Author Topic: keyboard volume up down not working on Peppermint 7 (SOLVED)  (Read 2464 times)
Offline linxuguy86
  • Peppermint version(s): 7
Hi my keyboard volume up and down not working on my new Peppermint 7 . The brightness keys are working just fine. The volume up and down keys are f7 and f8, no need to press shift or fn. This is my only proplem i found on PEP 7 other wise the best distro ever. :)
« Last Edit: July 28, 2016, 06:35:30 pm by linxuguy86 »
Re: keyboard volume up down not working on Peppermint 7
« Reply #1 on: July 28, 2016, 05:04:49 pm »
Is this a laptop ?
If so, can you mention the make/model ?
Try this .. run:
sudo pluma /etc/asound.confwhen a BLANK file opens, make it read
pcm.pulse {
    type pulse
ctl.pulse {
    type pulse
pcm.!default {
    type pulse
ctl.!default {
    type pulse
SAVE the file and exit pluma
Log OFF/ON (or REBOOT)
test your volume keys.
To UNDO
cd /etcthen
sudo rm -v asound.confthen REBOOT.
« Last Edit: July 28, 2016, 05:13:38 pm by PCNetSpec »
Offline linxuguy86
« Reply #2 on: July 28, 2016, 05:44:30 pm »
omg thank you very much ive been looking the whole day this worked.
« Reply #3 on: July 28, 2016, 11:37:19 pm »
Hi linuxguy86
Glad this worked for you. Can you please go to your first post and click Modify and append [SOLVED] to the subject line.
This will help other users with a similar problem find a solution :)
Offline linxuguy86
Re: keyboard volume up down not working on Peppermint 7 (SOLVED)
« Reply #4 on: July 31, 2016, 11:24:33 pm »
would this also worked in peppermint 6
« Reply #5 on: August 01, 2016, 05:55:44 am »
If it works on your hardware in PM7, it should also work in PM6 .. but there's no guarantee it'll work for all hardware in either.
Give it a shot .. you can easily undo the changes ;)
Offline ericjrich
« Reply #6 on: September 17, 2016, 11:43:43 am »
Here is a script I made thanks to the advice from the user: PCNetSpec (Thanks You PCNetSpec!! )
Download it using the terminal:
wget https://raw.githubusercontent.com/xejrx721/public_main/master/volume_key_fix.sh
Or Get it From here
**dont forget to make the file executable**
chmod +x volume_key_fix.sh
**To run it**
./volume_key_fix.sh
What Does It Do:
1) It will create the file asound.conf in the local directory and add the text to it.
2)It will move the file to /etc (you will be asked your password)
3)it will reboot your machine (use ctrl-c if you dont want to do this)
I hope this works for You
I have used this on a Dell and an HP laptop so far running Peppermint7 and it works.
Offline alelondon
  • Peppermint version(s): 7 xenial
« Reply #7 on: October 07, 2016, 05:18:43 am »
te script works like a charm on my toshiba portege Z30-A-13m.
can it be fixed upstream?
« Reply #8 on: October 07, 2016, 05:32:13 am »
Not sure about upstream .. I could easily put the file in the ISO so it's applied both in a Live session and on installation but I have no way of knowing for sure that it won't have detrimental affects on systems where everything works properly.
