Author Topic: Tip: speed up your Intel wireless chipset  (Read 1536 times)
Pjotr
  • Guest
« on: October 15, 2016, 06:45:44 am »
There's a new how-to on my website, namely a way to increase wifi speed for wireless chipsets from Intel. At least when it's a (reasonably) modern chipset. This is how:
https://sites.google.com/site/easylinuxtipsproject/3#TOC-Speed-up-your-Intel-wireless-chipset
(item 9, right column)
Have fun!   :)
Offline VinDSL
Re: Tip: speed up your Intel wireless chipset
« Reply #1 on: October 15, 2016, 06:57:01 am »
Interesting !
Is this a kernel bug  :-\
╭─vindsl@Boogaloo-5 ~
dpkg -S $(modinfo iwlwifi | head -1 | awk '{print $2}')
linux-image-extra-4.4.0-42-generic: /lib/modules/4.4.0-42-generic/kernel/drivers/net/wireless/iwlwifi/iwlwifi.ko
Offline VinDSL
« Reply #2 on: October 15, 2016, 07:06:19 am »
n/m
d. Does this hack create stability issues for your wifi? Then undo it with the following terminal command:
sudo rm -v /etc/modprobe.d/iwlwifi11n.conf
Then reboot. All should be then, as it was before.
This would indicate it's NOT a bug.   It's a speed vs. stability compromise, yes ?
Fair enough.  I can live with that ...   8)
Thx for posting !
Pjotr
  • Guest
« Reply #3 on: October 15, 2016, 09:41:54 am »
Yes. But the nice side is, that only a few chipsets suffer from that wifi stability issue, after the hack is applied.... So in most cases this is only beneficial.   :)
For the cases in which wifi stability problems do arise, I have supplied the how-to for undoing the hack.
Offline VinDSL
« Reply #4 on: October 15, 2016, 02:16:15 pm »
Good job !   ;)
Pjotr
  • Guest
« Reply #5 on: October 16, 2016, 02:46:20 pm »
Tonight I did a new measurement on speedtest.net: the speed difference was almost 100 %, so it nearly doubled!
Without the hack (click on the image to enlarge it):
With the hack (click on the image to enlarge it):
Note that the hack doesn't appear to influence the upload speed; only the download speed.
« Last Edit: October 16, 2016, 02:48:32 pm by Pjotr »
