Author Topic: mp3gain install not work (SOLVED)  (Read 2106 times)
Offline c_ve
  • Peppermint version(s): v7 (64 bits)
« on: June 02, 2014, 12:45:45 pm »
I am new to Linux and tried to install mp3gain to ajust sound tracks. But after install there was no start button anywhere. There is a mp3gain folder in usr/share/doc and a file called mp3gain in usr/bin   I tried making a .desktopfile but had no permission to do so.
How can i start mp3gain at this point?
(sorry for my english. Its not my native language)
« Last Edit: June 02, 2014, 02:09:22 pm by PCNetSpec »
Re: mp3gain install not work
« Reply #1 on: June 02, 2014, 01:14:15 pm »
mp3gain is a command line tool .. if you want a GUI for it, also install easymp3gain-gtk:
sudo apt-get install easymp3gain-gtk
You'll then find it in the menu's at
menu > Sound & Video > easyMP3gain
Offline c_ve
« Reply #2 on: June 02, 2014, 01:47:20 pm »
Thnks, You're the best  :)
« Reply #3 on: June 02, 2014, 02:08:08 pm »
You're most welcome :)
In the future, can you please remember to mark topics (SOLVED)
You can do this by editing the FIRST posting in the topic and appending "(SOLVED)" to the subject line .. as in:-
Subject: mp3gain install not work (SOLVED)
Thanks in advance...
I've done this one for you :)
