Author Topic: (SOLVED) OEM Install with Peppermint 7?  (Read 1447 times)
Offline gpfromnc
  • Peppermint version(s): 8 and 9
« on: October 10, 2016, 10:07:20 am »
I have an old Dell Dimension with a Pentium 4 processor that I am going to donate to the local thrift shop.  I would like to load Peppermint 7 in "OEM" mode such as one can do using Mint or Ubuntu.   This will allow whoever gets it to be able to enter their name, password, language etc. and make this machine "their computer" as opposed to using what ever username and password I would set for the root account.  Doing it this way has the added benefit of allowing someone coming to linux from a windows background to be able to log on and start using the computer while learning to use a linux based system.  So here's my question.  Is there a way to install Peppermint 7 as oem?
Peppermint is such a great distro.  It combines great performance, especially on an older machine, with a very nice looking and highly configurable desktop.   It will be so great if I can offer this to someone else.
« Last Edit: October 10, 2016, 11:25:58 am by gpfromnc »
« Reply #1 on: October 10, 2016, 10:07:20 am »
then copy what was returned in the terminal and post it back here.
Re: OEM Install with Peppermint 7?
« Reply #2 on: October 10, 2016, 10:09:09 am »
Hi, this is being considered for the future but is not possible at the moment. It's a good idea, I think.
Offline gpfromnc
« Reply #3 on: October 10, 2016, 10:24:18 am »
Thank you for the quick reply.   Just one more thing I love about Peppermint - the community is great!
« Reply #4 on: October 10, 2016, 12:35:33 pm »
+1
Amen to that .. we've been very lucky to have attracted some terrific, friendly, and helpful types .. The Peppermint community rocks, and we're SUPER proud of you all :)
Offline VinDSL
Re: (SOLVED) OEM Install with Peppermint 7?
« Reply #5 on: October 10, 2016, 01:05:03 pm »
+2
I might add, unlike many support sites, this community isn't filled with a bunch of stiff-necked geeks, trying to outdo one another.
Nobody knows everything, i.e. there is no such thing as a 'computer expert'.  There is no competition going on here.
We all have a piece of the puzzle, and freely exchange information.  That's what's so special about this place IMO.   8)
« Reply #6 on: October 10, 2016, 02:41:38 pm »
+3
« Reply #7 on: October 10, 2016, 04:16:56 pm »
Hi gpfromnc, you're a Super Star with your donation  8).  We're all very proud of the magnificent community we have here.  We always try to make people comfortable with their system ;).
« Reply #8 on: October 10, 2016, 06:42:22 pm »
Actually there **is** a way to set it up as "OEM" (so on the next boot the user is prompted to create an account), but first you need to install Peppermint then install some software .. BUT .. without us modifying the ISO the original account that you used to install will be left behind when the new account is created on first boot by the new owner.
So it kinda **can** be done, but it's not ideal .. the new user may wonder why there's 2 accounts and worry that you've left a backdoor.
As murraymint says, in either the respin or PM8 we'll be adding proper support for OEM installations to the ISO image .. the initial temporary account will then be deleted when the new account is created.
Whether you could remove the initial account via a chroot environment and it still work I'm not sure .. I guess I could test it if you want, but at least for now it's gonna mean some CLI work, which should only be undertaken if you feel comfortable in the CLI (specifically chrooting from a LiveUSB) ?
« Last Edit: October 10, 2016, 06:47:13 pm by PCNetSpec »
