Author Topic: mdadm Software Raid Peppermint 7  (Read 1612 times)
Offline Kujawamaster
  • Peppermint version(s): PM7sda:boot,/,tmp sdb:home, swap
« on: September 04, 2016, 02:13:57 pm »
Hi Guys. Is it possible to install Peppermint 7 in raid mode with mdadm?
I had used fdisk to make 4 primary partition, and band it with mdadm making 4 partitions (md0,md1,...)  for /boot (raid1), / (raid0), /home (raid1), swap (raid0). And there are always some troubles and it never boots after install, I tried few times. Disks are identical, same brand, model capacity, also partition i have made are identical.
There is always a problem during installation with GRUB. Even after installation in GRUB rescue mode manual booting doesn't work. I use Optiplex 330. On Esprimo is the same problem.
Have any one tried the mdadm raid?
(i have AHCI mode set ON in BIOS)
Sorry about my english, it's not my native language.
« Last Edit: September 06, 2016, 05:10:14 am by Kujawamaster »
Offline stroudmw
  • Peppermint version(s): 8 32 bit
Re: mdadm Software Raid Peppermint 7
« Reply #1 on: December 06, 2017, 03:26:33 am »
Sorry about the late reply, but I've just seen this post. I've got Peppermint 8 running on a RAID 0 array, and I used mdadm.
« Reply #2 on: December 06, 2017, 04:34:50 am »
Would you be so kind and told me how You did it? I was tried with PMos7 and I was installing mdadm in live mode, next I done partitioning, and install. Need I install PMos normal first, and after that mdadm, or add mdadm to iso (I don't know how to that, but know it is possible). Do You use btrfs or something else? I will be very grateful for response. It's child's play in for examlpe fedora, but I really want, to do that in light and fast debian based distro, like PMos.
« Reply #3 on: December 06, 2017, 11:43:31 am »
See the ticked response here for  RAID-1:
https://askubuntu.com/questions/505446/how-to-install-ubuntu-14-04-with-raid-1-using-desktop-installer
Which RAID type are you going for ?
« Reply #4 on: December 11, 2017, 04:37:52 am »
I'd like to make:
/boot - RAID1,
/home - RAID1,
/root - RAID0,
swap - RAID0,
Offline tetricky
  • Peppermint version(s): 8, 9
« Reply #5 on: December 11, 2017, 12:06:10 pm »
There are things that I wouldn't do there (boot on raid1, but root on raid0, why?). Generally I'd suggest looking at LVM and raid for more arcane setups like this. It's more flexible in the long run, and you are going to be less stuck with partitions that make sense now, but don't later.
« Reply #6 on: December 11, 2017, 07:28:00 pm »
I'm a bit lost what you're trying to say here ?
/boot - RAID1,
/home - RAID1,
/root - RAID0,
swap - RAID0,
Am I right in assuming by that you mean you want 2 disks in a (RAID-0) striped configuration .. but you want specific partitions on specific disks ?
