Author Topic: brtfs query..[solved]  (Read 949 times)
Offline acer
« on: September 09, 2016, 02:44:11 am »
Is it safe to remove the brtfs tools?
How is this done?
is there anything I should be made aware of before doing so?
The file system is the default from live! installation which I think is EXT4
TIA
« Last Edit: September 09, 2016, 03:54:05 am by acer »
Re: brtfs query..
« Reply #1 on: September 09, 2016, 02:58:11 am »
Unless you specifically chose to use btrfs as the file system during installation (and this wouldn't have happened accidentally) YES it's safe to remove btrfs-tools
sudo apt-get remove --purge btrfs-tools
Offline acer
Re: brtfs query.. [solved]
« Reply #2 on: September 09, 2016, 03:53:34 am »
Worked a treat and boot-time also quicker,  :)
This command has been added to my compilation of PM7 tweaks for the next two devices, when I have the time.
I seem to be spending more time on PM7 these days than Windoze 7 and enjoying the challenge more..   ;D
thanks again PCNetspec
Re: brtfs query..[solved]
« Reply #3 on: September 09, 2016, 04:00:06 am »
You're most welcome acer :)
