Author Topic: Changing whisker menu font size ? [SOLVED]  (Read 2345 times)
Offline armageddon51
  • Peppermint version(s): 6
« on: October 16, 2016, 02:50:56 pm »
Is there an easy way to change the whisker menu font size ? It seems to follow the type of font selected but not its font size.  The desktop and nemo have a different size ratio.
I only found the icons sizing.
« Last Edit: October 17, 2016, 11:04:41 am by armageddon51 »
« Reply #1 on: October 16, 2016, 02:50:56 pm »
then copy what was returned in the terminal and post it back here.
Re: Changing whisker menu font size ?
« Reply #2 on: October 17, 2016, 06:58:39 am »
The whiskermenu (and panel)  follows the default system font set in:-
menu > Preferences > Customise Look and Feel > Widget (tab)
And next time can you please not ignore the autoresponse .. TIA.
« Last Edit: October 17, 2016, 07:00:20 am by PCNetSpec »
« Reply #3 on: October 17, 2016, 10:07:13 am »
Hi PcNetSpec, yes I know the font selection, type and size but I think I formulate my question the wrong way. Nemo and the desktop icons do not follow that setup exactly. It seems to take the font type but only indirectly the size. I would like to have the same font size applied to both whisker and Nemo (menus). Right now, if I set the desktop text size to my liking, the whisker menu text is too small.  Is there a way to have them identical ?
As for my hardware signature, I already provide it two posts down but fair enough, here it is again.
System:    Host: Pep7-IL9-Pro Kernel: 4.4.0-43-generic x86_64 (64 bit)
Machine:   Mobo: www.abit.com.tw model: IL9 Pro v: 1.X
           Bios: American Megatrends v: 080012 date: 09/17/2007
CPU:       Dual core Intel Pentium D (-MCP-) cache: 2048 KB
           clock speeds: max: 3391 MHz 1: 3391 MHz 2: 3391 MHz
Graphics:  Card: NVIDIA G73 [GeForce 7300 GT]
           Display Server: X.Org 1.18.4 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1368x768@60.00hz
           GLX Renderer: GeForce 7300 GT/PCIe/SSE2
           GLX Version: 2.1.2 NVIDIA 304.131
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-43-generic
Network:   Card: Realtek RTL-8110SC/8169SC Gigabit Ethernet driver: r8169
           IF: enp2s5 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 360.1GB (22.3% used)
           ID-1: /dev/sda model: ST3160815A size: 160.0GB
           ID-2: /dev/sdb model: ST3200820AS size: 200.0GB
Partition: ID-1: / size: 29G used: 7.3G (27%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 183 Uptime: 4 min Memory: 428.8/1999.8MB
« Last Edit: October 17, 2016, 10:13:57 am by PCNetSpec »
« Reply #4 on: October 17, 2016, 10:19:34 am »
Okay, to change the nemo font (including desktop)
Go to:
menu > System  Tools > dconf Editor
In the left hand pane of dconf-editor, navigate to
org > nemo > desktop
In the right hand pane of dconf editor, select "font" (under the "value" column).. now enter say:
Ubuntu 15
and hit enter to set it.
Doesn't have to be 15 (or indeed Ubuntu) .. set whatever font/size you want.
Clearing "font" will set it back to default .. as will highlighting "font" and clicking the "Default" button.
« Last Edit: October 17, 2016, 10:23:14 am by PCNetSpec »
« Reply #5 on: October 17, 2016, 10:57:53 am »
Ok didn't know that one. I did some more testing on a VirtualBox Pep 7 installation on another machine and yes the font type and size is applied everywhere in sync. So I switch from my Nvidia 304 driver and return to the nouveau driver. That cured it. Everything has the same font and size. So it seems to be related to that Nvidia driver. The whisker menu font is a couple of points smaller then the desktop. Go figure ? So I am keeping the nouveau driver then.
Thanks  :D
« Reply #6 on: October 17, 2016, 11:01:49 am »
No problem armageddon51  .. if you're happy with the solution, can you please remember to mark the topic (SOLVED) .. TIA :)
« Reply #7 on: October 17, 2016, 11:05:35 am »
Hi
also a remark regarding the request for specification information on "New Threads"
We cannot possibly remember when and where each forum member last posted their system configuraton.   It's quick and easy to provide and could mean you getting an answer quicker, rather than waiting around for someone to ask for it again .
Thanks and Regards Zeb...
Re: Changing whisker menu font size ? [SOLVED]
« Reply #8 on: October 17, 2016, 11:29:11 am »
Hi armgeddon51,
Just to add to the posting by zebedeeboss:
We also do not know if you have more than one computer, and if so then which one is having which problem.  ;)
But it is great that you found a solution.  :) NVidia drivers are always a bit mysterious as they are not open source.
