Author Topic: [SOLVED] Change Login Logo - Peppermint Seven  (Read 1259 times)
Offline r00t3r
  • r00t3r
  • Peppermint version(s): Peppermint Ten (10)
« on: October 01, 2016, 04:26:52 am »
Hi,
I was looking everywhere how to change the login (http://i.imgur.com/kqbw6zJ.png) logo but unfortunately nothing worked.
Could you please give me instructions how I could change the login to logo to a custom one?
Thank you.
« Last Edit: October 01, 2016, 06:49:36 am by r00t3r »
« Reply #1 on: October 01, 2016, 04:26:52 am »
Re: Change Login Logo - Peppermint Seven
« Reply #2 on: October 01, 2016, 05:26:36 am »
Can you answer the autoresponse above when posting new topics .. in this case it's pretty irrelevant, but we want people to get into the habit.
Offline r00t3r
  • r00t3r
« Reply #3 on: October 01, 2016, 05:30:21 am »
Yeah, no problem. Will do from now on. :)
Offline JimmyTango
  • Peppermint version(s): 7
« Reply #4 on: October 01, 2016, 05:48:35 am »
Hey man. I was wondering the same.
try going to System Tools --> LightDM GTK+ Greeter Settings --> Appearence and below you can see the option of changing the icon
HOWEVER,
it doesn't work for me, regardless of the icon I choose there. Perhaps it has to be of a very specific resolution/format?
Try if it works for you.
Curious to what the skilled guys on the forum say on this one :)
Cheers
« Last Edit: October 01, 2016, 05:51:55 am by JimmyTango »
Offline r00t3r
  • r00t3r
« Reply #5 on: October 01, 2016, 05:58:36 am »
Hi @JimmyTango,
I have already tried this and does not work.
Thanks anyways.
« Reply #6 on: October 01, 2016, 06:40:08 am »
Hi r00t3r, how's it going :)?  Yeah, this is easy.  Firstly, make sure the image you're going to use is in .png format.  <<< This is important.  Now open the Nemo file manager and in your /home folder, find the file called .face.  Change it to .face.old.  You can do this quickly by running the following command in a terminal window:
mv -v ~/.face ~/.face.oldPlace the .png image you want to use in your /home folder.  Rename it .face.  That's it  :).  Reboot your machine to check the image shows up in the login screen  ;).  I hope this helps  ;).
« Last Edit: October 01, 2016, 11:44:14 am by AndyInMokum »
« Reply #7 on: October 01, 2016, 06:45:01 am »
Well, Andy beat me to it.  He's a ninja, that one.  ;)
Also, the .face file on the system is 96x96.  I'm not sure if it's necessary, but you may want to make the .png file you want to use the same size.
Offline r00t3r
  • r00t3r
« Reply #8 on: October 01, 2016, 06:49:23 am »
Hi @AndyInMokum,
Thank you very much. :)
Offline JimmyTango
Re: [SOLVED] Change Login Logo - Peppermint Seven
« Reply #9 on: October 01, 2016, 11:02:07 am »
Thanks guys.
