Author Topic: shutdown icon grayed out on P7 (SOLVED)  (Read 1666 times)
Offline gychang
  • Peppermint version(s): 6
« on: October 16, 2016, 07:46:25 am »
I have P7 running and everything works, I can reboot and shutdown using terminal but not using the icon on the  task bar, it is grayed out and can not be activated.  Any fix for this, I have a same problem also on my laptop running P7.
apa@main1 /usr/share/peppermint-settings-panel $ inxi -Fz
System:    Host: main1 Kernel: 4.4.0-43-generic x86_64 (64 bit) Desktop: N/A Distro: Peppermint Seven
Machine:   System: Dell product: XPS 8700
           Mobo: Dell model: 0KWVT8 v: A03 Bios: Dell v: A11 date: 07/09/2015
CPU:       Quad core Intel Core i5-4460 (-MCP-) cache: 6144 KB
           clock speeds: max: 3400 MHz 1: 3216 MHz 2: 3200 MHz 3: 3200 MHz 4: 3221 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV730 PRO [Radeon HD 4650]
           Display Server: X.Org 1.18.4 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1360x768@60.02hz
           GLX Renderer: Gallium 0.4 on AMD RV730 (DRM 2.43.0, LLVM 3.8.0) GLX Version: 3.0 Mesa 11.2.0
Audio:     Card-1 Intel 8 Series/C220 Series High Definition Audio Controller driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] RV710/730 HDMI Audio [Radeon HD 4000 series]
           Card-3 Logitech Webcam C270 driver: USB Audio
           Sound: Advanced Linux Sound Architecture v: k4.4.0-43-generic
Network:   Card-1: Broadcom BCM43142 802.11b/g/n driver: bcma-pci-bridge
           IF: N/A state: N/A mac: N/A
           Card-2: Edimax EW-7711UTn nLite Wireless Adapter [Ralink RT2870] driver: rt2800usb
           IF: wlx801f029706ae state: up mac: <filter>
Drives:    HDD Total Size: 1120.2GB (46.5% used) ID-1: /dev/sda model: WDC_WD10EZEX size: 1000.2GB
           ID-2: /dev/sdb model: BP4e_mSATA_SSD size: 120.0GB
Partition: ID-1: / size: 8.8G used: 6.6G (79%) fs: ext4 dev: /dev/sdb6
           ID-2: /home size: 30G used: 3.8G (14%) fs: ext4 dev: /dev/sdb5
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
Info:      Processes: 217 Uptime: 19 min Memory: 780.0/15999.2MB Client: Shell (bash) inxi: 2.2.35
« Last Edit: October 16, 2016, 12:31:27 pm by gychang »
« Reply #1 on: October 16, 2016, 07:46:25 am »
Re: shutdown icon grayed out on P7
« Reply #2 on: October 16, 2016, 07:52:28 am »
When you say "on the taskbar", do you mean the one in the whiskermenu ? .. or one you've ADDED to the panel ?
Offline gychang
« Reply #3 on: October 16, 2016, 08:25:12 am »
it is the one I added to the panel, action buttons on the item list.
Offline gychang
Re: shutdown icon grayed out on P7 (SOLVED)
« Reply #6 on: October 17, 2016, 03:18:57 am »
Great news, you're most welcome :)
