Author Topic: ANNOUNCEMENT - Peppermint 7 Respin Released.  (Read 6995 times)
Offline berliner58
Re: ANNOUNCEMENT - Peppermint 7 Respin Released.
« Reply #30 on: December 04, 2016, 06:09:50 am »
Wonderful.
Works perfectly.
Thank you very much, PCNetSpec.
I don't use the new wallpaper though because at the moment I like my own wallpaper better.
Just in case somebody likes it.
I found it here:
http://wallpaperswide.com/lakes-desktop-wallpapers.html
« Last Edit: December 04, 2016, 06:27:29 am by berliner58 »
P8 x64 Desktop Dual core Pentium E5400 (-MCP-) RAM: 8GB
« Reply #31 on: December 04, 2016, 06:13:48 am »
You're most welcome :)
Offline Bigoeuf
« Reply #32 on: December 04, 2016, 11:27:34 am »
Good evening Mark - like the new wallpaper in the respin so went to install it as per your instructions:
If you also want the new wallpaper, open a terminal and run these 2 commands in sequence:
cd /usr/share/peppermint/wallpapersthen
sudo wget https://dl.dropboxusercontent.com/u/31525164/Peppermint_Sunset-(image_by_Ray_Bilcliff).jpgthen right-click on your desktop and select "Change Desktop Background", and select "Peppermint_Sunset-(image_by_Ray_Bilcliff).jpg"
Gives me this:
mick@mick-Inspiron-1501 /usr/share/peppermint/wallpapers $ sudo wget https://dl.dropboxusercontent.com/u/31525164/Peppermint_Sunset-(image_by_Ray_Bilcliff).jpg
bash: syntax error near unexpected token `('
Any ideas why Mark?  ???
« Reply #33 on: December 04, 2016, 11:58:16 am »
Yeah sorry, my fault .. run:
sudo wget "https://dl.dropboxusercontent.com/u/31525164/Peppermint_Sunset-(image_by_Ray_Bilcliff).jpg"(also fixed in earlier posting)
Offline cost
  • Supersonic
« Reply #34 on: December 15, 2016, 11:58:52 am »
Great job, love the new splash screen and nice wallpaper. Wish  to see some wallpapers with Peppermint brand logo on next versions :P
