Author Topic: Can't log out. Screens not visible.  (Read 6887 times)
Re: Can't log out. Screens not visible.
« Reply #45 on: August 29, 2016, 05:33:10 pm »
What happens if you run:
lxsession-logout --display=$DISPLAYor
lxsession-logout --display=:0.0and what's the output from:
env | grep DISPLAYand
xrandr
Offline Darciar
  • Peppermint version(s): Peppermint 7 64 bit
« Reply #46 on: August 30, 2016, 09:57:01 pm »
I ran your latest tests from a liveUSB, as I wanted to see if the problem exists in a non-Ubuntu and it does. I installed Manjaro and whenever you start it up, the login screen appears on my HDMI TV instead of my monitor, despite my telling it the monitor is the primary. I think they programmed it making the assumption that all monitors are next to each other and always on.
Now to the results using Peppermint RC with liveUSB. If you think this is no use, I'll do a full install and try again:
The above two same as before. The pannel appears in my HDMI, not in my monitor.
peppermint@peppermint ~ $ env | grep DISPLAY
DISPLAY=:0.0
peppermint@peppermint ~ $ xrandr
Screen 0: minimum 320 x 200, current 3840 x 1200, maximum 16384 x 16384
DVI-I-1 connected 1920x1200+0+0 (normal left inverted right x axis y axis) 519mm x 324mm
   1920x1200     59.95*+
   1920x1080     59.93
   1600x1200     65.00    60.00
   1680x1050     69.88    59.95    59.88
   1600x1024     60.17
   1400x1050     74.76    70.00    59.98
   1280x1024     76.00    75.02    72.05    60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      59.80    59.96
   1152x864      75.00    75.00    70.00    60.00
   1024x768      75.05    60.04    75.08    75.03    70.07    60.00
   960x720       75.00    60.00
   928x696       75.00    60.05
   896x672       75.05    60.01
   960x600       60.00
   832x624       74.55
   960x540       59.99
   800x600       75.00    70.00    65.00    60.00    72.19    75.00    60.32    56.25
   840x525       74.96    69.88    60.01    59.88
   800x512       60.17
   700x525       74.76    70.06    59.98
   640x512       75.02    60.02
   720x450       59.89
   640x480       60.00    75.00    72.81    72.81    75.00    66.67    60.00    59.94
   720x400       70.08
   680x384       59.80    59.96
   576x432       75.00    75.00    70.00    60.06
   640x350       70.07
   512x384       75.03    70.07    60.00
   416x312       74.66
   400x300       72.19    75.12    60.32    56.34
   320x240       72.81    75.00    60.05
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 160mm x 90mm
   1920x1080     60.00*+  50.00    59.94    59.93    30.00    25.00    24.00    29.97    23.98
   1920x1080i    60.00    50.00    59.94
   1600x1024     60.17
   1400x1050     70.00    59.98    59.95
   1600x900      60.00
   1280x1024     60.02
   1440x900      59.89    59.90
   1280x960      60.00
   1360x768      60.02    59.80    59.96
   1280x800      59.91
   1152x864      70.00    60.00    59.97
   1280x720      59.81    60.00    50.00    59.94
   1024x768      60.04    70.07    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   800x600       70.00    65.00    60.00    60.32    56.25
   840x525       69.88    60.01    59.88
   720x576       50.00
   800x512       60.17
   700x525       70.06    59.98
   720x480       60.00    59.94
   640x512       60.02
   720x450       59.89
   640x480       60.00    60.00    59.94
   720x400       70.08
   680x384       59.80    59.96
   576x432       70.00    60.06
   512x384       70.07    60.00
   400x300       60.32    56.34
   320x240       60.05
« Last Edit: August 31, 2016, 01:46:47 am by Darciar »
Offline Darciar
« Reply #47 on: August 31, 2016, 03:37:27 am »
Just did a full install using the release candidate you gave me. Same behavior as above when the first two commands were run.
And this:
mycomputer@mycomputer-All-Series-Invalid-entry-length-16-Fixed-up-to-11 ~ $ env | grep DISPLAY
DISPLAY=:0.0
mycomputer@mycomputer-All-Series-Invalid-entry-length-16-Fixed-up-to-11 ~ $ xrandr
   1920x1200     59.95*+
   1920x1080     59.93
   1600x1024     60.17
   1440x900      59.89
   1280x960      60.00
   960x720       75.00    60.00
   928x696       75.00    60.05
   896x672       75.05    60.01
   960x600       60.00
   832x624       74.55
   960x540       59.99
   800x512       60.17
   640x512       75.02    60.02
   720x450       59.89
   720x400       70.08
   680x384       59.80    59.96
   640x350       70.07
   416x312       74.66
   1600x1024     60.17
   1600x900      60.00
   1280x1024     60.02
   1280x960      60.00
   1280x800      59.91
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   720x576       50.00
   800x512       60.17
   700x525       70.06    59.98
   720x480       60.00    59.94
   640x512       60.02
   720x450       59.89
   720x400       70.08
   680x384       59.80    59.96
   576x432       70.00    60.06
   512x384       70.07    60.00
   400x300       60.32    56.34
   320x240       60.05
« Reply #48 on: August 31, 2016, 04:23:51 am »
Hi Darclar
I have tried to keep up with what PCNetSPec is asking you to try but he usually leaves me scratching my head more often than not - it amazes me he knows so much.
Simple Q's.
1.     What monitor is the panel displayed on?  DV-I-1 or HDMI-1
2.    With both monitors attached and switched on - if you use ctrl+alt+del to bring up the logout panel, which monitor does it appear on?
Mine will depend on which monitor I used last (ie I click left monitor and it appears on the left.  I click right monitor and it appears on the right.)
However, using the menu and clicking logout it will always appear on the monitor that has the panel displayed.   Regardless if it is labelled default or not.
Does this help you track down the problem ?   My system is similar to yours, except I use a display port and hdmi and both my monitors are always on with my main large screen having the panel on it.  So for me the logout screen always appears on my main monitor.   but I can make it appear on the hdmi monitor by simply placing the panel on that monitor.
I hope this helps somewhat and doesn't end up confusing the issue even more.
Keep trying, It really is worth it when you get up and running.
Offline blooddove
« Reply #49 on: January 23, 2018, 03:37:27 am »
I had the same problem, I dunno if it's Peppermint 8's new function, but restoring the desktop theme was an instant success.
« Reply #50 on: January 23, 2018, 04:03:48 am »
Hi blooddove, welcome to the forum :)
