Author Topic: (Solved) Weather indicator/desklet/widget  (Read 2854 times)
Offline Banjo
  • Peppermint version(s): Peppermint 8 (64-bit)
« on: July 13, 2016, 04:55:10 pm »
Does anyone know of some sort of weather indicator/desklet/widget that will work with Peppermint OS 7? I have tried my-weather indicator but couldnt get it to work. Does anyone have any suggestions.
« Last Edit: July 13, 2016, 05:48:59 pm by Banjo »
Re: Weather indicator/desklet/widget
« Reply #1 on: July 13, 2016, 05:40:07 pm »
Download this
http://ppa.launchpad.net/atareao/atareao/ubuntu/pool/main/m/my-weather-indicator/my-weather-indicator_0.8.1-0extras16.04.1_all.deb
double-click it, and when gdebi opens click the "Install" button.
Wait until it's finished, and close gdebi
Open a terminal and run:
/opt/extras.ubuntu.com/my-weather-indicator/bin/my-weather-indicatorit should fire up .. once it does, close the terminal (which will cause the application to exit)
Now start it from the menu
menu > Accessories > My-Weather-Indicator
Offline Banjo
« Reply #2 on: July 13, 2016, 05:50:31 pm »
Download this
Thanks! The icon doesnt show anything in my panel, but if I highlight it I get my local forecast.
Re: (Solved) Weather indicator/desklet/widget
« Reply #3 on: July 13, 2016, 05:55:44 pm »
Huh  ???
How can you highlight it if it doesn't show up ?
« Reply #4 on: July 13, 2016, 06:00:49 pm »
There is also an excellent Xfce4 panel weather plugin.  To install it, run this command in the terminal:
sudo apt install xfce4-weather-pluginFollow the onscreen instructions.  When that's completed, right click on the panel and select: Panel > Panel Preferences....  Select the Items tab and then the + from the right side panel.  In the new window scroll down to Weather Updates (external).  Click on +Add.  Click on xClose
The weather plugin will have appeared at the far right of the panel.  The Panel Preferences will still be open.  You can position the plugin by highlighting it in the large left panel and move it with the arrows ⋀ ⋁ in the right panel.  To set the your location and other weather details, go into the weather plugin's preference.  I hope this helps  ;).
« Last Edit: July 13, 2016, 06:09:50 pm by AndyInMokum »
Offline Banjo
« Reply #5 on: July 13, 2016, 08:06:40 pm »
Huh  ???
There is a gray icon there, but on Linux Mint it actually shows the temp as an icon. No biggie, if I click it, it will show the forecast.
« Last Edit: July 13, 2016, 08:08:41 pm by Banjo »
« Reply #6 on: July 14, 2016, 05:25:02 am »
I've uninstalled it now .. is there nothing in its preferences to change the system tray icon ?
Offline Banjo
« Reply #7 on: July 14, 2016, 08:01:39 am »
It should automatically show up but it seems to have an issue with Peppermint. I'm currently using the one Andy posted above, and it even updates location to wherever I'm at. As a truck driver I always want to know the weather where I'm at, not just at home.
« Reply #8 on: July 14, 2016, 08:05:40 am »
Great stuff :)
