Author Topic: "Failed to find cpu0 device node" [SOLVED]  (Read 3697 times)
« on: October 09, 2016, 03:37:28 pm »
I now receive that error message during boot/reboot witht the following specifications on my laptop
spence@hpG6 ~ $ uname -a
Linux hpG6 4.8.0-999-generic #201610022245 SMP Mon Oct 3 02:47:24 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
spence@hpG6 ~ $ inxi -Fz
System:    Host: hpG6 Kernel: 4.8.0-999-generic x86_64 (64 bit) Desktop: N/A
           Distro: Peppermint Seven
Machine:   System: Hewlett-Packard product: HP Pavilion g6 Notebook PC v: 0690130000204610000620100
           Mobo: Hewlett-Packard model: 169B v: KBC Version 18.1A
           Bios: Hewlett-Packard v: F.46 date: 01/16/2012
CPU:       Dual core AMD A4-3305M APU with Radeon HD Graphics (-MCP-) cache: 1024 KB
           clock speeds: max: 1900 MHz 1: 1600 MHz 2: 1600 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Sumo [Radeon HD 6480G]
           Display Server: X.Org 1.18.4 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.03hz
           GLX Renderer: Gallium 0.4 on AMD SUMO2 (DRM 2.46.0, LLVM 3.8.0)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           Card-2 Advanced Micro Devices [AMD/ATI] BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series]
           Sound: Advanced Linux Sound Architecture v: k4.8.0-999-generic
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169
           IF: enp1s0 state: down mac: <filter>
           Card-2: Ralink RT5390 Wireless 802.11n 1T/1R PCIe driver: rt2800pci
Drives:    HDD Total Size: 1060.2GB (1.9% used)
           ID-1: /dev/sda model: PNY_CS1311_240GB size: 240.1GB
           ID-2: /dev/mmcblk0 model: N/A size: 0.5GB
           ID-3: USB /dev/sdb model: 00_HM321HI size: 320.1GB
           ID-4: USB /dev/sdc model: 00AACS size: 500.1GB
Partition: ID-1: / size: 15G used: 3.6G (26%) fs: ext4 dev: /dev/sda2
           ID-2: /boot size: 4.7G used: 120M (3%) fs: ext4 dev: /dev/sda1
           ID-3: /home size: 195G used: 15G (9%) fs: ext4 dev: /dev/sda3
Sensors:   System Temperatures: cpu: 42.0C mobo: 0.0C gpu: 46.0
Info:      Processes: 150 Uptime: 2 min Memory: 477.3/3427.8MB
« Last Edit: October 09, 2016, 06:24:53 pm by spence »
« Reply #1 on: October 09, 2016, 03:37:28 pm »
Re: "Failed to find cpu0 device node"
« Reply #2 on: October 09, 2016, 03:42:49 pm »
spence@hpG6 ~ $ systemd-analyze blame
          8.834s NetworkManager-wait-online.service
          1.075s networking.service
           878ms mintsystem.service
           815ms plymouth-read-write.service
           702ms dev-sda2.device
           461ms systemd-fsck@dev-disk-by\x2duuid-2a3cda82\x2d44c4\x2d4bbb\x2dac
           423ms ModemManager.service
           412ms accounts-daemon.service
           366ms console-setup.service
           353ms grub-common.service
           332ms irqbalance.service
           320ms lightdm.service
           289ms ondemand.service
           258ms systemd-logind.service
           199ms NetworkManager.service
           188ms upower.service
           184ms systemd-rfkill.service
           180ms avahi-daemon.service
           176ms pppd-dns.service
           172ms gpu-manager.service
           171ms console-kit-log-system-start.service
           150ms alsa-restore.service
           144ms keyboard-setup.service
« Reply #3 on: October 09, 2016, 03:46:53 pm »
That's probably being caused by your kernel update, if I were you I'd go back to the earlier kernel and see if the message disappears ?
« Last Edit: October 09, 2016, 03:54:02 pm by PCNetSpec »
