Author Topic: [SOLVED] WDC WD5000BPKT - 2.5" my laptop's HDD makes a weird click sound.  (Read 1872 times)
Offline fthpl
  • Talha Fatih Pala
  • Peppermint version(s): 7
Hello friends . I have a western digital 500 gb 7200 rpm mobile 2.5"" hardisk on my laptop.  I read to many page on the net but I can't not find solution for this weird sound yet.
When I don't use ten minutes my machine than my hard disk doing weird click sound. I hope somebodies have a like this thing and i hope we can find a answer for this.
I tried hdparm things. But it's still same. Every i tried linux distro's has a this thing.  8)
rootf13@M7X0SUF13 ~ $ inxi -Fz
System:    Host: M7X0SUF13 Kernel: 4.4.0-36-generic x86_64 (64 bit)
Machine:   System: CASPER (portable) product: M7X0SU v: Rev. A1
           Mobo: clevo model: M7X0SU v: Bottom
           Bios: Phoenix v: 6.00 date: 11/07/0892
CPU:       Dual core Pentium T4200 (-MCP-) cache: 1024 KB
           clock speeds: max: 2000 MHz 1: 1600 MHz 2: 1600 MHz
Graphics:  Card: NVIDIA G98M [GeForce 9300M GS]
           Display Server: X.Org 1.18.3 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1280x800@60.00hz
           GLX Renderer: GeForce 9300M GS/PCIe/SSE2
           GLX Version: 3.3.0 NVIDIA 340.96
Audio:     Card Silicon Integrated Systems [SiS] Azalia Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-36-generic
Network:   Card-1: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter
           driver: sis190
           IF: enp0s4 state: down mac: <filter>
           Card-2: Realtek RTL8187B Wireless 802.11g 54Mbps Network Adapter
           driver: rtl8187
           IF: wlx0022430fc4f9 state: N/A mac: N/A
Drives:    HDD Total Size: 500.1GB (1.2% used)
           ID-1: /dev/sda model: WDC_WD5000BPKT size: 500.1GB
Partition: ID-1: / size: 99G used: 5.6G (6%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 58.8C mobo: N/A gpu: 68C
Info:      Processes: 171 Uptime: 20 min Memory: 743.5/3949.4MB
« Last Edit: September 22, 2016, 12:23:31 pm by fthpl »
Ubuntu>>Debian>>LinuxMint>>Sabayon>>Crunchbang>>Peppermint7.
Openbox and lxde lover! Old gnome2 user. :]
WDC WD5000BPKT - 2.5" my laptop's HDD makes a sound. A click-like weird sound.
« Reply #1 on: September 17, 2016, 06:54:39 am »
[THIS IS AN AUTOMATED RESPONSE]
If this is a new request for support and you haven't already done so, can you please be sure to include information about your system that will help us to help you.
Please open a terminal (Ctrl+Alt+T) and run the following command:
Thanks in advance :)
See if disabling advanced power management for your WD drive makes a difference...
Open the "Disks" utility .. highlight your WD drive in the left hand column .. click the little 'hamburger' button on the titlebar and select "Drive Settings" .. on the 'APM' tab, set the switch to OFF.
Offline fthpl
  • Talha Fatih Pala
'APM' tab is already closed. I don't touch it.
* I just opened and changed the waiting tab maybe it will okey. I'll write ,thanks..
« Last Edit: September 17, 2016, 08:29:35 am by fthpl »
Offline acer
have you tried option number 10 on this website Some laptops: hard disk constantly clicks and spins up and down
https://sites.google.com/site/easylinuxtipsproject/bugs
edit, it seems you have tried hdparm, sorry I missed that.
Great site for newbies though.
« Last Edit: September 17, 2016, 08:33:42 am by acer »
Offline fthpl
  • Talha Fatih Pala
Yeah i tried. It doesn't work. But i think disk utility systems may change it. I will organize my hdd and than i'll search again.
Offline fthpl
  • Talha Fatih Pala
This problem solved! In the end, i did this three settings from to disk manager than harddisk is working like on windows vista or 7. Every ten seconds clicking normally like in working windows , sounds is good . Not seems like that bad *gurk sound.  :P :D :)
I marked to topic. Thanks a lot!
I am happy now... ;)
