Author Topic: Date Missing? (SOLVED)  (Read 1938 times)
Offline whitehavenchaz
  • Peppermint version(s): 7
« on: August 29, 2016, 03:43:47 pm »
Is it possible to add the date next to the time on the menu bar?  I have the time, but no date.
Thanks.
« Last Edit: August 30, 2016, 06:08:57 pm by PCNetSpec »
Online zebedeeboss
Re: Date Missing?
« Reply #1 on: August 29, 2016, 04:26:31 pm »
Hi whitehavenchaz
for the date I choose to display
%a %d %b, %Y
Which gives me Mon 29 Aug, 2016.    If you use %A and %B It will give Monday and August.
or you can simply use
dd/mm/yyyy
  which will give you 29/08/2016.   Remember to leave what is there for the time to show
You can achieve this by right clicking the clock and choose properties (not panel properties) and then either pick an option from the relevant drop down or choose custom and configure it how you wish
Linux User #565092
Re: Date Missing?
« Reply #2 on: August 29, 2016, 04:30:46 pm »
Hi whitehavenchaz
You could add the orage clock to the panel which will give you a clock and an icon showing the current date, you can find orage in the repo or
sudo apt-get install orage
Then add it to the panel
Re: Date Missing?
« Reply #3 on: August 29, 2016, 05:01:57 pm »
Hi whitehavenchaz
%a %d %b, %Y
dd/mm/yyyy
I'm not sure what I did to this topic.  Anyway, I can get I Orage to install, which is not what I'm looking for.  I just want the date next to the time which I just I can't get.
Sorry for the forum confusion - I'm not sure what I did.
Online zebedeeboss
Re: Date Missing?
« Reply #4 on: August 29, 2016, 05:06:16 pm »
Hi whitehavenchaz
%a %d %b, %Y
dd/mm/yyyy
Hi  I am not on my main machine tonight. If no one answers and still open I will post tomorrow with screen shots.    I'll assume you are using P7 from your profile.
Linux User #565092
Re: Date Missing?
« Reply #5 on: August 29, 2016, 05:10:53 pm »
You can get what you want in orage by changing Line1 in the properties to %A %d %B %X
like this
http://imgur.com/a/I0meB
« Last Edit: August 29, 2016, 05:16:03 pm by emegra »
Re: Date Missing?
« Reply #6 on: August 29, 2016, 08:10:07 pm »
You should (as zebedeeboss suggested) be able to get this with the regular clock on the xfce4-panel
Right-click the clock and select "Properties"
When the clock properties opens, select
Format: Custom Format
In the new box below, put one of these:-
24hr format with long date
%R %a %d %b %Y
24hr format with short date
%R %d %b
12hr format with long date
%I:M %P %a %d %b %Y
12hr format with short date
%I:M %P %d %b
or even (for Americans)
%I:M %P  date - %m/%d/%y
or (for the rest of us)
%I:M %P  date - %d/%m/%y
if you want ;)
etc.
You can get the options by running:
man strftime
Re: Date Missing?
« Reply #7 on: August 30, 2016, 02:23:21 pm »
I can't believe this is stumping me.  I don't see any option in the XFCE Panel or Orage to insert the date.  There is a choice to configure the time format.  What am I missing?
I have used Unity, Gnome 3.20, Cinnamon, Plasma 5 and Budgie with no issue inserting the date to the right of the time..  I just don't see it.  Yikes.
Re: Date Missing?
« Reply #8 on: August 30, 2016, 02:33:34 pm »
There is  NO separate DATE field in the clock on the xfce4-panel .. those strings go under:-
Clock Options
[string goes in this box, that appears when you choose "Custom Format" above]
in the clocks preferences page.
« Last Edit: August 30, 2016, 02:37:28 pm by PCNetSpec »
Re: Date Missing?
« Reply #9 on: August 30, 2016, 02:51:59 pm »
Clock Options
Ah I got it.  This is what I did:  %a %b %d, %Y   %I:%R %p giving me 'Tue Aug 30, 2016  02:14:50 PM.'
Thanks.
« Last Edit: August 30, 2016, 02:53:32 pm by whitehavenchaz »
Re: Date Missing?
« Reply #10 on: August 30, 2016, 03:15:02 pm »
No problem, can you please remember to mark the topic solved by appending (SOLVED) to the end of the suject line in the FIRST posting in this topic.
TIA :)
Re: Date Missing?
« Reply #11 on: August 30, 2016, 03:51:21 pm »
TIA :)
It isn't solved.  I just noticed my time hasn't changed.  Any ideas?
Edit:  I think it is solved, now, maybe.  %a %b %d, %Y   %I:%M:%S %p.  I am going to hold off marking this solved for an hour.
« Last Edit: August 30, 2016, 03:58:18 pm by whitehavenchaz »
Re: Date Missing?
« Reply #12 on: August 30, 2016, 03:57:38 pm »
Tried logging out and in again?
Re: Date Missing?
« Reply #13 on: August 30, 2016, 04:21:51 pm »
I think I got it.  I will mark it as solved.
