Author Topic: Getting ready to install EVGA GeForce 8400 GS  (Read 1551 times)
Offline mjvezzani
  • Peppermint version(s): 7
« on: October 01, 2016, 05:39:22 am »
Hi all!
I'm receiving a new EVGA GeForce 8400 GS for my Inspiron 530, and I was wondering what information I might need / cautions I should take when installing NVIDIA cards on Peppermint OS.
A quick peek at my system, in case that is helpful to anyone. :)
« Reply #1 on: October 01, 2016, 05:39:22 am »
Re: Getting ready to install EVGA GeForce 8400 GS
« Reply #2 on: October 01, 2016, 06:27:52 am »
Nothing too fancy.  Just, after you install it and boot, you'll probably want to go to Menu > Preferences > Additional Drivers and install the Nvidia proprietary driver for it.  The Nouveau (open source) driver is OK, but the proprietary one does things it can't.  You shouldn't have too many issues with the 8400.  As far as I know, it should use the Nvidia-340 driver and should work just fine.
Offline mjvezzani
« Reply #3 on: October 01, 2016, 09:16:57 am »
Ok,
I got the card installed without any incident and was able to use the proprietary driver. Awesome. It works with a regular vga monitor, but when I hook it up to HDMI things appear much bigger than they should. For example, Chrome appears to be blown up by about 350%. This is unfamiliar territory for me and I'm not sure where to start regarding troubleshooting this problem. I'm wondering if my "monitor" (a 60 inch Hitachi television with HDMI input) is the issue here, but I suspect there are things I can do with regards to video settings configuration. Any direction would be appreciated!
« Reply #4 on: October 01, 2016, 09:27:34 am »
Ok,
Hi mjvezzani
Can you open a terminal and give us the output from
xrandr
This should tell us what resolutions the TV can take
Offline mjvezzani
« Reply #5 on: October 01, 2016, 11:07:21 am »
Hey Zeb,
Here is the output from `xrandr`:
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 8192 x 8192
DVI-I-0 disconnected primary (normal left inverted right x axis y axis)
VGA-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
   1920x1080     60.05*+  60.00
   1440x480      60.05
   1280x720      60.00    59.94
   720x480       59.94    60.05
   640x480       59.94    59.93
« Last Edit: October 01, 2016, 11:40:04 am by mjvezzani »
« Reply #6 on: October 01, 2016, 11:36:14 am »
Hi mjvezanni,
for future reference, could you please remember to encapsulate terminal outputs with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  Don't combine the functions.  Only use one or the other  ;).  These preserve the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively.  Use the Preview button to see how it'll look in the forum.
« Reply #7 on: October 01, 2016, 11:40:05 am »
Hi mjvezanni,
So 1920 x 1080 is the best you are going to get and on a 60" screen is going to make that look a bit Fischer Price.   ie  stupidly big icons txt etc
You may have to play with nvidia-settings to see if you can get it to scale things smaller.
Never used a PC on such a large TV - maybe other forum members have and can help...
