Author Topic: Changing the Pm7 startup wallpaper (the rusty one with the Pm7 logo) (SOLVED)  (Read 945 times)
Offline JimmyTango
  • Peppermint version(s): 7
Is it possible? I mean the rusty one with the Pm7 logo that comes before the login screen.
Much obliged  :P
System:    Host: merlin Kernel: 4.4.0-38-generic x86_64 (64 bit) Desktop: N/A
           Distro: Peppermint Seven
Machine:   System: HP (portable) product: HP Pavilion Notebook v: Type1ProductConfigId
           Mobo: HP model: 820B v: 82.24 Bios: Insyde v: F.06 date: 05/05/2016
CPU:       Dual core Intel Core i5-6200U (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 2800 MHz 1: 499 MHz 2: 573 MHz 3: 499 MHz
           4: 499 MHz
Graphics:  Card: Intel Sky Lake Integrated Graphics
           Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.4.0-38-generic
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169
           Card-2: Intel Wireless 3165 driver: iwlwifi
Drives:    HDD Total Size: 256.1GB (51.0% used)
           ID-1: /dev/sda model: SanDisk_SD8SNAT size: 256.1GB
Partition: ID-1: / size: 227G used: 115G (54%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.47GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 33.0C mobo: N/A
Info:      Processes: 181 Uptime: 16 min Memory: 927.0/7873.3MB
« Last Edit: October 09, 2016, 02:53:52 pm by JimmyTango »
« Reply #1 on: October 09, 2016, 02:04:13 pm »
Re: Changing the Pm7 startup wallpaper (the rusty one with the Pm7 logo)
« Reply #2 on: October 09, 2016, 02:35:27 pm »
Change the background here:
/usr/share/plymouth/themes/peppermint-7/background.png
then run:
sudo update-initramfs -u
Offline JimmyTango
My hero!  :)  :)  :)
Well I've been called some things.....
