Author Topic: New Pepp 7  (Read 3605 times)
Offline asheguy
Re: New Pepp 7
« Reply #15 on: June 29, 2016, 11:07:59 am »
Andy how do you use screenruler to move the conky around and find the other themes?
Offline JoeSh
  • Peppermint does the trick
  • Peppermint version(s): 6 and 7 (32bit) 10 (64bit)
Re: New Pepp 7
« Reply #16 on: June 29, 2016, 04:31:46 pm »
Displaying the Nemo file manager with a split screen configuration.  The font and size is Roboto Regular, 11.  The Sakura terminal is rolled up.
Hi AndyInMokum, how do get split screen in file manager?
Re: New Pepp 7
« Reply #17 on: June 29, 2016, 05:15:00 pm »
In Nemo, go to:-
Edit > Preferences > Behaviour (tab)
And tick:-
Always start in dual pane view
Or if you want to split the view manually .. just hit F3
Offline JoeSh
Re: New Pepp 7
« Reply #18 on: June 29, 2016, 06:27:05 pm »
Thanks a lot PCNetSpec.  8)
Re: New Pepp 7
« Reply #19 on: June 29, 2016, 06:35:02 pm »
Hello asheguy, welcome back :)
Re: New Pepp 7
« Reply #20 on: June 29, 2016, 06:49:02 pm »
You don't use the screenruler to move the Conky instances.  It's used to help calculate the positions and spacing.  You know you can open multiple instances of screenruler and have them orientated vertically or horizontally.
To move the Conky instances, you need to go into the config files and position each of the five Conky instances by altering the X and Y axises and their alignment.  I'm assuming you've installed this Conky.  These five files are contained in:
nemo ~/.conkyrc
Here's an example.  I'm using my CPU Conky instance:
# SETTINGS #
background no
update_interval 0.5
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
no_buffers yes
text_buffer_size 1024
# WINDOW #
own_window yes
own_window_type override
own_window_transparent yes
own_window_hints undecorate,sticky,skip_taskbar,skip_pager,below
# BORDER #
border_inner_margin 1
border_outer_margin 1
# SIZE #
minimum_size 185
maximum_width 185
# ALIGNMENT #
alignment tr
gap_x 195
gap_y 28
# GRAPHIC #
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
#default_bar_size 40 8
#default_shade_color
#own_window_colour 808080
# TEXT #
use_xft yes
xftfont Dejavu Sans:size=6
xftalpha 0.8
uppercase no
override_utf8_locale yes
default_color 666
# LUA #
#lua_load ~/Conky/bgcolor/bg.lua
#lua_draw_hook_pre conky_draw_bg
# Colors #
color1 C18C24
TEXT
${font  Poky:size=20}P${voffset -3}${font Impact:size=16}$color1${goto 30}${cpu cpu0}${goto 60}${color}%${color1}${goto 90}${font}${voffset -10}${top name 1}${alignr}${top cpu 1}$color
${goto 90}${top name 2}${alignr}${top cpu 2}
${goto 90}${top name 3}${alignr}${top cpu 3}
${voffset -10}$color1${cpugraph 15,80}$color${goto 90}${voffset 10}${top name 4}${alignr}${top cpu 4}${voffset -25}
The lines highlighted in red determine the position.  The screen is divided into 6 quadrants.  This particular Conky instance is in the Top Right quadrant as indicated in the line highlighted in green.  Here is a link to my .conkyrc folder containing my customized positions for all five Conky instances: https://mega.nz/#F!v4tlUJaZ!YrLxgZkQZTFExkw3XfILHg.  Download the zip file and open it.  I hope this helps - good luck and have fun  ;).
« Last Edit: June 29, 2016, 08:02:19 pm by AndyInMokum »
