Author Topic: SOLVED -- Installing Se7en- Problems with Modify top Bar -- need shutdown  (Read 2278 times)
Offline crazyodaz
  • Peppermint version(s): SIX - ATE - SE7EN
so yea --- deleted the top bar -- oops --- LOL
FIRST OF ALL --- BIG HUGE THANK YOU TO SE7EN CREW!!!!!!
6 would not run right on this desktop -- maybe it was the i7 -- maybe something else, been tossing between Mint and Peppermint on my laptop, so glad I stumbled on Peppermint few months ago -- anyways... here we go
top bar is reserved for mac's --- get rid of it -- LOL --- I did -- and now my problem
as you can see -- I cant shut down -- cant restart -- cant do normal stuff --- but I can change the start button back to Windows98 style button -- LOL
maybe I am over-looking this issue --- I appreciate any input
again -- SERIOUSLY --- BOTH KODI AND VMWARE working on peppermint 7 --- seriously -- something i could not accomplish with 6 --- THANK YOU SE7EN CREW <3
and thanks for any insight on my Panel modification and stupidity of trying to make something old run even better
I got another issue I will post later --- DRIVER MICROCODE INTEL -- that hapens in MINT 18 beta and peppermint --- not sure what this driver is --- never needed it or was asked for it in 14.04 based machines
just wondering how to fix the GREY'd out SHUTDOWN and REBOOT options
thanks again
« Last Edit: June 28, 2016, 09:17:49 pm by crazyodaz »
Hi, crazyodaz and welcome to the forum :)
See this posting:
https://forum.peppermintos.com/index.php/topic,3712.msg37316.html#msg37316
is that what you mean ?
Offline crazyodaz
See this posting:
yes and no .... and thank you --- LOL
seems the terminal command ---
peppermint-logout
was all I needed --- went back into the main panel settings and added a custom "LAUNCHER" like what the picture shows
now when i click the shutdown on bottom left -- the menu pops up
IMPORTANT NOTE --- my "START BUTTON" is just applications launcher -- it is NOT whiskers ---  all that is left to do is take out the Session Manager that had the greyed out restart buttons -- and just use the one created thanks to your referal tip
thanks again --- appreciate it --- will change as SOLVED
Cool, glad you got there in the end :)
Offline tppthpthp
  • Peppermint version(s): 6 & 7
For those naysayers..........The search tool works!
I ran into the same exact problem while tinkering with switching the applications menu and needed to add a shutdown button.
However, I still have a grey'd out item at the bottom of my Applications menu stating "no applications found". But that's minor. I'm sure it's something I'm missing.
Thanks crazyodaz for a solution.
And I'll just echo crazyodaz sentiment -- BIG HUGE THANK YOU TO SE7EN CREW!!!!!!
tppthpthp aka: "bob"
What's the contents of
pluma ~/.config/xfce4/panel/whiskermenu-7.rc
If however you're not talking about the main menu .. can you say exactly what you mean by
« Last Edit: July 21, 2016, 05:48:21 am by PCNetSpec »
Offline tppthpthp
I switched out my whisker menu to the applications menu in panel preferences.
As seen here.
https://forum.peppermintos.com/index.php/topic,3705.0.html
Everything is there and works fine. Just the last item at the bottom of the list states "No applications found".
If you want a menu like the one from Peppermint 6 (the image below is using the "Applications Menu" xfce4-panel applet in Peppermint 7)
Run these commands in sequence:
cd /etc/xdg/menusthen
sudo wget https://dl.dropboxusercontent.com/u/31525164/peppermint-hierarchical.menu.tar.gzthen
sudo tar xvf peppermint-hierarchical.menu.tar.gznow right-click your "Applications Menu" panel applet, and choose "Properties"
At the bottom of the Applications Menu preferences dialog, select "Use custom menu file" .. then click the little "Browse" icon, and browse to
File System > etc > xdg > menus
and choose the "peppermint-hierarchical.menu" file .. and click the "Open" button.
Then make the other settings look like this:-
Now (if you want the "End Session" button in the menu) back in a terminal, run:
sudo pluma /usr/share/applications/peppermint-logout.desktopand change the line
NoDisplay=true
to
NoDisplay=false
SAVE the file and exit pluma
If you need to make any changes to the top level menu applications....
sudo pluma /etc/xdg/menus/peppermint-hierarchical.menu
and make your changes to ONLY the BOTTOM 2 sections
<!-- General layout of the whole menu -->
    <Layout>
        <Menuname>Settings</Menuname>
        <Separator/>
        <Merge type="all"/>
        <Separator/>
        <Menuname>Administration</Menuname>
        <Menuname>DesktopSettings</Menuname>
        <Separator/>
            <Filename>firefox.desktop</Filename>
            <Filename>mintinstall.desktop</Filename>
            <Filename>sakura.desktop</Filename>
            <Filename>gnome-search-tool.desktop</Filename>
            <Filename>nemo.desktop</Filename>
            <Filename>xfce4-run.desktop</Filename>
        <Separator/>
            <Filename>peppermint-logout.desktop</Filename>
    </Layout>
        <Include>
        </Include>
</Menu>
« Last Edit: July 21, 2016, 09:13:59 am by PCNetSpec »
