Author Topic: Does Peppermint OS have an equalizer? (Solved)  (Read 3159 times)
Offline _tuter
  • 18 yrs old - Distro Hopper - Peppermint Lover
  • Peppermint version(s): Peppermint OS 6!!
« on: June 15, 2014, 10:38:12 am »
Just wondering if Pep OS has a built in equalizer?? If not can i get one from the software center?
« Last Edit: June 15, 2014, 05:12:49 pm by _tuter »
:) _tuter :)
Re: Does Peppermint OS have an equalizer?
« Reply #1 on: June 15, 2014, 02:53:11 pm »
Which version of Peppermint ?
Offline _tuter
« Reply #2 on: June 15, 2014, 03:31:44 pm »
Pep OS 4 :D!!
:) _tuter :)
« Reply #3 on: June 15, 2014, 03:40:44 pm »
Make sure you have pulseaudio installed:
sudo apt-get install pulseaudio pulseaudio-utils pavucontrolthen download this .deb:
https://launchpad.net/~nilarimogard/+archive/webupd8/+files/pulseaudio-equalizer_2.7.0.2-3%7Ewebupd8%7Eraring_all.deb
and  double-click it to install.
Once installed, you should find a system wide Equalizer at
menu > Sound & Video > PulseAudio Equalizer
When that opens, make sure you tick the "EQ Enabled" box.
Offline _tuter
Re: Does Peppermint OS have an equalizer? (Solved)
« Reply #4 on: June 15, 2014, 05:13:23 pm »
Thanks!!! That's perfect,
_tuter
:) _tuter :)
« Reply #5 on: June 16, 2014, 01:34:37 am »
You're welcome .. thanks for marking the topic solved :)
