Author Topic: PM7 Steam Error [Solved]  (Read 1841 times)
Offline Razznak
« on: June 27, 2016, 08:56:15 am »
Installed PM7 yesterday... Wow, it's beautiful! Great job!
However I'm getting this error with Steam, was wondering if anyone else had an idea what I'm doing wrong.
In the meantime I think I'm gonna try to reinstall. Thanks a bunch.  :)
« Last Edit: July 08, 2016, 02:43:47 pm by Razznak »
Re: PM7 Steam Error
« Reply #1 on: June 27, 2016, 08:58:45 am »
Can you post the output from
inxi -Fplease
Can you also try running these 4 commands in sequence
cd ~/.steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnuthen
mv -v libstdc++.so.6 libstdc++.so.6.bakthen
cd ~/.steam/ubuntu12_32/steam-runtime/amd64/usr/lib/x86_64-linux-gnuthen
mv -v libstdc++.so.6 libstdc++.so.6.baknow see if steam will start with
steam
« Last Edit: June 27, 2016, 09:05:18 am by PCNetSpec »
Offline Razznak
Re: PM7 Steam Error
« Reply #2 on: June 27, 2016, 09:12:39 am »
I followed your instructions and believe that did it! Thanks once again for all the help.
Re: PM7 Steam Error
« Reply #3 on: June 27, 2016, 09:14:14 am »
You're most welcome :)
