Author Topic: File server for Windows users (SOLVED)  (Read 2246 times)
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
  • Peppermint version(s): 1, 3, 4, 5, 6, 8, 9, 10
« on: June 07, 2014, 01:09:30 am »
Hello
I have a couple of computers with PM 1, 3, and 4 as well as a desktop with windows 7.  I can see the windows shares just fine on the Linux boxes, but have not figured out how to see the Linux shares when I am logged into the Win 7 box.  I have seen a couple of solutions,  but they were geared towards straight up Ubuntu, and I appeared to hit a dead end when I tried them.  Can you vector me to a tutorial?
I am sure I have to share them out with samba or perhaps something else,  but have not seen how to do that.  I ultimately want to replace a creaky old XP file server at my church with Peppermint but I need to ensure I can do it.
Thanks for your help.
Scott G
« Last Edit: June 07, 2014, 04:40:46 pm by sdgengineer »
No Job is impossible for the  person who doesn't have to do it!
Re: File server for Windows users
« Reply #1 on: June 07, 2014, 04:41:57 am »
Hi sdgengineer
You'll need to have Samba installed on your Peppermint PC to share files,
sudo apt-get install samba
then for the gui interface
sudo apt-get install system-config-samba
Peppermint 4 has a useful networking metapackage that installs most of the necessary packages needed for networking including Samba
sudo apt-get install peppermint-networking-pack
Once installed open the Menu>System Tools and you should find Samba there, setting up the share is quite self explanatory but if you need any further help post back here
Good luck
« Last Edit: June 07, 2014, 02:01:01 pm by emegra »
