Author Topic: STEAM not working on a new device [SOLVED]  (Read 727 times)
Offline JimmyTango
  • Peppermint version(s): 7
« on: November 06, 2016, 11:36:14 am »
Hello, gents! Installed steam on new device and it just doesn't work. Clicking on the steam icon in the Menu does nothing. duh.
I've installed Steam with "sudo apt-get install steam". Reinstalling didn't do anything.
Running Steam through terminal gives this message:
Running Steam on peppermint 7 64-bit
STEAM_RUNTIME is enabled automatically
[2016-11-06 21:35:24] Startup - updater built Oct 13 2016 00:47:16
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
System:    Host: ostapenko-System-Product-Name Kernel: 4.4.0-45-generic x86_64 (64 bit)
Machine:   Mobo: ASUSTeK model: P6TD DELUXE v: Rev 1.xx
           Bios: American Megatrends v: 0303 date: 12/30/2009
CPU:       Quad core Intel Core i7 930 (-HT-MCP-) cache: 8192 KB
           clock speeds: max: 2801 MHz 1: 1600 MHz 2: 1600 MHz 3: 1600 MHz
           4: 1600 MHz 5: 1600 MHz 6: 1600 MHz 7: 1733 MHz 8: 1600 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Juniper XT [Radeon HD 5770]
           Display Server: X.Org 1.18.4 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Gallium 0.4 on AMD JUNIPER (DRM 2.43.0, LLVM 3.8.0)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Juniper HDMI Audio [Radeon HD 5700 Series]
           Card-2 Intel 82801JI (ICH10 Family) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-45-generic
Network:   Card-1: Marvell 88E8056 PCI-E Gigabit Ethernet Controller
           driver: sky2
           IF: enp4s0 state: down mac: <filter>
           Card-2: D-Link System RTL8139 Ethernet driver: 8139too
           IF: enp7s1 state: unknown speed: 100 Mbps duplex: full
           mac: <filter>
Drives:    HDD Total Size: 1250.3GB (60.4% used)
           ID-1: /dev/sda model: ST3250820AS size: 250.1GB
           ID-2: /dev/sdb model: WDC_WD10EARS size: 1000.2GB
Partition: ID-1: / size: 87G used: 7.6G (10%) fs: ext4 dev: /dev/sdb5
           ID-2: swap-1 size: 6.43GB used: 0.00GB (0%) fs: swap dev: /dev/sdb6
Sensors:   System Temperatures: cpu: 43.0C mobo: 40.0C gpu: 44.0
           Fan Speeds (in rpm): cpu: 2220 psu: 0 sys-1: 0 sys-2: 4326 sys-3: 0
Info:      Processes: 294 Uptime: 10:10 Memory: 995.4/5957.6MB
« Last Edit: November 06, 2016, 11:52:02 am by JimmyTango »
« Reply #1 on: November 06, 2016, 11:36:14 am »
Note - Please rest assured there is nothing in the output from that command that could be construed as a 'security risk', the '-z' option makes sure of that by filtering out your MAC address.
If you're not sure how to run the above command or how to post the output back here, please see the video tutorial at the link below:
https://forum.peppermintos.com/index.php/topic,4546.0.html
Offline JimmyTango
Re: STEAM not working on a new device
« Reply #3 on: November 06, 2016, 11:51:27 am »
Bingo!  :D
Re: STEAM not working on a new device [SOLVED]
« Reply #4 on: November 06, 2016, 11:56:15 am »
Always a winning game with Peppermint  8)
Enjoy your gaming
