Author Topic: Stellarium does not work on Peppermint 4  (Read 2065 times)
Offline capngloval
    • Denny's Home World
  • Peppermint version(s): Peppermint-8-20171130-amd64
« on: June 10, 2014, 06:06:37 am »
When I run Stellarium, it opens for a second, then crashes and closes.
When I run it from the terminal, I get this:
Stellarium works just fine on this computer with Xubuntu 14.04 LTS.
« Last Edit: June 10, 2014, 06:26:54 am by PCNetSpec »
"A person is smart. People are dumb, panicky dangerous animals and you know it." -Agent K
Re: Stellarium does not work on Peppermint 4
« Reply #1 on: June 10, 2014, 06:21:59 am »
Attempting to use an existing older config file.
Config file is:  "/home/denny/.stellarium/config.ini"
It seems to be picking up an old config file .. try renaming the ~/.stellarium folder:
mv -v /home/denny/.stellarium /home/denny/.stellarium-old
now what happens if you try to run it from the command line ?
Or see the solution in this bug report:
https://bugs.launchpad.net/ubuntu/+source/stellarium/+bug/1173844
BTW, Peppermint 5 is due out very soon, and will be based on Lubuntu 14.04 ;)
« Last Edit: June 10, 2014, 06:25:40 am by PCNetSpec »
