Author Topic: how to install solaris nimbus theme in pepermint 7?  (Read 1825 times)
harishpathangay
  • Guest
« on: July 26, 2016, 05:15:53 am »
hi,
I need this very badly. Solrais Nimbus theme and icons are very good.
i kinly request you to help me.
thanks,
harish pathangay
Re: how to install solaris nimbus theme in pepermint 7?
« Reply #1 on: July 26, 2016, 05:28:59 am »
Hi harishpathangay
Perhaps you could first tell us where you get the theme from. Then we can work out how to install it for you.
Icon sets can easily be installed via the Peppermint Settings Panel and then Customize Look and Feel. Click the Icon Theme tab then click on the +install and then go and find the tar.gz file you downloaded.
Main Themes are done differently.
harishpathangay
  • Guest
« Reply #2 on: July 26, 2016, 10:26:22 am »
hi,
yeah, that is what i am asking.
i find it only for ubuntu trusty. i used the same files in PM 7. gdebi package installer is showing error -  not a valid debian package.
i downlaoded a set of files from gnom-look.org, but it is not working.
any help?
thanks,
harish pathangay
« Reply #3 on: July 26, 2016, 10:41:31 am »
Hi
The more technical members will need a link to the files you downloaded. If you can supply that... and the details about the trusty .deb file. The more detailed information you can provide the better.
All will help them to decide is it feasible. It maybe that until the person who designed the theme updates it, you won't be able to use it in P7.
Regards Zeb
harishpathangay
  • Guest
« Reply #4 on: July 26, 2016, 12:32:05 pm »
hi,
it was downloaded from gnome-look.org.
the links are not working right now. but it did work a year before.
I downloaded those files and installed it in my PM 6 machine.
But now I have reinstalled PM 7 on that machine and find that those downloaded files are not working.
https://www.gnome-look.org/p/1079793/
https://www.gnome-look.org/p/1080244/
Thanks,
HP
harishpathangay
  • Guest
« Reply #5 on: July 26, 2016, 12:41:45 pm »
okay a working link is found here.
https://www.gnome-look.org/p/1013676/
but the deb file wont execute.
thanks,
hp
harishpathangay
  • Guest
i am like really really sorry.
the last link works fine and i was able to install nimbus theme as well. [https://www.gnome-look.org/p/1013676/]
egg on my face....my bad...my very bad...my super bad...
sorry guys....
thanks,
harish pathangay
« Reply #7 on: July 26, 2016, 01:10:11 pm »
What matters is that you solved it - well done :)
