Author Topic: A way to disable touchpad while my mouse is connected via usb? super(SOLVED)  (Read 2019 times)
Offline JimmyTango
  • Peppermint version(s): 7
Is there a way to make my touchpad disable automatically when a usb mouse is connected?
or have a keybind or a macro preset for it?
I know I can disable and enable touchpad by going to input options and putting/taking off a tick on "disable touchpad", but that's a hassle if I'm doing it 5 times a day (I travel a lot).
Thanks!
System:    Host: merlin Kernel: 4.4.0-38-generic x86_64 (64 bit) Desktop: N/A
           Distro: Peppermint Seven
Machine:   System: HP (portable) product: HP Pavilion Notebook v: Type1ProductConfigId
           Mobo: HP model: 820B v: 82.24 Bios: Insyde v: F.06 date: 05/05/2016
CPU:       Dual core Intel Core i5-6200U (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 2800 MHz 1: 784 MHz 2: 799 MHz 3: 799 MHz
           4: 799 MHz
Graphics:  Card: Intel Sky Lake Integrated Graphics
           Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.4.0-38-generic
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169
           Card-2: Intel Wireless 3165 driver: iwlwifi
Drives:    HDD Total Size: 256.1GB (52.9% used)
           ID-1: /dev/sda model: SanDisk_SD8SNAT size: 256.1GB
Partition: ID-1: / size: 227G used: 119G (56%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.47GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 43.0C mobo: N/A
Info:      Processes: 205 Uptime: 58 min Memory: 1805.0/7873.3MB
« Last Edit: October 02, 2016, 04:39:27 am by JimmyTango »
Is there a way to disable touchpad while my mouse is connected via usb?
« Reply #1 on: October 01, 2016, 12:10:44 pm »
Re: Is there a way to disable touchpad while my mouse is connected via usb?
« Reply #2 on: October 01, 2016, 05:26:29 pm »
Short of going into the Peppermint Control Center and manually disabling it NO
Well the truthful answer would be yes, theoretically it could be achieved by a custom udev rule and script .. but it aint straightforward ;)
« Reply #3 on: October 01, 2016, 09:45:00 pm »
Haven't tried this, but doing a quick search ...
LINK:  http://www.thedevilonholiday.co.uk/ubuntu-15-04-disable-the-touchpad-when-a-usb-mouse-is-present/
Looks like it's still supported ...
LINK:  https://launchpad.net/~atareao/+archive/ubuntu/atareao?field.series_filter=xenial  (' touchpad-indicator')
Offline JimmyTango
« Reply #4 on: October 02, 2016, 03:54:38 am »
merlin@merlin ~ $ sudo add-apt-repository ppa:atareao/atareao
 Applications from atareao
 More info: https://launchpad.net/~atareao/+archive/ubuntu/atareao
Press [ENTER] to continue or ctrl-c to cancel adding it
gpg: keyring `/tmp/tmp0kzwa4q9/secring.gpg' created
gpg: keyring `/tmp/tmp0kzwa4q9/pubring.gpg' created
gpg: requesting key 36FD5529 from hkp server keyserver.ubuntu.com
gpg: /tmp/tmp0kzwa4q9/trustdb.gpg: trustdb created
gpg: key 36FD5529: public key "Launchpad PPA for atareao" imported
gpg: Total number processed: 1
gpg:               imported: 1  (RSA: 1)
OK
merlin@merlin ~ $ sudo apt-get update
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
merlin@merlin ~ $ sudo apt-get install touchpad-indicator
I was trying to setup Wargus yesterday, but had to stop half-way, because I couldn't extract data from the War2 CD, perhaps it has to do with that. Now if I'm using "sudo dpkg --configure -a" it brings up the Wargus installation at the spot where I had to abandon it. I have a hint, I'm the one responsible for the mess...
« Last Edit: October 02, 2016, 04:10:45 am by JimmyTango »
Offline JimmyTango
« Reply #5 on: October 02, 2016, 04:38:24 am »
NEVER MIND! Sorted the Wargus issue and it worked like a charm.  THANK YOU THANK YOU THANK YOU!!!
 :) ;D ;D :D ;D :D :P ;D :D
So far, peppermint has been the best OS I've ever used. Needs a few more touches to make it PERFECT, but I'm only thwarted by my own ignorance :D I'm getting there, though.
« Last Edit: October 08, 2016, 07:35:08 am by JimmyTango »
« Reply #6 on: October 02, 2016, 05:12:16 am »
Suggestions for improvement are ALWAYS welcome my mate :)
(as long as they fit our minimalist ethos of not choosing application software FOR the user)
« Last Edit: October 02, 2016, 05:14:13 am by PCNetSpec »
Offline JimmyTango
I always make honest attempts at searching through the forums and then the internet before I post for help, but couldn't find any mentions of this one somehow. Really sorry about that.
Thx for testing it !
I always carry a USB mouse in my laptop bag, but I seldom use it.  When I do use it, I place an I.D. badge or credit card on the touchpad -- a ghetto solution, for sure.
Think I'll give it a whirl, the next time I boot my 'road warrior' ...   ;)
thank you, thank you... thank you very much for asking... ;)
and thanks to VinDSL for finding something I've been hunting but never had found...  :-*
