Author Topic: Fail message at boot.  (Read 3456 times)
« on: September 03, 2016, 04:33:00 pm »
Hi all, my machine again froze after waking from: Suspend.  I was required to do a hard shutdown.  On reboot, instead of receiving the usual fsck clear message.  I'm now getting a longer message with a red Fail in parentheses.  Unfortunately, I can't read the message because the SSD has made the boot time too damn quick.  I've changed from the Xfce4 Power Manager to the Mate Power Manager.  That has slowed down the frequency of the freezes considerably.
I'm multi-booting, so I've booted into SparkyLinux to run any repairs.   Here's a list of my partitions:
andy@sparky-dell-latitude:~$ sudo parted /dev/sda 'print'
[sudo] password for andy:
Model: ATA KINGSTON SV300S3 (scsi)
Disk /dev/sda: 120GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type      File system  Flags
 1      3145kB  120GB   120GB   extended               boot
 5      3146kB  21.5GB  21.5GB  logical   ext4
 6      21.5GB  40.8GB  19.3GB  logical   ext4
 7      40.8GB  62.3GB  21.5GB  logical   ext4
 8      62.3GB  81.6GB  19.3GB  logical   ext4
 9      81.6GB  103GB   21.5GB  logical   ext4
10      103GB   120GB   16.9GB  logical   ext4
andy@sparky-dell-latitude:~$ sudo parted /dev/sdb 'print'
Model: ATA WDC WD10JPVX-60J (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
 1      1049kB  992GB   992GB   primary  ext4
 2      992GB   1000GB  8589MB  primary  linux-swap(v1)
[bPeppermint 7[/b] is on: /dev/sda9 and /dev/sda10.   The partitions of the second hard drive are a shared /DATA partition and a swap space.  I've run:
sudo fsck -M /dev/sda9
sudo fsck -M /dev/sda10and
sudo fsck -M /dev/sdb1They all check out fine.
andy@sparky-dell-latitude:~$ sudo fsck -M /dev/sda9
fsck from util-linux 2.28.1
e2fsck 1.43.1 (08-Jun-2016)
PM7/: clean, 358059/1310720 files, 2087535/5242880 blocks
ndy@sparky-dell-latitude:~$ sudo fsck -M /dev/sda10
PM7/home: clean, 65122/1036320 files, 1912738/4137472 blocks
andy@sparky-dell-latitude:~$ sudo fsck -M /dev/sdb1
/DATA: clean, 144171/60530688 files, 71270819/242093312 blocks (check in 5 mounts)
When I boot into Peppermint 7, it appears to be running fine.  I can't figure out what's causing the Fail alert  :-\.  These random freezes are driving me crazy  >:(.  Where can I find the boot log?  Maybe that'll shed some light on what's happening  ;).
Offline VinDSL
Re: Fail message at boot.
« Reply #1 on: September 03, 2016, 04:45:57 pm »
╭─vindsl@Boogaloo-5 ~
╰─➤  journalctl
That will give you everything.
There are filters, too.  Hit Ctrl-Home to see the commands.   ;)
EDIT
This might be more useful to you ...
╰─➤  journalctl -b0 --system _COMM=systemd
« Last Edit: September 03, 2016, 04:49:38 pm by VinDSL »
« Reply #2 on: September 03, 2016, 05:00:39 pm »
╰─➤  journalctl
EDIT
Thanks John, I'll give that a whirl when I boot back into PM7.  I wish I could get to the bottom of this hard freezing.  I wouldn't have these issues if I could fix it.  It's the only problem I have with PM7, apart from it booting too quick to readerror/fail messages  ;D.
Offline VinDSL
« Reply #3 on: September 03, 2016, 05:38:05 pm »
Happy hunting !   ;)
« Reply #4 on: September 03, 2016, 10:24:46 pm »
Hi Andy
Would /var/log/boot.log perhaps shed any light on it ?
« Reply #5 on: September 03, 2016, 10:47:43 pm »
Found the little rascal:
[  OK  ] Started Create Volatile Files and Directories.
[FAILED] Failed to start LSB: AppArmor initialization.
See 'systemctl status apparmor.service' for details.
I don't think it's anything very important.  I'd like to clear it up though, if possible.  Any help is much appreciated  ;).
Many thanks to both VinDSL and Emegra for their assistance  ;).
« Reply #6 on: September 03, 2016, 11:25:56 pm »
Have you run in the terminal
any clues there ?
« Reply #7 on: September 03, 2016, 11:47:49 pm »
any clues there ?
That looks fine:
andy@andy-Latitude-PM7 ~ $ systemctl status apparmor.service
● apparmor.service - LSB: AppArmor initialization
   Loaded: loaded (/etc/init.d/apparmor; bad; vendor preset: enabled)
   Active: active (exited) since zo 2016-09-04 08:24:44 CEST; 4min 54s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 2414 ExecStart=/etc/init.d/apparmor start (code=exited, status=0/SUCCESS)
sep 04 08:24:41 andy-Latitude-PM7 systemd[1]: Starting LSB: AppArmor initialization...
sep 04 08:24:41 andy-Latitude-PM7 apparmor[2414]:  * Starting AppArmor profiles
sep 04 08:24:41 andy-Latitude-PM7 apparmor[2414]: Skipping profile in /etc/apparmor.d/di
sep 04 08:24:44 andy-Latitude-PM7 apparmor[2414]:    ...done.
sep 04 08:24:44 andy-Latitude-PM7 systemd[1]: Started LSB: AppArmor initialization.
Tried rebooting again and the nano second Fail message is still there.  Also the Fail message is back at boot.  There's no record of it in the, /var/log/boot.log file:
I'm now officially baffled  :-\.
« Reply #8 on: September 04, 2016, 12:38:36 am »
any clues there ?
That looks fine:
More progress.  It's systemd thing, (naturally  >:().
Failed to start LSB: QEMU KVM module loading script.I've disabled the qemu with:
systemctl disable qemu-kvmThe fail messages have now disappeared at boot and shutdown/reboot.  Is it safe to completely remove this metapackage and is it recommended.  I see there are security concerns associated with it - many thanks  ;).
« Reply #9 on: September 04, 2016, 01:12:58 am »
Just out of curiosity have you tried this booting with another kernel ?
« Reply #10 on: September 04, 2016, 01:40:43 am »
The system freezing happen in every kernel I've tried.  It was happening while we were beta testing too.  I haven't tried the 4.7.2 kernel.  I could give that a go.  I don't expect much though.  The initial thought was a failing memory card.  I've run a couple of system diagnostic from the BIOS.  The memory cards checked out each time.  I've the Intel microcode running.  So the CPU firmware is up to date and optimized for Linux.  The system freezes were MUCH worse with the Xfce4 Power Manager.  I could just about guarantee the system would freeze coming out of suspend and hibernate.  While the Mate Power Manager  is a long way from perfect with applying settings.  It's still light years ahead of the Xfce4 Power Manager on this machine.  The system freezes are really sporadic.  I can't see any fixed pattern.  This is what's making the issue so annoying and difficult to diagnose.
« Last Edit: September 04, 2016, 01:46:44 am by AndyInMokum »
« Reply #11 on: September 04, 2016, 02:17:32 am »
Seeing all these problems - I am so happy I just shut my laptop down when not in use.  It only take a min or two to reboot anyway :)
« Reply #12 on: September 04, 2016, 02:24:08 am »
I know what you mean.  I'm just a stubon old goat, who thinks because it's there, it should work.  If it doesn't, I want to know why  ;).
« Reply #13 on: September 04, 2016, 02:29:08 am »
well qemu-kvm isn't installed by default on my machine so I'd guess it should be safe to remove depending on what added it in the first place .. just FYI here's what installing it on my system would pull in:-
  cpu-checker ipxe-qemu libboost-random1.58.0 libboost-thread1.58.0
  libbrlapi0.6 libcacard0 libfdt1 libiscsi2 librados2 librbd1 libspice-server1
  libusbredirparser1 libxen-4.6 libxenstore3.0 msr-tools qemu-block-extra
  qemu-kvm qemu-system-common qemu-system-x86 qemu-utils seabios sharutils
So if I were you I'd run a simulated purge
sudo apt-get remove --purge -s qemu-kvmand see what it says will be removed .. you should then be able to figure out what pulled it in in the first place.
You could also purge apparmor and check if that helps .. you can always add it back later if you wish
sudo apt-get remove --purge apparmor apparmor-notify
« Reply #14 on: September 04, 2016, 05:03:42 am »
Cheers, I'll try this a little later on today  ;).
