Author Topic: Peppermint 7 and 8 - Using RUFUS to create a LiveUSB in Windows  (Read 29109 times)
« on: September 21, 2016, 05:32:46 am »
Peppermint recommend using RUFUS for creating Peppermint 7 and 8 LiveUSB's in Windows.
Here's how...
Download the Peppermint ISO image from our main website:
https://peppermintos.com
and save it somewhere you'll be able to find it.
Download RUFUS from here:
https://rufus.akeo.ie/
and fire it up.
1) Select the USB stick.
2) Give the USB stick a label (can be whatever you want).
3) From the drop menu select "ISO Image".
4) Click the button no navigate to the Peppermint 7/8 ISO image you downloaded earlier
Select the Peppermint 7/8 ISO image, and click the "Open" button.
Click the "Start" button.
You'll now be presented with this screen:-
Select "Write in ISO Image mode (Recommended)", and click "OK".
You'll be presented with a WARNING that everything on the USB stick will be overwritten and destroyed.
As long as you're happy with that, click "OK".
RUFUS will start to create the LiveUSB:-
And will tell you when it's done by displaying "READY":-
That's it, you're done and the Peppermint 7/8 LiveUSB is ready to use .. just close RUFUS, and boot to the USB stick.
« Last Edit: December 19, 2017, 07:03:44 am by PCNetSpec »
