Author Topic: Peppermint 4 install hangs at partition space screen (SOLVED)  (Read 3647 times)
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
  • Peppermint version(s): 1, 3, 4, 5, 6, 8, 9
I am somewhat a newbie but have installed Peppermint 4 on two other machines without incident, and PP 3 and 1 on other machines.
I have a dell Latitude D630 with 2 GB ram and a 1.8 GHz processor, Intel Graphics. With WIndows XP. 80 GB HD, Win Xp is using about 25 GB.  I want to install PM 4 next to it.  When I select that option I ampresented with a screen and a slider to allocate disk space for the Win XP and PM 4 install.  I can move the slider but I never see any numbers as to how much space is allocated, OK I can leave with that I think the PM install size is on the right, and XP is on the left.  I get it close.  BUT  Then I wait and the Install now button never changes from gray to black.
I have tried a USB and a CD with the same results.
As an alternative I could "do something else" instead of install next to windows, but I need guidance on how to change the size of the existing partition, and how to add the PM partitions as well as the type.
Can you help.  If you can vector me to a site that leads me through how to change the Win XP partition size (without destroying the existing OS) and then how to add the partitions for pm 4 I can muddle through
Thanks
Scott
« Last Edit: May 30, 2014, 09:17:21 pm by PCNetSpec, Reason: Marked as (SOLVED) »
No Job is impossible for the  person who doesn't have to do it!
Re: Peppermint 4 install hangs at partition space screen
« Reply #1 on: May 30, 2014, 10:39:25 am »
Before going any further, can you boot to the LiveCD/LiveUSB, open a terminal (Ctrl+Alt+T) and post the output from running this command::
sudo fdisk -l
Offline mac
« Reply #2 on: May 30, 2014, 10:55:24 am »
PCNetSpec's fdisk request will help you / him determine what you can do as far as the sizes of your
various partitions.  Meanwhile, some genreal thoughts....
Before resizing your WinXP primary partition (C:\) it would behoove you to run the defragmentation tool.  Once that's completed, boot into your Peppermint 4 LiveCD and open Gparted (menu>System Tools>Gparted).  Select the drive to resize and pull the slider from right to left (or you can just enter a numerical drive size in the appropriate boxes).
For simplicity's sake, I would go ahead and apply that change by itself.  Once that's done you'll have unallocated space which you'll formatt for Peppermint.  If the space is large enough I would create the following...
1) a root partition of 15-20 GB
2) an extended partition (whatever is left)
3) a logical partition for /home
4) a swap file of about 4 GB (or double your RAM)
Before beginning you might want to read THIS excellent tutorial by AndyInMokum.
BTW, running WinXP online is something you'll want to rethink.  It is not safe since MS killed all support in April.
Just sayin'.....
« Last Edit: May 30, 2014, 10:58:34 am by mac »
Reg. Linux User #432835
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
« Reply #3 on: May 30, 2014, 12:03:25 pm »
sudo fdisk -l
Here you go thanks for your assistance!
peppermint@peppermint ~ $ sudo fdisk -l
Disk /dev/sda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders, total 156301488 sectors
Disk identifier: 0x782a3f4a
/dev/sda1   *          63   156296384    78148161    7  HPFS/NTFS/exFAT
« Reply #4 on: May 30, 2014, 12:35:49 pm »
OK, the fist step would be to boot into windows and do a full defrag, and run chkdsk against the C:\ partition.
Once windows is defragged and checked OK in chkdsk....
Boot to the the Peppermint LiveCD and try electing to "Install alongside Windows" again.
If that still doesn't work .. you'll need to use Gparted to resize the windows partition.
Boot to the Peppermint 4 LiveCD/LiveUSB and go to
menu > System Tools > Gparted
When Gparted starts, right click on the /dev/sda1 partitions and select "Resize/Move"
Now enter a figure into  "Free space following (MiB)" .. this being the amount of space you want to allocate to Peppermint.
Then click the "Apply" button.
Once you've done that, make sure Windows still boots .. then come back here and post the output from:
sudo fdisk -l
again.
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
« Reply #5 on: May 30, 2014, 05:52:22 pm »
sudo fdisk -l
again.
It tried to install but was stuck at the same place, but it let me select the install button  waited 25 minutes (to ensure nothing going on.) Used Gparted to create a 40 GB unallocated partition for peppermint.
Here are the results of the Sudo fdisk -l
/dev/sda1   *          63    71901183    35950560+   7  HPFS/NTFS/exFAT
Disk /dev/sdb: 1027 MB, 1027416576 bytes
16 heads, 63 sectors/track, 1990 cylinders, total 2006673 sectors
Disk identifier: 0x00000000
/dev/sdb1   *          63     2006672     1003305    e  W95 FAT16 (LBA)
According to what I can tell it created the 40 GB unallocated partition.
Thanks for your trouble..
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
« Reply #6 on: May 30, 2014, 06:40:08 pm »
sudo fdisk -l
again.
great news, I slected the Install next to windows and it installed just fine.  Thanks
Now I need to enable the WIFI card, before I bother you guys again, I will search the archives.  I recall going to the command line and doing an app get.  I will need to look it up..It is an Intel Prowireless 3945 ABG.
I push Peppermint to my friends who have a laptop or desktop that is too old for WIN 7.  I still have much to learn, especially in getting windows native apps to work.
I am older 960) but still like this stuff
Thanks again
Scott G
Offline sdgengineer
  • Forum User
    • Scott Gardner PE
« Reply #7 on: May 30, 2014, 08:30:56 pm »
Thanks
Please mark this closed..
SDG engineer
« Reply #8 on: May 30, 2014, 09:16:21 pm »
Great news .. happy to hear you managed to figure it out :)
To mark the topic (SOLVED), please edit the FIRST posting in this topic, and change
Subject: Peppermint 4 install hangs at partition space screen (SOLVED)
Thanks in advance :)
I've done this one for you :)
