  :-\  But according to Is It Down Right Now? --yeah, it's down.  :(
« Reply #8 on: December 08, 2016, 04:41:24 pm »
that doesn't tell you anything ... the imap.cox.net mail servers won't be using http (it's not a website) so they will appear "down" to that site .. they are using imap.
That site also reports imap.gmail.com and pop.gmail.com are "down", but they aren't.
That site is just reporting that they didn't respond to an "http" request .. imap and pop3 mail servers won't ;)
(you'd get a similar response from me if you gave me a shout in swahili)
See if you can telnet in
telnet imap.cox.net 993then
LOGIN username@cox.net your_passwordI seriously doubt if you'll get in, but it should give you an idea if the imap server is up.
(the above could be completely wrong .. it's been years since I "telnetted" into mail servers)
« Last Edit: December 08, 2016, 05:09:08 pm by PCNetSpec »
« Reply #9 on: December 08, 2016, 05:01:35 pm »
Thanks, PCNetSpec, and, now, I don't know if VinDSL will be able out to help with this particular issue either.  From what I'm gathering Cox Communications is spread throughout different metropolitan regions of the country.  I'm not sure if Arizona is even in a part of that mix.  Apparently Cox sold off some of its holdings in parts of California too.  Cox Communications is a bit of a hodgepodge on the map.
« Reply #10 on: December 27, 2016, 10:01:09 am »
Cox is indeed part of the mix in Arizona, so much so that its the only option available for internet in large swaths of the state, aside from pricey, sketchy & slower satelite providers. AZ telephone companies seem to have ditched all internet providing options. Cox is the only provider in my neighborhood.  Century Link creeps closer & closer, but their speeds are much slower.  USA needs to get rid of the ISP hegemony....
