Author Topic: how to remove categories from "Whiskermenu"  (Read 2365 times)
    • My MeWe profile
« on: June 27, 2016, 05:04:31 pm »
Okay, starting a new thread as directed :P
I have a few categories I'd like to remove from the new p7 whiskermenu. I'm supposing it may be a wee bit different than changing the top level categories in previous versions of peppermint?
 '18 Asus VivoBook
Online PCNetSpec
Re: how to remove categories from "Whiskermenu"
« Reply #1 on: June 27, 2016, 08:03:10 pm »
There's no simple way to do this, beyond hiding all the icons contained within the category .. then the category will hide itself.
The only other method would be to manually edit
/etc/xdg/menus/peppermint-applications.menu
and I'd STRONGLY advise against that unless you know what you're doing .. you could VERY easily end up with a badly broken menu structure.
    • My MeWe profile
Re: how to remove categories from "Whiskermenu" [SOLVED]
« Reply #2 on: June 27, 2016, 09:51:46 pm »
guess i picked the right board to ask in then... I'm not a gamer...  i had already reviewed our conversation about how we did this in previous versions of peppermint... saved an original copy of the file.... made the appropriate edits and boom... Games is gone... whisker menu just a bit more to my liking...
« Last Edit: June 27, 2016, 10:17:51 pm by spence »
 '18 Asus VivoBook
Online PCNetSpec
« Reply #3 on: June 27, 2016, 10:31:37 pm »
You don't have to delete the .desktop files, just open them in a text editor and add the line
NoDisplay=true
and save them .. they'll then not be displayed in the menu
« Reply #4 on: June 27, 2016, 11:04:47 pm »
Also, if you have icons that appear in more than one category and you want one icon and category gone but the other to remain, you can just remove that category from the "Categories=" line.  If you do it this way, be sure to save the edited file in your ~/.local/share/Applications directory.  If you save it there, it will override the file in /usr/share/Applications folder.  Also, a program update won't undo your changes like it will if you save it to /usr/share/Applications.
    • My MeWe profile
« Reply #5 on: June 28, 2016, 12:54:19 am »
good to know for the other remaining categories, but there will never be any games on this machine, so I'm not too worried  8)
 '18 Asus VivoBook
« Reply #6 on: June 28, 2016, 01:45:34 am »
Hi All
Thanks for all the input - I have now managed to "Tweak" a few items and empty Categories now don't display. I also saved the edited files ~/.local too
 :D Lurnin' all the time - I LUV IT
Linux User #565092
P10r x64 Desktop - AMD Threadripper 2950X - 64Gb RAM - NVIDIA RTX2080Ti 11Gb - 2 x 27" 4k - 1 x 43" 4k
Online PCNetSpec
« Reply #7 on: June 28, 2016, 07:54:27 am »
:) .. fun innit :)
« Reply #8 on: June 28, 2016, 09:33:05 am »
Hi All
I always have to do that with LibreOffice Math.  It shows up in both Office and Educational, but I never install any other educational software, so it's pointless to have a category with an icon in it that appears elsewhere in the menu.  So, I always edit the .desktop file and save it to my local Applications folder because I tried it once where I saved it to the system folder and an update put the category Education back in the file.  ::)  However, the system can't override stuff in your home folder for your user account.  8)
Online PCNetSpec
« Reply #9 on: June 28, 2016, 10:08:55 am »
Yeah good point .. .desktop launchers in:-
~/.local/share/applications
take priority (for the current user) over the system wide ones in:-
/usr/share/applications
If you have the same .desktop launcher in both directories, it will be the one in your home folder that is acted upon.
    • My MeWe profile
« Reply #10 on: July 02, 2016, 06:43:36 pm »
hopefully, y'all will be pleased to know, I corrected my previous edits and took the board admins advice
NoDisplay=true
was added to all the local desktop files which aren't going to be used by me, myself and I... thanks guys
 '18 Asus VivoBook
Offline facucsok
  • Peppermint version(s): 7 Seven
« Reply #11 on: July 08, 2016, 02:14:33 pm »
Alacarte is the best option, (It comes with a restore default button) , I don't know why Pmint comes with menu libre (just sucks, no offense)  >:(
Online PCNetSpec
« Reply #12 on: July 08, 2016, 02:17:57 pm »
So install it .. problem solved (or just starting).
By the way, Peppermint does NOT come with menulibre, it never has and probably never will .. there is no 100% safe menu editor for LXDE so we don't ship with one :P
Feel a bit stupid now ? .. no offence.
And what's with the all bold text ?
« Last Edit: July 08, 2016, 02:29:50 pm by PCNetSpec »
