Author Topic: How to install PM7 Theme/Icon/Wallpaper on PM6  (Read 1890 times)
Offline rajeev2631007
« on: October 24, 2016, 01:58:28 am »
I want to know how to install PM7 Themes/Icon/Wallpaper on PM6.I request you please share details.
Rajeev Gautam
Re: How to install PM7 Theme/Icon/Wallpaper on PM6
« Reply #1 on: October 24, 2016, 10:25:17 am »
Okay, well I can't guarantee how the gtk themes will look in Peppermint 6 because they were designed for gtk 3.18 .. but you can certainly install them and take a look.
(icon and wallpapers should be fine)
To install (from my dropbox) , run these commands in sequence
cd /usr/share/icons
sudo wget https://dl.dropboxusercontent.com/u/31525164/pm7-icons.tar.gz
sudo tar xvf pm7-icons.tar.gz
sudo rm -v pm7-icons.tar.gz
okay that's the icons done
Now for the wallpapers
cd /usr/share/peppermint/wallpapers
sudo wget https://dl.dropboxusercontent.com/u/31525164/pm7-wallpapers.tar.gz
sudo tar xvf pm7-wallpapers.tar.gz
sudo rm -v pm7-wallpapers.tar.gz
that's the wallpapers done
Now for the themes
cd /usr/share/themes
sudo wget https://dl.dropboxusercontent.com/u/31525164/pm7-themes.tar.gz
sudo tar xvf pm7-themes.tar.gz
sudo rm -v pm7-themes.tar.gz
that's the themes done.
Now just apply them in the normal way .. but bear in mind that the gtk themes may or may not look right in Peppermint 6
Offline GNULINUX
« Reply #2 on: October 24, 2016, 05:31:22 pm »
Icons and wallpapers are working without a problem!
The themes are working and are nice but give colored (red in this case) dotted lines all over the place...  ::)
Screenshot of different windows and the right click menu:
Greets!  ;)
« Reply #3 on: October 24, 2016, 06:51:36 pm »
Yeah I kinda figured they wouldn't work properly with gtk < 3.18
Sorry but there's nothing I can do about that :( .. you'll have to find a dark theme that works in 14.04, but the Peppermix-Dark-7 xfwm Window Manager Theme should still work.
Peppermint Control Center > Window Manager (tab) > Theme > Peppermix-Dark-7
« Last Edit: October 24, 2016, 06:56:14 pm by PCNetSpec »
« Reply #4 on: October 25, 2016, 12:20:37 am »
Hi PCNetSpecs and GNULINUX  thanks for your help and guidance.  I'll see how it will work for me.
Rajeev Gautam
Offline GNULINUX
« Reply #5 on: October 25, 2016, 04:07:24 am »
No problem, was just testing so other members/readers would see what they could expect!  ;)
Screenshot with Peppermix-Dark-7 xfwm Window Manager on std Peppermint 6:
Greets!  ;)
