Author Topic: Peppermint 6 window decoration  (Read 1411 times)
Offline birkopf
« on: August 21, 2016, 08:27:12 am »
Hey,
Where can I find graphics from P6? I wanted to change window decorations in my P7 to P6 looks.
Checked web - nothing
Checked repositories - nothing :(
Re: Peppermint 6 window decoration
« Reply #1 on: August 21, 2016, 10:07:37 am »
The Gtk theme from Peppermint 6 was badly broken in Peppermint 7's Gtk 3.18 .. it **may** be possible to get just the window decoration (titlebar and window surround) to work but the rest of the theme most definitely won't.
The theme is in the "peppermint-artwork" package .. but DO NOT attempt to use that entire package from PM6 in PM7, it WILL break your system as it contains a LOT more than just the gtk themes .. instead you'd have to unpack the package and extract just the theme from /usr/share/themes
Offline birkopf
« Reply #2 on: August 21, 2016, 02:13:14 pm »
This whole "look change" went prettttyy well.
Check picture which I attached :)
However, I ended up with black font under icons and white font on start menu. I need it reversed.
There are multiple tutorials advising how to modify code to change colour, but I was wondering if within Peppermint there are settings allowing to change that ?
https://s9.postimg.org/6wx412f3j/shoot.png
« Last Edit: August 25, 2016, 03:10:51 pm by birkopf »
« Reply #3 on: August 26, 2016, 07:11:55 pm »
The menu button font colour can be easily changed, but the font colour underneath icons on the desktop and in nemo are set by the gtk theme.
