Author Topic: Resetting video driver nouveau [solved]  (Read 1314 times)
Offline armageddon51
  • Peppermint version(s): 6
« on: October 16, 2016, 09:25:29 am »
I spent a few hours installing Pep7 on an older PentiumD computer and everything went fine. I have a weird monitor (Acer x193w) with a resolution of 1440x900. I have dual boot with windows and windows can't even get me that resolution, only 1366x768 but Pep7 can with the nouveau driver. Anyway I install a bunch of programs without issue but after rebooting now the resolution is stuck at 1024x768, no more. I tried the Nvidia driver (304.131) suggested and this one get me 1366x768 like in windows. I don't why I lost the proper resolution on my monitor.
Is there a way to restore it ? I found this command  "sudo dpkg-reconfigure xserver-xorg" but it doesn't do anything.
TX
Abit IL9
Nvidia 7300GT
Pentium D
« Last Edit: October 16, 2016, 11:51:59 am by armageddon51 »
« Reply #1 on: October 16, 2016, 09:25:29 am »
Re: Resetting video driver nouveau
« Reply #2 on: October 16, 2016, 09:50:36 am »
Ok forgot here it is :
System:    Host: Pep7-IL9-Pro Kernel: 4.4.0-43-generic x86_64 (64 bit)
Machine:   Mobo: www.abit.com.tw model: IL9 Pro v: 1.X
           Bios: American Megatrends v: 080012 date: 09/17/2007
CPU:       Dual core Intel Pentium D (-MCP-) cache: 2048 KB
           clock speeds: max: 3391 MHz 1: 3391 MHz 2: 3391 MHz
Graphics:  Card: NVIDIA G73 [GeForce 7300 GT]
           Display Server: X.Org 1.18.4 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1024x768@60.00hz, 1368x768@60.00hz
           GLX Renderer: GeForce 7300 GT/PCIe/SSE2
           GLX Version: 2.1.2 NVIDIA 304.131
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-43-generic
Network:   Card: Realtek RTL-8110SC/8169SC Gigabit Ethernet driver: r8169
           IF: enp2s5 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 360.1GB (22.3% used)
           ID-1: /dev/sda model: ST3160815A size: 160.0GB
           ID-2: /dev/sdb model: ST3200820AS size: 200.0GB
Partition: ID-1: / size: 29G used: 7.3G (27%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 183 Uptime: 4 min Memory: 428.8/1999.8MB
« Reply #3 on: October 16, 2016, 10:26:21 am »
So it worked with nouveau ?
Why not just switch  back to nouveau then ?
« Reply #4 on: October 16, 2016, 10:38:35 am »
I think that's the question, how to restore the nouveau driver.
To accomplish this, go to the Additional Drivers tool.  (I think it's under the System menu, I'm at work right now)  Select the nouveau driver and wait for it to do its thing.  Reboot.  You may not have to do anything else, but odds are you will. If your screen is all wonky after rebooting, go into the Synaptic Package Manager and search for nvidia-304.  Remove any remaining installed nvivia-304 packages.  Make sure you don't remove anything else Nvidia.  Reboot again and you should be back to the nouveau driver.
« Last Edit: October 16, 2016, 10:40:14 am by scifidude79 »
« Reply #5 on: October 16, 2016, 11:18:56 am »
Ok I think I figure it out. It's the monitor. That's an very old monitor that someone gave me to see if it works. I want to use it with my other Acer (X183H) monitor for a dual display setup. The Nvidia settings panel can't figure out what it is now, so that's why it limit the resolution. I noticed also that in windows, it says it's a non-plug and play monitor but can recognized the other, even older Acer. It may have work before during the initial setup. Looks like that monitor stop sending monitor infos (DID). There was also messages with the Peppermint boot disk that DID was not functioning.  I change the cable but with no effect.
I return the original Acer monitor as the main one. It's recognize correctly and PEP works fine. The Nvidia panel also identify it correctly. So that old monitor is finally re-route to where it was supposed to go, recycling, end of story.
Thanks ! I learn something else today...
« Reply #6 on: October 16, 2016, 11:47:33 am »
For future reference doing
xrandr
in a terminal window will bring up the resolutions the connected monitors can connect to
example
