Author Topic: Peppermint 7 - Steam on the open source ATI radeon drivers  (Read 4520 times)
« on: June 27, 2016, 01:46:05 pm »
If you're attempting to run the steam client under Peppermint 7 on a PC with the open source ATI radeon drivers, but the steam client just crashes...
Try opening Steam from the terminal with:
steam
if that returns the following error:-
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
Try this fix .. open a terminal and run these 4 commands in sequence
cd ~/.steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu
then:
mv -v libstdc++.so.6 libstdc++.so.6.bak
then:
cd ~/.steam/ubuntu12_32/steam-runtime/amd64/usr/lib/x86_64-linux-gnu
then:
now see if steam will start with:
steam
To UNDO
then:
mv -v libstdc++.so.6.bak libstdc++.so.6
then:
then:
« Last Edit: June 27, 2016, 01:54:30 pm by PCNetSpec »
