Author Topic: Where Are The Startup Applications Found Within Peppermint? (SOLVED)  (Read 10653 times)
...I enable "Certificate and Key Storage" at startup.
-- VinDSL
How does one get to Startup Applications within Peppermint?
I did look at my Task Manager, but I didn't see anything I could recognize related to Startup.  Also, Preferred Applications seemed to offer nothing to help me find Peppermint's Startup Applications.
Where are the Startup Applications found within Peppermint?
I'm at a loss here as to what to do in order to find Peppermint's Startup Applications.
Thank you,
perknh
« Last Edit: June 13, 2014, 08:11:03 am by perknh »
Re: Where Are The Startup Applications Found Within Peppermint?
« Reply #1 on: June 13, 2014, 07:42:37 am »
In this case....
menu > Preferences > Desktop Session Settings > Automatically Started Applications (tab)
and tick "Certificate and Key Storage"
« Reply #2 on: June 13, 2014, 08:10:28 am »
Thank you, PCNetSpec and VinDSL,
I never knew about any of this at all.
Thank you very much,
perknh
 8)
« Last Edit: June 13, 2014, 12:24:42 pm by perknh »
Offline sandstormzach
  • Linux Noob
Re: Where Are The Startup Applications Found Within Peppermint? (SOLVED)
« Reply #3 on: June 23, 2014, 10:42:15 pm »
Speaking of startup applications, is there a way to make Conky run at startup?
« Reply #4 on: June 23, 2014, 11:11:56 pm »
I use a small shell script with 30-seconds delay (90-seconds on a slow machine) to start Conky...
Filename:  conky-autostart-30sec-delay.sh
Path:  /home/<your username>/.config/autostart/conky-autostart-30sec-delay.sh
#!/bin/sh
sleep 30
display=:0.0 conky
I autostart this shell script, at startup, using a desktop config file...
Filename:  conky-autostart.desktop
Path:  /home/<your username>/.config/autostart/conky-autostart.desktop
[Desktop Entry]
Name=Conky Autostart
Comment=Run Conky delay script
Exec=/home/<your username>/.config/autostart/conky-autostart-30sec-delay.sh
Terminal=false
Enable at startup using the instructions above.  Tick the entry called "Conky Autostart".
There are other ways of doing this (combining the shell script + desktop config file, for instance) but that's the method that works best for me, i.e. for the way I do things, e.g. I like to over-engineer everything.    ;D
« Last Edit: June 24, 2014, 11:16:56 am by VinDSL, Reason: Addendum »
  • Linux Noob
« Reply #5 on: June 23, 2014, 11:28:21 pm »
Thanks for the tip! I just found where the autostart applications are kept in Peppermint 5 though, so I don't think I'll bother doing that.  ;D
« Reply #6 on: June 23, 2014, 11:34:03 pm »
You're welcome.
Good luck with that...   ;)
Offline prgramly
  • Peppermint version(s): 5
« Reply #7 on: August 28, 2014, 11:00:29 am »
SOOoooo, where are the autostart applications kept in Pppnt 5?
« Reply #8 on: August 28, 2014, 11:34:42 am »
It *may* be easier to do it by example .. what are you trying to autostart ?
If there's a menu item for it, you can normally just copy the applications .desktop file from
/usr/share/applications
to your
~/.config/autostart
directory.
Offline iamesperambient
  • a totally awesome dude
« Reply #9 on: August 28, 2014, 01:44:01 pm »
In this case....
interesting i actually dont have t his option in my preferences tab
i have desktop preferences but i dont see 'desktop sessions settings' i was
actually looking for the same thing. INteresting. and im also using peppermint 5
http://iamesper.bandcamp.com
boring drone music from NJ
« Reply #10 on: August 28, 2014, 03:37:59 pm »
See the date of that posting .. that was Peppermint 4
« Reply #11 on: August 28, 2014, 08:33:04 pm »
ok sorry i didnt notice!!!! well thats good now i know haha sorry!
Offline prgramly
« Reply #12 on: September 01, 2014, 11:31:48 am »
to your
~/.config/autostart
directory.
ok - i did that - even used the GUI to do it and it worked, but i would not describe that as an intuitive way to accomplish this task. you have to know the secret handshake. looks like Peppermint 4 was more user friendly in this regard.
« Reply #13 on: September 01, 2014, 05:29:50 pm »
Can't see how ?
What did Peppermint 4 have that helped autostart apps ? .. it had lxsession-edit (which can be installed in peppermint 5 too, though it's function is already duplicated in lxsession-default-apps) but that didn't allow you to ADD autostart items, just enable/disable a few system services)
In fact Peppermint 5 has lxsession-default-apps (menu > Preferences > Default applications for LXSession) where you *can* manually add autostart items as long as you know the command to start them.
Granted, there's no GUI kinda "drag'n'drop this to autostart it" .. but you only need to know 2 folder locations to achieve this, same as you did in Peppermint 4 .. I'd say the Peppermint 5 system is slightly more powerful
Or am I missing something ?
Offline prgramly
« Reply #14 on: September 04, 2014, 04:12:26 pm »
ah there it is - that was what i asked for on 8/28 , but instead got the secret handshake method. alas, i understand now why the other method was suggested since LXSession/autostart tab is not very intuitive either.
not trying to be difficult here - thank you for the input. There may not be an intuitive way for a user to pick apps to automatically start at system startup.
