Author Topic: [solved]Fujitsu Siemens s miniCard D2301 802.11bg Wireless Module  (Read 3190 times)
Offline darknet
  • /home/darknet
  • Peppermint version(s): Peppermint 10 respin 64-bit
On my self-builded desktop i have no wireless.
darknet@darknet-G45M ~ $ inxi -F
System:    Host: darknet-G45M Kernel: 4.4.0-38-generic x86_64 (64 bit)
Machine:   Mobo: FOXCONN model: G45M04 v: 1.1
           Bios: American Megatrends v: 080015 date: 08/16/2008
CPU:       Quad core Intel Core2 Quad Q6600 (-MCP-) cache: 4096 KB
           clock speeds: max: 2403 MHz 1: 1603 MHz 2: 1603 MHz 3: 1603 MHz
           4: 1603 MHz
Graphics:  Card: NVIDIA GK107 [GeForce GT 640 OEM]
           Display Server: X.Org 1.18.3 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: GeForce GT 640/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 361.42
Audio:     Card-1 NVIDIA GK107 HDMI Audio Controller driver: snd_hda_intel
           Card-2 Intel 82801JI (ICH10 Family) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-38-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169
           IF: enp3s0 state: up speed: 100 Mbps duplex: full
           mac: 00:1f:e2:6a:a6:3b
           Card-2: Fujitsu Siemens s miniCard D2301 802.11bg Wireless Module [SiS 163U]
           IF: null-if-id state: N/A mac: N/A
Drives:    HDD Total Size: 2060.4GB (0.9% used)
           ID-1: /dev/sda model: SPCC_Solid_State size: 60.0GB
           ID-2: /dev/sdb model: WDC_WD20EFRX size: 2000.4GB
Partition: ID-1: / size: 55G used: 4.7G (9%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 1.8T used: 9.3G (1%) fs: ext4 dev: /dev/sdb2
           ID-3: swap-1 size: 4.00GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
Sensors:   System Temperatures: cpu: 56.0C mobo: N/A gpu: 50C
Info:      Processes: 221 Uptime: 9:29 Memory: 1223.4/3951.2MB
In the past i have try it with ubuntu, linuxmint, manjaro and antergos but never have succes  :-[ :-[
« Last Edit: October 03, 2016, 06:46:03 am by darknet »
« Reply #1 on: October 01, 2016, 06:49:52 am »
Re: Fujitsu Siemens s miniCard D2301 802.11bg Wireless Module
« Reply #2 on: October 01, 2016, 11:15:36 am »
Can you post the output from:
lspci -vnn | grep -i net
Offline darknet
  • /home/darknet
« Reply #3 on: October 01, 2016, 11:26:31 pm »
darknet@darknet-G45M ~ $ lspci -vnn | grep -i net
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 01)
Subsystem: Foxconn International, Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [105b:0de3]
« Reply #4 on: October 02, 2016, 08:44:24 am »
Have you tried the Windows drivers via ndisgtk ?
If not, open a terminal and run:
sudo apt-get install dkms build-essential ndisgtknow download this file
https://dl.dropboxusercontent.com/u/31525164/SiS163U_R109d_VistaWin7.rar
and unpack it.
Then in your menu go to
menu > System Tools > Windows Wireless Drivers
Click on "Install New Driver"
Click on "Location", and browser to where you unpacked the driver .. then the "64bit" folder .. then the "sis163u.inf" file.
Then click the "Install" button.
Offline darknet
  • /home/darknet
« Reply #5 on: October 02, 2016, 09:06:14 am »
when i extract it i get the message:
an error occured while extracting files
parsing filters is unsupported
« Reply #6 on: October 02, 2016, 10:04:16 am »
Okay I've repacked them as a tarball .. with an ethernet connection, open a terminal and run:
cd ~/Desktopthen
wget https://dl.dropboxusercontent.com/u/31525164/SiS163U_R109d_VistaWin7.tar.gzthen
tar xvf SiS163U_R109d_VistaWin7.tar.gzyou should now have a folder on your desktop called "SiS163U_R109d_VistaWin7"
Offline darknet
  • /home/darknet
« Reply #7 on: October 03, 2016, 06:45:29 am »
that did it  ;) thank you
Re: [solved]Fujitsu Siemens s miniCard D2301 802.11bg Wireless Module
« Reply #8 on: October 03, 2016, 07:35:49 am »
You're most welcome :)
You might want to keep a copy of that driver tarball as I don't know how long it'll stay in my dropbox .. otherwise you can get it from here:
http://support.ts.fujitsu.com/IndexDownload.asp?lng=EN&ln=no&LC=yes
Driver > WLAN > WLAN MiniCard D2301 (for the AMILO Li 1818)
which is where I found it.
Quote from: darknet
and then you found Peppermint ;)
« Last Edit: October 03, 2016, 07:40:37 am by PCNetSpec »
