Author Topic: Pepppermint 7 hang on disk detection (installation)  (Read 1194 times)
Offline armageddon51
  • Peppermint version(s): 6
« on: July 25, 2016, 05:15:09 pm »
I am trying to install Pep 7 on an older machine (Abit Kn8 Ultra - Amd Athlon 64). At the phase where it scan for disks, it just  turn in circle and never come back. I have install Mint 18 on that partition before without any issue.
Any idea ?
Re: Pepppermint 7 hang on disk detection (installation)
« Reply #1 on: July 25, 2016, 05:46:15 pm »
None whatsoever, it uses the same ubiquity installer as Mint 18 so if Mint 18 worked so should Peppermint7
If you start the Mint 18 installer again, does Mint 18 get stuck at disk detection now .. which would suggest a hardware or partition problem.
Anything else I could suggest carries risk.....
I mean I could say "format the drive and try again", but if it does turn out to be a hardware problem you may now not be able to get ANY OS installed
« Reply #2 on: July 25, 2016, 08:40:48 pm »
Ok got it to work. If I select "install" directly from the installation disk, it's turning in circle at that point but after selecting the demo mode, I was able to launch the installer and install everything. Good to go.
One note, there is nothing displayed in the install window during the installation, only the progress and comments at the bottom. That's normal ?
« Reply #3 on: July 26, 2016, 12:44:04 pm »
If you mean there was no slideshow during the installation .. NO that's NOT normal.
« Reply #4 on: July 26, 2016, 04:53:28 pm »
Yep ! no slide show for me. No big deal. Everything works.
