Author Topic: Peppermint 7 - Screen tearing on the ATI open source radeon drivers  (Read 10408 times)
This fix appears to work only for those where:
inxi -G | grep -i driverreports the driver(s) as radeon or ati,amdgpu
For those people where it reports ati,radeon I'm working on a solution and will add it when tested.
[EDIT 2]
For those where inxi reports ati,radeon and the fix doesn't work, keep reading ... there is now a possible solution later in the topic.
As we all know ATI/AMD are not putting any more work into their proprietary drivers (FGLRX), and because Ubuntu 16.04 (and anything based on it) uses xorg 1.18 the old proprietary fglrx drivers can no longer be installed.
So far I'm not really missing them, I've been mightily impressed with how far the open source radeon drivers have come since I last used them .. in fact once you make the necessary tweak to get steam installed and working:
https://forum.peppermintos.com/index.php/topic,3739.0.html
I haven't noticed any real difference between radeon and fglrx, except for one thing  .. the "Tear Free" option that fglrx used to offer .. I've been suffering screen tearing with desktop effects enabled.
Anyway, here's how I fixed screen tearing on the open source radeon (and ati,amdgpu) drivers in Peppermint 7...
(I can't say this will work for everyone, but it sure works for me)
Open a terminal and run:
sudo pluma /usr/share/X11/xorg.conf.d/20-radeon.confWhen a BLANK file opens, make it read
Section "Device"
Identifier  "Radeon"
Driver "radeon"
Option "AccelMethod" "glamor"
Option "DRI" "3"
Option "TearFree" "on"
EndSection
SAVE the file, and exit pluma
Reboot.
To UNDO
sudo rm -v /usr/share/X11/xorg.conf.d/20-radeon.conf
You might want to check for screen tearing both before and after with this video
« Last Edit: November 28, 2017, 08:23:51 am by PCNetSpec »
Offline Bigoeuf
Re: Peppermint 7 - Screen tearing on the ATI open source radeon drivers
« Reply #1 on: July 02, 2016, 08:03:02 pm »
Morning Mark - had a look at this because I have:
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RS482M [Mobility Radeon Xpress 200]
           Display Server: X.Org 1.18.3 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1280x800@60.96hz
           GLX Renderer: Gallium 0.4 on ATI RS480 GLX Version: 2.1 Mesa 11.2.0
I did the youtube video screen tear test & indeed it was tearing so I tried out your fix & on re-boot it wouldn't reach the login screen (got as far as the black screen with the file system check script).
Had to do a hard-reboot - booted into live USB, removed /usr/share/X11/xorg.conf.d/20-radeon.conf from pepp 7 install, rebooted & back to normal. Like you say Mark 'I can't say this will work for everyone, but it sure works for me', which is fair comment, but I would like if fixed if possible - what do you recon?? (I'm using a Dell Inspiron 1501 - slightly dated I know  ::))
Cheers  :)
Offline Timo
« Reply #2 on: July 03, 2016, 02:55:55 am »
Thanks, worked for me.
CPU:       Quad core AMD A8-6410 APU with AMD Radeon R5 Graphics (-MCP-) cache: 8192 KB
           clock speeds: max: 2000 MHz 1: 1200 MHz 2: 1000 MHz 3: 1400 MHz
           4: 1600 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics]
           Display Server: X.Org 1.18.3 driver: radeon
           Resolution: 1366x768@59.99hz
           GLX Renderer: Gallium 0.4 on AMD MULLINS (DRM 2.43.0, LLVM 3.8.0)
           GLX Version: 3.0 Mesa 11.2.0
Yep the open source driver now without tearing has anything the proprietary had in Peppermint 6. Even connecting the laptop to a screen works after reboot (not sure if/how it's possible to get it to plug & play and it still breaks the touchscreen until the next reboot).
AMD might have worked on the open source driver I guess, the just released RX 480 had day one support and from what they said their new drivers should be open source anyways.
Offline SantaFe
  • Peppermint version(s): Peppermint 10 Respin 64bit
« Reply #3 on: July 03, 2016, 03:00:21 am »
Cheers  :)
That's weird, because my video card is this:
Advanced Micro Devices, Inc. [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
And this works fine.  Funny thing is, I tried the solution here: http://ajreissig.com/eliminate-screen-tearing-amd-graphics/ and had the same thing that you had happen to me.  But in my case he had the file saved to /etc/X11/xorg.conf.d/ and also he echoed everything in one line.
« Reply #4 on: July 03, 2016, 03:20:25 am »
@BigouefTry making it just read
Section "Device"
Identifier  "Radeon"
Driver "radeon"
EndSection
Offline Bigoeuf
« Reply #5 on: July 03, 2016, 04:25:22 am »
No joy with that either Mark  :( made it to the login screen which was total distorted & unreadable with what I would describe as horizontal tearing??
« Reply #6 on: July 03, 2016, 04:56:53 am »
I guess your only option is to disable desktop effects, or if you need compositing say for transparency for a dockbar to use compton as the compositor instead.
« Last Edit: July 03, 2016, 04:58:46 am by PCNetSpec »
Offline Bigoeuf
« Reply #7 on: July 03, 2016, 05:26:19 am »
Hmmm - well turned off desktop effects to see if that would sort the 'screen tearing' - rebooted then ran your youtube video - no difference (still shows the lines distorting) ???
« Reply #8 on: July 03, 2016, 06:06:07 am »
Can we have your
inxi -Foutput Bigouef ?
Offline Bigoeuf
« Reply #9 on: July 03, 2016, 06:15:09 am »
You most certainly can:
« Last Edit: September 15, 2016, 04:52:00 am by Bigouef »
Offline Bigoeuf
« Reply #10 on: July 05, 2016, 04:31:59 am »
Dont mean to pester you Mark cos I realise your busy but did my
inxi -Foutput throw up anything?
« Reply #11 on: July 05, 2016, 11:29:53 am »
Yeah, your graphics card is using the "ati" driver not just "radeon", and
yours
mine
I'm just not sure how this affects screen tearing and the fix yet .. still looking into it.
Maybe try
Section "Device"
Identifier  "Radeon"
Driver "ati"
        Option "DRI" "2"
EndSection
or maybe
Section "Device"
Identifier  "ATI Technologies, Inc. ATI Default Card"
Driver "ati"
        Option "DRI" "2"
EndSection
Or some combination of the two.
I think I have a system with an ATI R200 somewhere .. I'll see if I install PM7 and figure it out .. but it may be a few days.
« Last Edit: July 05, 2016, 11:45:24 am by PCNetSpec »
Offline Bigoeuf
« Reply #12 on: July 06, 2016, 02:59:54 pm »
Cheers for your response Mark - tried both of those options for the config file & no joy - resulted in making it to the login screen which was total distorted & unreadable with what I would describe as horizontal tearing (like the one in the 03 July 2016, 11:20:25 post).
I tried your original  code minus the
Option "AccelMethod" "glamor" as I had do a little digging & apparently that function isnt available on older graphics cards (which is probably why I never made it to the login screen on my first try) but again that produced the same result as above also tried swapping Radeon with ATI as Device & Identifiern again with the same result.
Regarding your last message Mark its difficult to see how I could further combine the 2 code options you gave as the only viariable is on the 'Identifier' line & you have covered both (unless I combine them???) so I guess I'll leave it with you Mark when you have some free time available if that's ok?  :)
« Reply #13 on: July 06, 2016, 05:12:08 pm »
Sure, I'll get around to testing on the R200 PC at some point, just a little too busy to clear it off ready for PM7 yet .. it has all the PM6 and PM7 build files on it, so I can't just wipe it ;)
Offline Bigoeuf
« Reply #14 on: July 07, 2016, 12:17:57 am »
Okey Dokey - cheers Mark  ;)
