Author Topic: Wacom/Graphics Tablet settings menu on Peppermint  (Read 3663 times)
Offline patrick_os
  • Peppermint version(s): Peppermint OS 9 (64-bit)
« on: November 23, 2016, 02:43:20 am »
Hello everyone!
I want to configure my Wacom graphic tablet on Peppermint just like when I was in Linux Mint. On Mint and Ubuntu there is a menu called Graphics tablet, where we can change the pressure sensitivity and the buttons. But in Peppermint I can't do that. Can this be integrated into the system?  :)
Here is the menu:
Sorry if my english is not very well, I am not a native english speaker.
Thanks a lot
Re: Wacom/Graphics Tablet settings menu on Peppermint
« Reply #1 on: November 23, 2016, 04:23:41 am »
See if this works...
(I haven't got a wacom tablet, so can't test it myself)
FIRST download this file:
http://launchpadlibrarian.net/109052632/python-support_1.0.15_all.deb
and double-click it to install.
Then download this file:
https://launchpad.net/~hughescih/+archive/ppa/+files/wacom-utility_1.21-3_all.deb
Then open a terminal and run:
sudo pluma /usr/share/applications/wacom-utility.desktopand make it read:-
#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Encoding=UTF-8
Name=Wacom Control Panel
Type=Application
Exec=python /usr/share/wacom-utility/wacom_utility.py
Terminal=false
Icon=/usr/share/wacom-utility/images/generic.png
Comment=Utility to configure wacom pen tablets
Categories=GTK;Settings;HardwareSettings;GNOME;
OnlyShowIn=LXDE;Settings;GNOME;
Hidden=false
Name[en_CA]=Wacom Control Panel
Comment[en_CA]=Utility to configure wacom pen tablets
X-GNOME-Autostart-enabled=false
SAVE the file and exit gedit.
Now (with your wacom tablet attached) go to:-
menu > Preferences > Wacom Control Panel
and see if it works ?
Offline patrick_os
« Reply #2 on: November 23, 2016, 09:26:16 am »
[Desktop Entry]
Version=1.0
Encoding=UTF-8
Type=Application
Terminal=false
Hidden=false
It opens but don't detect the wacom tablet
« Reply #3 on: November 23, 2016, 09:30:38 am »
Okay remove em then:
sudo apt-get remove --purge wacom-utility python-supportand I'll see if I can figure this out
https://github.com/Zeioth/XFCE-Wacom-Settings
Offline patrick_os
« Reply #4 on: November 23, 2016, 02:31:31 pm »
Okay I removed it.
Thanks I'll be waiting.
Offline patrick_os
« Reply #5 on: November 24, 2016, 09:18:42 am »
Sorry, did you succeed?
« Reply #6 on: November 24, 2016, 02:59:46 pm »
Not yet my mate, but then I'm pretty busy getting the Peppermint 7 respin ready .. I'll get to it as soon as I have time but you'll have to bear with me a bit.
Offline patrick_os
« Reply #7 on: December 01, 2016, 04:03:58 pm »
Hi my friend,
Can I help you in any way? I would really appreciate this function to be available in LXDE. I have a friend that needs this function too, because we want to use LXDE to have more memory available. And Peppermint is a distro that I am enjoying very much.
Offline patrick_os
« Reply #8 on: December 10, 2016, 03:10:20 am »
Regards
Is there any news?
« Reply #9 on: December 11, 2016, 02:04:01 pm »
I keep getting
** (gnome-control-center:2910): WARNING **: Could not find settings panel "wacom"
and haven't found a way around it yet ???
I'll have another crack at it tomorrow because I've just noticed the gsettings key in the install script is wrong .. dunno if putting that right will make a difference though because I already tried manually activating the key and it made no difference.
What I really need to do is look at Ubuntu Gnome and see how it all plugs together in that .. erm, so I will ::)
« Last Edit: December 11, 2016, 03:00:51 pm by PCNetSpec »
Offline patrick_os
« Reply #10 on: August 17, 2017, 07:00:29 pm »
Hello, have you found any solution? Thanks
